Question about Minolta Office Equipment & Supplies
Konica F-36-2 code on 7030. Removed the jam, but need to have the call service screen go away. Any ideas?
  • Minolta Master
  • 6,161 Answers
Sir/Mam,
First power off the machine. Then hold down the 2 and 5 button and turn on the machine. Hold down to you the 25 mode screen. Then touch Soft switch setting. The next screen you get your going to use the arrow buttons to put a 3 in the first box (LEFT) a 1 in the second box (middle) and change the 1 to a 0 in the third box. then touch exit power off the machine. If the code 36-2 comes back there is a problem with the Fusing Unit the hot part (sensor could have gone bad.). do not keep trying to reset. The machine is telling you its broke keep doing it could cause a lot more damage or start a fire. Get a technician out to look at it.
Posted on Jan 01, 2015
3 Suggested Answers
  • 48 Answers
SOURCE: f 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
Posted on Jun 02, 2009
  • 5370 Answers
SOURCE: This copier is used. I
To get the technical service manual.---------Please click the link mentioned below:---- http://www.scribd.com/doc/11162873/Konica7020702270257030703571307135sm --------------------- The error code F35-36 is related to fuser assembly error codes.In some cases removing and cleaning the fuser connections helped.In other cases the fuser has to be replaced.------------- --------------- There is also a reset procedure for this error code.In some cases it helped:--- ----------dip switch3----------
1:reset f34,f35,or f36fuser problems set to "1"to reset,then set back to 0.
----------- 1)9272 is the standard password. 2)To enter this password.Turn the machine on. 3)Then press and hold the star"*"key util the display says "please enter service password". Note:factory manual says"keep pressing" this might mean hold down or it might mean press repeatedly. 4) Now enter the password.Press9272 start "mode select-menu screen" will appear. 5) Press the mode you want this modes will show below-------[p ,25, 35, 36 , or 47]------ when finished press "normal mode"to return to standard screen use the number keys to change values press print key to check item press "stop/clear"when finished 6) You will have to select the mode 25. 7) Now to enter mode 25 there is a procedure. The procedure is as follows:-- 1) "25 mode" to enter this mode turn power off, press the 2and 5 keys and hold them down while they are held down turn on power . 2) When the power turns on --- you will see this options on menu .The options are as follows:--1.software switches.2.pm count.3. collecting. 3) You select the option 1 and that is software switches. 4) Once this option is selected you can select the dip switches.In that you have to select dip switch 3.Which is fuser reset code. 5) use up/down arrows keys to select dip switch. use up/down arrow keys to select to select bit number.To select "on" press number 1 .To select "off" press number "0". On will set bit, off will clear bit .Press "return"to return to menu listing dip-switches 6) Dip switch 3 ,bit 1 is the fuser reset command {for error codes f34,f35and f36}0 is no ,1 is yes to reset a fuser fault you enter this mode select dipswitch 3, select bit 1 and change "1"to "0"by pressing"off".---------------- Read this procedure carefully.Its not very easy.But once you do the reset and its successful then for next time it will not take much time to reset.In some cases the users have to try this procedure 7 to 8 times to get the reset done.Because in case if you skip any step then it will not get reset.Once if the any mistake is done then again start from step 1 again.-----------------This should help.Thanks.Helpmech.
Posted on Jan 11, 2011
What does code F52 mean
It seems that your drum is asking for a new one.
Jul 24, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
A konica 7030 displaying a meassage " remove paper from the exit tray" on the screen, how do i fix it? tnx
check if there is a paper at your exit feeder try. at the fuser.
if not. see if the paper sensors are not stuck.
Nov 15, 2011 | Office Equipment & Supplies
Gud day 2 u sir, am using konica 7030,Am having this code F26-3 pls what do i do? Thanks
F-26-3 means the machine was not recognize the devloper, try to reset, go to 36 mode (turn off machine press 3&6 buttons simultaneously, release 3&6 when the screen appears, select NO.1 HV, then search for L detection.. then start. if it wont work replace devleper then repeat the prcedure
Aug 15, 2010 | Konica Minolta DiALTA Di200 Copier
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7030 copier/printer - service codes
Are you sure it's not 34-2.I don't see or know of a 32-4 in my service manual.If it's a 34-2 write back and I'll reset it for you.
Jul 24, 2008 | Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica 7020 copier
what happens when u run L-detect. Make sure the sensor near the drum sep claws in the drum unit is clean. Any toner or setting powder on this semsor will give u errors while running L-detect.
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
224 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
