Question about Vacuums
Help please. I have small silver cylynder vacuum with retractable cable paper bag. i need replacement bags. Durabrand 1300
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632941
Generic problem for all Vacuums
Posted by louise10 on May 29, 2008
Help please. I have small silver cylinder vacuum with retractable cable paper bag. I need replacement bags. Durabrand 1300
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. When I did a Google and Durabrand.com search I found that the Durabrand is carried as a private label by WalMart and Target and upon my search found that most of the websites are saying that there are no parts or they do not provide a 1-800- phone # so that the average person can order bags and or parts. Suggest that you can search Google to see if you can find someone who carries parts for the Durabrand vacuum. It is probably a private label id which I spent over an hour looking for someone who would carry the vac bags for the vacuum you are requesting. Sorry I could not help you on this item.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 30, 2008
I just replaced the bag (used recommended Miele bag). When I turned on the machine the red "bag full" indicator comes on and the suction seems poor. I tried reinserting bag. ?
Good afternoon Kristen.
Vacuum cleaners usually pop the 'bag full' indicator when they lose suction due to the load of dirt in the bag impeding the motor pulling air through.
If you are still getting the indicator with a new bag, and already did the prudent re-seating of the bag, the next thing is likely a clog or blockage elsewhere in the vacuum. You don't specify the model, so I can't be too specific.
Safety first. Please please please make sure the unit is unplugged before you start disassembling.
As you are able, detach hoses, look in the back of the brush unit, see if there's a blockage. Wads of crumpled paper are particularly good at wedging themselves into corrugated flex lines. Depending on location, I've found that a wire coat hanger, bent into marshmallow-roaster configuration, with the old hook bent with some pliers into a long straight section with a small half-loop at the end, can be a good probe for the long sections of tube to see if it runs into anything, and then perhaps hook it and pull it out. Be careful if you do this to not hook the tubing walls and tear them.
Hoping this helps!
D
Nov 18, 2015 | Miele Vacuums
How do you change bag
Hi! Below are step-by-step instructions on how to change the bag on your vacuum. This vacuum takes a Dirt Devil Type D replacement bag. I have included a link to the instruction manual, as well as a link where you may go to purchase replacement bags for your vacuum.
1. To Remove: squeeze front panel release lever and pull towards you.
2. Grasp cardboard collar of paper bag with both hands and pull past raised locking tabs on the dirt tube. Dispose of old paper bag.
3. Important: Extend bag away from hole before installing. Press in opening to clear paper away from hole.
4. To Install: Push cardboard collar past raised locking tabs on the dirt tube with both hands. Be sure paper bag is fully extended and tucked in at the top and bottom.
5. Replace front panel by putting the two bottom tabs in the slots on the vacuum. Push front panel so release lever attaches.
http://bit.ly/1DEkilx
Type 3 Pack
Hope this helps!
Jun 01, 2014 | Dirt Devil Vacuums
Vacuum bags
It would help to know your postal code in order to to find a shop that caries bags for that model. Otherwise you can get them online such as amazon. Samsung Type VP-95 are the bags and should be readily available; also evirocare make a bag for them which is package #211.
Nov 12, 2013 | Samsung Easy 1300 Lightweight Compact...
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
I have an XL Silver Upright Vacuum with a docking Station. Bag will not stay on and dirt & dust builds up inside the Vacuum. Big mess to clean out. Also vacuum is hard to push. Is it because BAG...
The docking station is not on properly...Make sure that you have the outer (permanent) bag pushed down over the lip of the vacuum. The docking system needs to be behind the lip also. This keeps both the inner and outer bag firmly attached. If it is hard to push, you may look into replacing the roller brush. They start breaking down..kinda like a toothbrush. It will make it extremely hard to push.
Aug 30, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at chris.jones@govacuum.com if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
GoVacuum.com
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
This silver metal triangle shaped thing popped out
I think it's a spring that goes on the bag holder itself... You have to sort of pop the bag holder up from it's hinges and see a little tab stick on the bottom, in the middle, pointing sideways. There's a little groove that the spring is supposed to line up with on one side, and if it's not in that place you put the spring on backwards and have to turn it around the other way so the end lines up. Then snap the holder back in, and make sure the spring is pushing against the vacuum so when it's in place, the holder pushes the bag up towards the lid. The spring is to keep the bag pressed up to the air intake, and doesn't push down very much.
Jan 14, 2010 | Miele S318 Bagged Canister Vacuum
I need vacuum cleaner bags for a WST 1300
call a vacumn or small appliance repair shop most vacumn repair shops will know what bags you need esp if they service your model or may be able to tell you who to call
Dec 18, 2009 | Vacuums
How do I detach the cloth bag from my Kirby G3 Vaccuum to wash it
I would clean the bag by blowing it out with compressed air (lightly). If you do wash it, do it by hand in room temp water and air dry. I'm not too sure how to remove the whole bag on that model. You should call your local vacuum dealer to inquire, and ask the same question you asked here on Fixya.
Jun 17, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
97 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
