Question about IBM Wheelwriter 6 Typewriter
I replaced the typewriter ribbon, but now the "hammer" doesn't move. What do I do now? Dagmar
  • IBM Master
  • 3,594 Answers
The plastic print solenoid is probably broken. We sell them for 20.00 includes instructions and shipping.
DickyO
Cleveland Business Machines
216-241-0027
sales@cbmohio.com
Posted on Oct 18, 2010
My typewriter won't type. The cartridge moves, but nothing prints
The ribbon may be broken or binding so that it cannot advance.
Apr 19, 2014 | Brother EM-430 Typewriter
Hammer doesd not strike
There is a clutch system under the ribbon carrier that has to rotate to move the hammer, see if you can see if this part is rotating, also there is a spring that puts pressure on the hammer. If this clutch is not moving it may need replacement,, or cleaned with alcohol.
Apr 14, 2014 | Brother ML-500 Typewriter
Canon ap350 typewriter
I believe there is a lever (maybe green on the lower part of the print head for copy adj.
DickyO
Jan 28, 2014 | Office Equipment & Supplies
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
The hammer for my brother ax-250 electronic typewriter doesn't move at all but everything else works fine, how do i fix the hammer?
The Hammer armature on the solenoid is cracked. This is a tough fix. for experienced repaimen only.
Dec 23, 2012 | Office Equipment & Supplies
The ribbon will not index forward on my 345 DLE. It appears that the shaft that inserts into the cassett does not turn to move the ribbon.
if the knob on the ribbon cartridge doesn't move the ribbon when you turn the knob the direction of the arrow (on the cartridge next to the knob) you need a new ribbon
Nov 03, 2011 | Smith Corona Wordsmith 100 Typewriter
Nothing shows on the paper when I type.
Remove and observe the ribbon, wind the feedwheel to see if the ribbon if moving at all. Make sure that the correction tape is not in front of the printheel and installed properly. (electronic machines use non-sticky lift-off tapes).. Observe the hammer movement. The ribbon winder in the cartrige could be defective, the ribbon ffeed mechanism in the machine may need repair/replacement. Make sure there is a printwheel in the machine.
Nov 15, 2009 | Brother GX-6750 Typewriter
IBM wheelwriter
Is the hammer moving at all? There is a rubber part on the I think left side of the ribbon hammer, down on the side of the printer. This will adjust the amount of impact. I really doubt if
this is the problem, but worth a try to look at. This part and I think it is a blue slide will move up and down to adjust the impact. Possible lubrication and there is a large spring that actually pulls that hammer forward, check to see if this spring is OK. Other than that electronic problems such as main board, printer motors, etc. Does hammer move freely by hand? Also mechanical binding in the printer... GOOD LUCK.
Jul 23, 2008 | IBM Wheelwriter 30 Typewriter
IBM 1500 by Lexmark
If it is moving as the hammer is struck, then it's one of two things. Either the hammer is moving too slowly, or the ribbon is moving too quickly. Since this is a rather old machine, it seems more likely things would slow down than speed up. I'd check the hammer solenoid. See if it's dirty, or needs lubricated. I wish I could give you more advice on this, but I am not familiar with this specific model, and was unable to find any kind of service manual, or troubleshooting information for it.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 6 Typewriter Logo
42 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
