Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Bought non kodak cartridges and it won't work???
  • Kodak Master
  • 6,826 Answers
Kodak specifically recommends using genuine Kodak cartridges in their printers in their literature.
Please don't use generics in Kodak printers, is essentially what they say to do if malfunctions occur.
Good luck on this repair.
Posted on Oct 08, 2010
I"ve replaced printhead and cartridges but readout tells me to replace cartridges.
• Check that KODAK Ink Cartridge(s) are installed. Do not use non-Kodak brand or
refilled ink cartridges.
• Remove, then install the cartridges again.
Make sure the cartridges click into place
Feb 12, 2015 | Kodak ESP C310 AllInOne InkJet Printer
I replaced the ink and closed machine tried to copy but the replace ink keeps coming on,, what can I do?
Are you using Kodak cartridge? They have a chip that communicates with the printer. If non-Kodak ink cartridge, it may not work properly.
Oct 12, 2014 | Kodak ESP C315 Wireless Color Printer with...
Black printing double ink
This is often a problem when using non-Kodak inks as the cheap after-market cartridges use dye instead of pigment inks. Replace the after-market cartridge with the proper Kodak pigment ink cartridge and the problem should go away. If you are using a Kodak cartridge, you may need to run your printer through the cleaning cycle a couple of times. Also, run the printer through the calibration cycle once.
Mar 10, 2014 | Kodak EASYSHARE 5300 All-In-One InkJet...
Problem With Kodak Colour Ink Cartridge I bought a Kodak colour ink cartridge as it was saying replace colour, l installed it but it was still saying "replace colour" I thought maybe the cartridge cou
the kodak system uses a countdown system that assumes you use a certain amount of ink re sheet regegardless of how much ink you accutualy use, the counter system starts everyt ime you turn the printer on, so the only way to extend the life of the ink is not to turn the printer off netween use, which the domestic useres do not of course do what i did throw the printer away and get a new one not Kodak sh*t
Mar 28, 2013 | Kodak Esp 3250 Allinone Multifunction ( ...
Have a Kodak all in one 5500...black cartridge went empty, replaced it with a non-Kodak cartridge, now it won't print black...changed back to real Kodak cartridge and problem remains....have cleaned...
I think the printhead is already defective since you tried using a non kodak ink the big difference is the viscosity of a non kodak ink is diff. w/ the original giving more load to the printhead and making it defective.
you can contact support at
1-800-421-6699
Dec 21, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Not printing in color and black/white copy not clear, light in some places
Dear sir
good day
to fix up such problem
Clean the printhead, then print and
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
  3. Close the printer access door, then make the same print.
and you can point to the website below for further information
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=5224/6198
thanks
Dec 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Wont except aftermarket printer cartridge error code "not recognized"
May be the cartridge is not detected by Kodak printer. Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges.The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 23, 2009 | Kodak ESP 5 Printer
Reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 16, 2009 | Kodak ESP 5 Printer
Won,t print
are all the drivers installed correctly? when you try printing off microsoft word (ctrl +p) try viewing the properties
good luck
Jayce
Feb 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
