Question about Sport & Outdoor - Others
YOU NEED TO HAVE A MARINE/BOAT CATAGORY...I have a fiberglass fishing boat and the ss screws that hold the hinges to the lids of my fish boxes are loose. The "screws" may, in fact, have a nut on the other end that has worked it's way so loose that when trying to back it out, it just revolves and will not tighten or back out. Is there a way to fix this probelm?
    Top Expert:
  • 80,637 Answers
U will need to first see if the screws are machine screws or wood screws, but i suspect they are machine screws with a nut, u will need to gain access to the nut in that case, whatever that takes, no magic method to do this.
Posted on Oct 08, 2010
Where do you find year model on a boat
usually on a plate screwed to the transom or just embedded into the fiberglass on the transom.
Aug 11, 2014 | Boating
Water in hull of bass tender pro
Find the leak and patch it. Use a good marine epoxy system with a sheet or two of fiberglass cloth laid-across the crack. Be sure to sandpaper the area thoroughly with rough paper. If you can't find a leak or crack, fill the hull with water and inspect for leak. Repair after.
May 20, 2014 | KL Industries Basstender 10.2 Fishing Boat
What oil do i use in the lower unit of a 1989 90 hp mercury outbord
go to a marine store and get lower unit gear lube. it comes in a squeeze tune and just remove the plug and squirt it in . both screws need to be out tho upper one lets air out as you push new in lower .the put upper back in first keeping oil in till you put in lower plug
May 01, 2010 | Light Outboard Motor Boat Bass Fishing...
I HAVE A 1995 STARCRAFT FIBERGLASS FISH/SKI BOAT WITH A 1995 FORCE 90 HSP. MOTOR... I JUST BOUGHT THE BOAT... THE PREVIOUS OWNER SAID HE CHANGED THE STEERING CABLE... WHEN I TURN THE STEERING WHEEL LEFT...
are you sure about this or guessing with the boat on the trailer . they do move the motor in the opposite direction as one would think they should .
Apr 07, 2010 | Boating
1978 Mercury Marine boat motor
Get a Repair manual from the library or marine store
It explains it well . bad selinoid
Sep 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Need a op. manual for uniden mc-600 fish finder
There is not a Uniden Marine Electronic with MC-600. Here's are all the manuals for Uniden Marine Electronics =>
http://www.uniden.com/index/manuals_results.cfm?cat=7
If it's the Cobra Fish Finder MC600, here's the operation manual =>
http://www.cobra.com/downloads/manuals/MC600C_MANL_ENG1.pdf
Jan 03, 2009 | Boating
Why are Aluminum Fishing Boats the Best Fishing Boats?
A timber boat is high maintenance. Trust me, I've had quite a few. You're always sanding timber, varnishing timber, repairing timber and lots more. Now if you're happy to be doing that then that's great, but recognize that's the price you pay for a great looking timber fishing boat. And a timber boat is often heavy, and will not last well, particularly if you aren't as diligent with your maintenance as you could be. And they puncture easily when you hit something, as I did last week. But if you're not an enthusiast for working on boats then timber isn't your best choice. What you want in a fishing boat is this. It needs to be tough. It needs to be low maintenance. It needs to be puncture resistant. It needs to last forever without spending hours working on it. It needs to be easily repairable. And it needs to be cost effective. For me the best choice fishing boat is an aluminum fishing boat. Aluminum has properties which make it the perfect material for building fishing boats. It is very light and strong for it's weight, and can be easily welded, so is ideal for both building and repairing. It is extremely long lasting, and is very resistant to puncture. Now of course that doesn't mean it can't be damaged, as it can. But you need to hit it pretty hard to do some serious damage. And if you did that to a timber or fiberglass boat it will be very seriously damaged. And an aluminum boat may just dent, rather than fracture, so you can head right back home with nothing more to show than a dent, instead of possibly be the subject of a rescue from a sinking boat. And it lasts forever if treated right. If you get a great aluminum fishing boat and treat it well you may well find yourself leaving it to your kids. Because aluminum boats are light for their strength they often need a smaller engine, and the engine is probably the highest cost item. A smaller engine costs less, and uses less fuel. And with a smaller engine they are also lighter and easier to handle. And they require little maintenance. Make sure you hose your boat down after a day out, especially in saltwater, and if you drop a lead sinker make sure you pick it up, as it's not great to leave any other metal in contact with aluminum, otherwise you don't need to do too much maintenance at all. More fishing time. And because aluminum boats last so well they also retain their resale value well. I bought a used aluminum fishing boat 2 years ago and it is currently worth a little more than I paid for it. So there's plenty of good reasons to buy an aluminum fishing boat. Unfortunately they aren't cheap if you want to buy a new boat, but for the same reasons I've mentioned above, it's way better to buy a used aluminum boat, as a used boat is usually much cheaper than a new one, and retains it value well. I would never buy a new aluminum boat. So grab yourself a great used aluminum fishing boat and get fishing this summer, it's the best way to get on the water.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
How do iI chose a fishing boat?
There are three styles of regular fishing boats; deep v, regular v or modified v. The v determines how well the boat cuts through the depth of the water. The deep v is better suited for large lakes because they can handle heavy waves better. Regular "v" is more appropriate for smaller lakes and a man made body of water. As the water is not as deep and the waves are not as heavy, this type of boat is able to handle the situation. The modified v is the most popular version. It is capable of handling speed best. Most fishing boats on the market today are made of fiberglass or aluminum. What is best for your fishing situation? Do you want to fish in large lakes or small lakes? The options are endless. There are several classes of fishing boats for different situations. All purpose fishing boats are great for your basic fishing needs. This type of boat has space for some bench seats, fishing gear and a simple steering station. They are made of either fiberglass or aluminum and are between 15 and 20 feet long. Another type of fishing boat is a bass boat, which comes fully equipped with space for rods and fishing gear. The boat is fully built with electronics and livewells. This boat also is made out of fiberglass and aluminum. The advantage to this type of boat is it is made especially to catch bass, fast. The third type of fishing boat is the center-console. It allows a fisherman to angle from any place on the deck. The control center is located in the center. Depending on the size of the boat they can be used offshore as well as near. Flats boats are mostly made up of fiberglass. The advantage of these boats is they allow easier angling access to saltwater flat fish. Another advantage it has is a poling platform that allows for fish spotting. Finally, a casting deck allows the angler to keep control. This makes this ype of boat convenient for fishing. The final category of fishing boats is the fun boat because it combines the motor of a yacht and the functionality of large a cockpit to work trophy fish and bring them on board. If ou are a fishing fanatic then it is important to have all the things that you need to make your fishing trip a success. Fishing boats are definitely the finishing touch to a nice fishing trip.
Sport & Outdoor - Others Logo
63 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
