Question about Refrigerators
I have a hotpoint fridge and it does this clicking noise which sounds like the compressor is trying to start up what could be causing this?
  • 828 Answers
This can be caused by a bad compressor.
Posted on May 30, 2008
Hotpoint fridge clicks before starting
You have a possible compressor relay going bad or something like low house power could cause that. Also the mother board could be going bad without seeing any problem. Electronic boards sometimes go bad without being able to actually see it. The compressor part of the board will sometimes burn a spot on the mother board but can only be see on the back solder side.
Apr 07, 2015 | Hotpoint Refrigerators
Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Nov 18, 2011 | Hotpoint Refrigerators
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 12, 2011 | Hotpoint Refrigerators
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
RLA Future Hotpoint Fridge
This may be caused by a fanmotor touching something, or one of the copper tubes from the compressor causing a resonant frequency. If you touch the different tubes to find out which one is causing the noise and then slightly bend it with your fingers. That should stop the noise.
Mar 13, 2009 | Hotpoint RLA30 Compact Refrigerator
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Clicking noise-GSH22JFR/SH200106
If you have a 5 year warranty, you should not take anything apart and consult the place where you got the appliance.
They should be able to tell you exactly what is covered under warranty before they work on it.
Feb 20, 2008 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint Frige
The main computer is bad. the small square panel axcess it. Had 2 do this same thing.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
