Question about Vacuums
Inoperable electrical wall socket - Vacuums
  • 377 Answers
The obvious would be a blown fuse or tripped circuit breaker. Go to your main fuse box and check for that. If you have a GFI outlet or circuit breaker, reset that. Some outlets protected by Ground Fault Interrupters are gang wired, so there may be another outlet in the room that has the GFI outlet that controls the outlet you are using. You may have to check for them. The GFI outlet usually has two small push buttons on it, one is TEST and the other is RESET.
If it is not easily fixed by those items, you will most likely need to pull the outlet from the wall box and see if you can trace it from there. First check these as they are the easiest fixes.
If you find my solution to be of help, I would appreciate a Thumbs Up from you. If my solution does not solve your problem, please contact me and we can go from there. Paul
Posted on Oct 08, 2010
  • pwillitz Oct 09, 2010
    I am sorry my efforts were of no help to you.
    Paul
  • pwillitz Oct 10, 2010
    Thank you very much for the time you took to provide me with such a great rating.
    I appreciate it.
    Paul
    Problem Solver:
  • 7 Answers
Is problem solved?
Posted on Oct 24, 2010
Central vacuum won't turn off when hose removed from wall socket
There is a switch somewhere close to where you plug in the hose. Check and see if the switch is stuck in the down position. If so, it will either need to be replaced or cleaned to allow the switch to raise to the off position.
Semper Fi,
Z
Aug 03, 2017 | Vacuums
How do i remove the power supply socket from the dyson wall mount
Hi Les, it's Jack at Dyson.
The end of the charger cord assembly which attaches to the machine itself is held in place securely by a friction-fit connection. You should be able to use something like a flat-bladed screwdriver to free the end of the charger cord from the docking station. Then with the docking station removed from the wall, you should be able to disconnect the charger cord completely from the rear of the dock, following the route shown in the image below:
I hope this helps - if you'd like any additional advice you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 04, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Electrolux mondo z1175 vacuum cleaner not working.
Do not get upset with me, but I must ask this question!!! 1) Did u try any other appliance in that outlet, or 2) Did you go back to the original outlet to see if the vacuum works there? It is kind of a coincidence that it quit working only after you moved it to another area. Let me know please!
Nov 15, 2014 | Vacuums
My cord has to be pushed in to socket and giggled to get the vacuum to have power? Any suggestions?
You might want to remove the electric plug from the wall and spread the prongs just a little bit, it sounds like the plug might be loose in the wall socket.....try it in another wall socket and see if the problem continues to exist...generally it you get the same result from similar wall sockets...you may have looseness in the electrical plug...meaning that you might have been unplugging the cord by grabbing the cord and snatching versus unplugging with the plug itself. Hope this helps.
Sep 25, 2013 | Electrolux Guardian Bagged Canister Vacuum
Hooked everything up per directions. I plugged it in to the closest electrical outlet and nothing happened. The lights did not light up, the connected wall control and sensors leds do not light up. It...
Dear Davehibshman,
Firstly; dismantle the plug and replace the fuse with the same rating as the one you have just taken out. Replace the plug cover, put the plug into the socket and try again. If this doesnt work, there may be a problem with the internal fuse (if one is fitted). Two choices here, either refer this unit to a qualified service personnel/ the place where you got it from, or do the job yourself (which will save you a whole bunch of cash). In your circumstances, I would take it back to the place you got it and ask them to put the fault right, or replace the unit completely; if it is past its warranty or guarantee time, then get back to me with a make and model number of the unit, and I will give you step-by-step instructions on how to solve this.
Yours sincerely
Oz
Feb 27, 2011 | Vacuums
Hello, I awoke this morning to a room full of acrid smell. The timer controlling an electric radiator was extremely hot,and was also heating up the wall socket. The heat has distorted the plastic case...
I am sorry that no one picked up on this sooner-
I came across it, after reading a response from one of th persons I helped--
Good Question: Who to alert?
By now you have probably called an electrician?-- Or at least stopped using both the receptacle, as well as the heater?- right?
Now-- to fix the problem:
It sounds like some poor connections at both the wall plug/socket end, as well as inside the heater-
First the wall socket:
Is the plug nice and tight, as you plug it in, and as you pull it out?-- If not-- the socket needs to be replaced--
Is the plug end of the cord hot in one spot, but not others?-- If so, there are some broken wires right near the plug end of the wire--- It needs to be replaced, too.
Now-- Inside the heater-- you mention the Thermostat area is real hot-- It sounds like either a loose wire, or a worn set of contacts on the thermostat.. (How old is the unit?)
So-- if you can narrow down the places, and repair-replace defective parts, maybe you can restore the heater to a safe, dependable source of heat-- If not-- It sounds like a recyclers needs to take over, and safely return parts to the environment!
Let us know how it all turned out, OK?
Mack B
Jan 26, 2011 | Vacuums
My dyson will not power up, it shorted out at the wall, socket sparked.
Common problem is a break in the wire where it enters machine, caused by accidently stepping on cable when using vacuum. You need to gain access and cut and discard about 3-4 inches from cable end and re-attach, a bit of a fiddly task but won't cost you much. Tools required: Torx 6 and a small crosshead screw driver, wire cutters/strippers, insulation tape. Basic electrical experience (if you can wire a plug correctly you can do this!)
Mar 15, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Model 116.1260
Need the complete model #, 116.1260*****. I assume this is a built-in system? Yes you have to plug the hose into the wall outlet, and there usually is a switch on the hose handle to turn it on.
Jul 23, 2008 | Vacuums
Vacuums Logo
87 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
