Question about Hussmann HGM-2-TS Commercial Refrigerator
Temperature not coming below -9C - Hussmann HGM-2-TS Commercial Refrigerator
    Scholar:
  • 86 Answers
Hello there:- First of all you should clean out the condensor unit and see if that works. all the Best God bless.
Posted on Oct 09, 2010
My fridge temperature sensor is alarming and temperature is now +9C. what shall I do?
Hard to tell...Don't just let a service fella throw parts at it....
Sounds like you have a thermistor that is in trouble or a connection related to it. If you are able to follow directions here is a link to the service manual. There is a section for testing and isolation....
This fridge unfortunately is quite complex....Most servicers can't fix them.
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Apr 11, 2010 | Samsung RB215LASH
Rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Jan 17, 2010 | Refrigerators
Moto Q 9C I accidentally erased some files and
here is a post that will help you to update and reload your software.
look down a couple comments and the Guest comment will help.
http://www.fixya.com/support/t201587-motorola_flash_mode
Good Luck and Thanks for using FixYa
Jun 17, 2009 | Motorola Mobility MOTO Q 9c Smartphone
Error MOTO Q? 9c
My phone does the same **** from time to time, all you have to do is take out the battery and put it back in and turn your phone on and BLAM good as new and it sould work just fine. =]
Jan 03, 2009 | Motorola Mobility MOTO Q 9c Smartphone
About the windows XP SP2 directX 9b to 9c
Have you tried the slimmer version, the 34Mb? Additionally, have you tried installing in Safe Mode?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Microsoft Windows XP Professional
Webcam driver for advik model no a-9c 101
hi ,
i m searching for advik driver A-9c 101, but i an not getting it. so send this driver to me..
Rajeev
Aug 20, 2008 | Computers & Internet
Refrigerator temperature can't be set to cold - sensor light shows 9C and keeps on beeping. Samsung model RB1855SL
I had this exact problem with my 4 yr old Samsung RB1855SL refrigerator. BTW, the temperature display doesn’t display higher than 9C, even when its warmer inside. The fan wasn’t turning on to circulate the cold air, although the cooling coils were still cooling. There was no excess ice build-up. The freezer was working fine.
I thought perhaps the fan was toast or the temperature sensor. Then I noticed the interior fridge light was not turning off when closing the door (but the freezer light was). BINGO—thig light switch was the problem. A small piece on the inside of the fridge side of the switch was broken. When the door was closed, the broken switch didn’t let the fridge know that the door was in fact closed, causing the door alarm to keep beeping. This must shut the fan down in order to save energy when regularly opening the door.
DIY fix: I removed the switch (until I could get a replacement) which is located to the left of the lower door hinge (right hand side). Gently, with a flat nose screw driver, I pried it out.
The light no longer turned on when opening either door but that was a small price to pay compared to the incessant beeping and rotten food. The part can’t be very expensive and I can replace it myself. The local appliance repair shop will order it for me.
No expensive “internal brain” needed to be replaced or an expensive repairman needed to be called. Good luck!
Aug 17, 2008 | Samsung Heating & Cooling
Frigidaire frf170ff alarm keeps going off, but has been no powercut and door has not been open but temperature will not go down to -18 oc it is at -9 oc and superfreezer does not alter temperature!
We have same problem. Its stored in a intergal garage had it since Jan 08, no problem until now. The last 3-4 days its been beeping the alarm, temperature according to the display varies between -9c and 11c/ Despite doing the fast freeze over night temperature hardly improved at all around -1c. to 12c. Its quiet a cold night tonight 14c in garage yet temperature of freezer remains at -11c
May 05, 2008 | Refrigerators
Hussmann HGM-2-TS Commercial Refrigerator Logo
70 people viewed this question
Top Hussmann Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Hussmann Refrigerator Expert? Answer questions, earn points and help others
