Question about Hobart Welders 500505 Handler 140 MIG & Flux Cored 140 Amp Welder w/Cart
Wire stuck in Lead - Hobart Welders 500505 Handler 140 MIG & Flux Cored 140 Amp Welder w/Cart
  • 29 Answers
Snip wire loose from spool -- hold trigger down and pull excess wire out of trigger
Posted on Jan 02, 2011
1994 GMC C1500 Sierra, 5.7 liter, 2WD. Replacing a one-lead ECT sensor with a two-lead??
Your engine coolant temp sensor is a two wire sensor.
The temp sending unit for temp gage is a different animal, one wire connector.
Nov 14, 2016 | GMC Cars & Trucks
The compressor runs for 5 minutes and turns off for 3 minutes. Is this normal?
This seems to be normal from the info you have given. If this is a window unit, it should have a sensing lead at the indoor coil (lead as in a sensor that may be a wire with a part of the very end of it stuck to the front of the indoor coil OR a wire or copper tube that is clipped to the front of the coil). This lead senses the indoor coil temp and when its "satisfied" it will stop the compressor and the indoor fan continues to blow air which heats the sensor and a few minutes later the cycle begins again. I have had to pull the sensor away from the coil a bit for it to cool a room.
May 29, 2015 | Keystone KSTAW05A 5,000 Cooling Capacity...
What would cause no oil pressure
Clogged oil pump pick up screen, a stuck open pressure relief valve on oil pump, clogged oil passages. Verify gauge operation, unplug oil pressure sender , turn key on, have someone observe the gauge, for single wire, ground the lead to the engine block, gauge should go up. For two wire lead , jump the ends to each other.
Dec 21, 2013 | 1999 Dodge Ram
Wire is stuck in lead my licon weld pack 100
If can't pull it out, remove the section where the wire is stuck
Mar 21, 2013 | Welding Tools
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Brought 1979 out of storage after five years. Put in new battery and all accesories work, car turns over but will not start. No spark was comming from plug wire so I checked the coil. No spark came from...
Most likely the points, but check the low tension coil wiring as well. If the points have got stuck together during storage or if the wire to them is disconnected then you won't get a spark. If they've slipped totally closed you won't get a spark either. Replace the condenser at the same time, they don't last forever and are cheap.
After changing the points or re-gapping them, you MUST re-time the ignition, statically to begin and then dynamically once the engine is running. ****** the timing slightly from standard to take account of lead-free fuel, unless the car was supplied from new to a lead-free country.
Oct 09, 2010 | Alfa Romeo Spider Cars & Trucks
How do you remove a broken wire in the wire liner with no wire exposed at either end of the liner?
Remove the lead completely from the welder and remove the tip Strip all of the insulation off of larger piece of copper electrica wire (probably #12) and push it through the lead. You need to use the largest size copper wire that will fit in the lead so that the stuk wire does NOT jam against the inside of the lead. It is a **** shoot as to whether or not you can clear the lead to the weld head. If you know you folded the wire inside the lead you can try making a "tight" hook with a piece of the wire weld wire to try and hook the piece that folded over. Good Luck!
Kelly
Feb 21, 2010 | Welding Tools
Wheel will not turn at all my fan will come on and i pull the trigger and it wont turn it will just wine
Take the spool off of the machine and see if the feed wheels turn. If they do, you probably have the wire stuck in the tip or the line leading to it -- replace as necessary. If they don't turn, there is something jammed at the feed rollers or the motor that turns them. My bet would be that there is something stuck in the lead to the gun or the tip. The whine noise is probably the rollers slipping on the wire. Since the wirewill not feed, the spool doesn't turn.
Nov 29, 2009 | Hobart Welding Tools
I have an 04 s4 and recently the horn goes off and gets stuck in that orinentation. it wont shut off unless i pull the horn fuse or battery lead. when the horn gets stuck on the hazards also come on n stay...
methinks a stray wire in aftermarket alarm system. Most horns are negative switched (ie they are operated by earthing a wire on the steering column) and would not interfere with positive-switched items such as the hazard lights. Does your car have an aftermarket alarm?
Sep 17, 2009 | 2004 Audi S4
Oasis HE
You have something stuck in the drain pump/filter. Remove the pump filter and clear the blockage.
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Hobart Welders 500505 Handler 140 MIG & Flux Cored 140 Amp Welder w/Cart Logo
113 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
