HI, MY RADEON 9800 VIDEO BOARD IN A TOWER BUILT IN 2004 HAS FAILED. THE SIX-YEAR OLD POWER SUPPLY IS A 380 WATT "PREMIER" AND I AM RUNNING THE AGP VIDEO CARD ON MICROSOFT XP HOME SP3. MY PROCESSOR IS A PENTIUM 4. I AM CONCERNED ABOUT THE REPLACEMENT CARD NEEDS FOR MORE THAN 380 WATTS THAT I CURRENTLY HAVE ON A 6 YEAR OLD POWER SUPPLY. ADVICE?
    President:
  • 2,992 Answers
There's no reason not to replace the power supply if your video card needs the extra power. Having excess capacity is not going to hurt anything. (Some people wrongly think that a larger supply than originally installed will burn out parts. Won't happen...the excess capacity just is unused.) The only problem you might have is fitting it in to the case if the original supply was a proprietary design. This was true with many manufacturers, and a generic replacement just wouldn't fit.
500-watt supplies are available starting at about $25 (US). Get a new supply and video card and you should be in good shape for a while. Thanks for using Fixya!
Posted on Oct 08, 2010
    Problem Solver:
  • 6 Answers
Since you have to purchase a new video card then I would go ahead and get one and see what happens. Worst case, you'll have to go buy a bigger power supply.
I have a Radeon HD3450 512MB agp graphic card and my system wont recognize it why?
You would need to install the drivers and possibly disable the on board video card in BIOS.
Jan 31, 2013 | EliteGroup KV2 Lite (V1.0) Motherboard
Running Windows 7 Home Premium, recently tried installing Radeon X1300 AGP video card, and computer won't display anything or boot with it installed. With card unplugged and using onboard video it still...
Hi - I believe you might be suffering from one of two (or even both) problems. The video card sucks lots of power and I believe has a separate power connector on the card that should be connected. The type of connector varies with manufacturers; from a four pin floppy disc type to a molex type connector or even something proprietary.
Secondly -- It's recommended that you have a 350 watt or higher power supply in your system.
Either issue could keep your machine from booting.
Good Luck, Mikeywaf
Dec 21, 2010 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
Hello, my monitor has streaks running through top to bottom. I can still read the font but just barely. What might be causing the streaks? The machine is factory Sony P4 3.2 tower, the video card is the...
Possibly conflicting with something or the card has failed or it could be a driver issue try & update the drivers if this doesn't work check in device manager if there is a yellow exclamation mark then there is a conflict somewhere, if driver update doesn't work & no conflicts are found your card has failed & will need to be replaced.
Oct 26, 2017 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Video black with 7600gs card installed
Hi bandit11,
First how did you get a PCI-Express X16 like the 7600 onto a AGP 4X port?? Two different animals. To answer your qustion, no that Card will not work on that Board. You can spend your money if you want to on some of the higher speed video cards but, to be turthful, I wouldn't. The CPU and memory will limit any of the newer cards that will fit that board today. But, if you really want to keep that board, then I might suggest to look for a $40-50 Radeon 9700 pro or 9800 pro. Anything more than that is a waste of your money.
Bottom line a lower end AGP cardwon't give you any more card performance then high end AGP card if you must upgrade, go used and cheap...nothing fancy.
Best of Luck
Mark
Dec 11, 2009 | Syntax SV266M Motherboard
Video ram error 2ATI/1/4:113-A14404-118 in Apple hardware test Power Mac G5 DP 2,5 ATI Radeon 9800 XT
This one is pretty clear. Your machine is a June, 2004 model. Your video RAM is bad. Video RAM is not user-replaceable on the Radeon 9800 XT, so you will have to replace the Radeon card itself.
Oct 16, 2009 | Apple Power Mac G5 Desktop
Powercolor Radeon 9550 R96 256mb Card - Lights on, noone at home!
Depends on the video card ,it might require more power ,200w is fine for onboard but add other components and the system needs more power.
Disconnect the harddrive or CD ROM drive and see if the system will start.
If it starts then you will need more power 300-400w at least but shuttle power supplies can be expensive to get.
May 18, 2009 | Power Color RADEON 9550 R96-LC3 (128 MB)...
Update video card
It will work fine. I looked up one for you here: http://search%20sapphire%20ati%20x1650%20pro%20512mb/
cost is $65.99 and it only requires a 350 watt psu so you are good. Hope this helps & please remember to rate my answer.
Dec 29, 2008 | ASUS K8V-SE Deluxe Motherboard
Ati radeon agp card
Hi Rafael83,
There may be afew things that may be wrong. One, the video card may be bad, two the motherboard may be bad, or three your power supply may not have enough wattage to power your video card. Or it coud be all of the above.
Sincerely,
Agent Xiong
Apr 30, 2008 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
Swap 9800 Pro for 9700 Pro
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
http://ati.amd.com/support/driver.html
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
Oct 30, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Replacing a Radeon 9800 Pro AGP graphic card
Axis 3000 is listed as 360w and this should just do as the card requires 350w. As you are going to Ebuyer anyway why not get a new PSU, they have a 450 watt PSU with a large fan for £16. Make sure you are getting the AGP version and not the PCI-E version of the card. I find eBuyer are usually open to replacing items and you could ask their tech support first.
Sep 10, 2007 | Evesham Axis PC Desktop
Computers & Internet Logo
David Payne
David Payne
