Question about X2Gen MG19VT 19" LCD Monitor
MW19r powers up but sceen remains black - X2Gen MG19VT 19" LCD Monitor
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 08, 2010
Why no start?
Many reasons take it to a good repair shop .
May 03, 2015 | Computers & Internet
Laptop sceen black
If everything else is working, hook a spare monitor to the video output, if picture okay! the inverter board just below the screen is more than likely faulty, or the backlight behind the display has failed, but if both show the same symptom it is the video graphics card usually built into the motherboard, I suggest a computer repair shop to address.
May 05, 2012 | Toshiba Computers & Internet
My 19 inch x2gen mw19r monitor just went black its still on but wont display a picture so now im using my old tube monitor want to fix the x2gen
titter101, You left out telling us the "DATE of MANUFACTURE" for your unit. You will need to use CRT unit while researching info on x2gen mw19r unit. If unit out of warranty, then you or qualified technician will need to do the investigation and repair of unit. Read the fixya profiles of "budmrtn" , "buddymc" , "12fixlouie" to see if a DIY repair will work for you. 12fixlouie
Aug 16, 2010 | Computers & Internet
The sceen is black but wen u press the power
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 13, 2010 | Neovo AG E-17A 17'' LCD Monitor
Stefieanne, The long, thin, "cold-cathode-fluorescent-lamps" are not staying lit anymore. Unit's "switch-mode-power-supply/CCFL inverter supply will need REFURBISHMENT to restore proper operation. SOFTWARE WON"T HELP YOU!!!!! Visit all links you find while doing some reading in my fixya profile to help you in the big decision you will need to make on what you will do with this "black" or "blank n black" screen ccfl back-lit lcd monitor. Do you have soldering pencil of about 35 watts and some solder and pliers and screwdrivers and even a digital voltmeter. Contract out the work $35 to $90 Tell us what your intentions are. 12fixlouie
Mar 21, 2010 | Neovo AG E-17A 17'' LCD Monitor
TV is turnrd off and the red light gos out when u turn it on but sceen remains black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 16, 2009 | TruTech PVS2119 19 in. LCD Television
Blue sceen how to get to window
just reinstall the operating system, if the problem remaining same then replace the RAM.
Aug 16, 2009 | Computers & Internet
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
X2gen MW19R picture only stays on for one to fifteen seconds...
Dear Chris,
Visually check the component :
Try checking on the power board , may be ESR of capacitor is faulty and power resistor shorted and burnt.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19VT 19" LCD Monitor Logo
187 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
