Question about HP Photosmart R725 Digital Camera
Hp photosmart r725 6.2 megapixels.
I need help, my cam wont turn on, it displays a error to reset it and i pressed the reset several times and nothing, i thought maybe was the lens lid staying open and so i check but nothing,, please email me asap.. sweetnena0437@aol.com........ ineed it for sat graduation day... please help
  • 2 more comments
  • lovemyboys Jul 02, 2008
    the camera wont turn on says reset camera error 184489957000
  • Anonymous Aug 05, 2008
    My digital camera will not turn on. I thought the battery was dead so I charged it for 24 hours and it still will not respond when I press the On/Off button.
  • vetgal69 Feb 15, 2009
    i try ti turu on the cerema but it display erro 000000184489957000 on the front but it not staying on it says to reset but how do u reset?
  • Anonymous Mar 24, 2009
    My camera starts up, the screen goes red says error 000000184489957000 reset camera.
    how do you reset?
  • 4 Answers
If you're getting the 18-4489-957-000 error code, then give it a good tap on the corner where the lens cap is. A little tapping and the lens cover should pop closed. When you turn the camera on again it will probably work just fine.
I was just about to junk my camera when I googled the error code and found this very tip in another thread. It worked like a charm.
Posted on Jul 01, 2008
  • 1 more comment
  • jerzeyjewelz Oct 31, 2010
    I got the same error code. I tapped it a few times just like you said and it worked for me. Thanks so much for posting that.
  • Tiny Tim II Jul 01, 2011
    I had the same problem, but it took me many trials to recognize the error code, because it came up only for a fraction of a second! I wanted to report it to HP, but they told me that this modes is now (mid 2011) no longer supported. Then I entered the error code in google and came straightaway to your solution. I tried it, a n d i t w o r k e d!
    Thank You very much!
  • Anjan Rakshit
    Anjan Rakshit May 11, 2014
    I was getting message 18-4489-957-000 error code in my HP R725 Camera. Wasted a lot of time in trying to get a solution from HP Support site. Then as a last try googled the error code and got solution provided by raycr with success report from others. It worked for me. Thank you all very much for sharing your experience
I have a photosmart r 725 digital camera that was working just fine but this mornig when i activate to open the camera instead of having picture of the object i want to shoot i have instead on the screen a white screen with vertical line. i have tried as suggested by hp support guide on internet to remove battery and card for 10 seconds and reinstall but it didn t work any suggestions. thanks
Posted on Feb 03, 2009
I had the same problem with my cam. the lense cap was also broken, i mean, it wouldn't close.
I also googled and found that i should to try to get the lense cap to close, by tapping, and my camera would work.
And soo... i failed to get the lense cap out, so i searched a little more and i found a solution: SUCTION! haha it really worked for me.... like trying to **** the lense out. The lense doesn't have to come out for it to work. The error stopped appearing, and I could take my pictures :)
Posted on Jul 14, 2008
Error:oxc18a0401??
Hi There,
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Nov 04, 2010 | HP Photosmart 3210 Printer
How do I fix Error:Oxc18s0301 Ink system failed.
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
Full reset
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Aug 20, 2010 | HP Photosmart C6280 Printer
I changed the black ink cartridge and after the printer's maintance process, it gave me this error code: 0xb8255932
here.. check this out. a solution to your problem.
Semi reset
Full reset
Aug 17, 2010 | HP Photosmart 3210 Printer
Error: Oxc18a0401
Semi reset
Full reset
Aug 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
I have HP photosmart 321 all in one and I have
Semi reset
Full reset
Jul 05, 2010 | HP Photosmart 3210 Printer
When I am printer Hp 3210 Messe error like this 0xc18a0206
Semi reset
Full reset
Jun 07, 2010 | HP Photosmart 3210 Printer
0xc18a0001
Semi reset
Full reset
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
Jun 02, 2010 | HP Photosmart 3210 Printer
0xc18a1002 error message on HP Photosmart C-7180 Printer
Resetting HP Photosmart C6180 & C7180 "system failure" errors:
(might work on other similar models as well)
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
Feb 03, 2010 | HP Photosmart C7180 All-In-One InkJet...
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart R725 Digital Camera Logo
517 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
