Question about Craftsman Garden
After lots of excellent service suddenlymy craftsman rorotiiler Model # 917 2960230 is auddenly belching white smoke and oil out of the exhaust It starts with the choke on and tries to run when the choke goes off but dies. It will not runor start. What is wron? And what can I do?
  • len_olds Oct 08, 2010
    Sabin, I'm not sure but less than five years. Cm't you ytell from the Model #? I ertainly hope it is not the oil ring.
  • 2,299 Answers
What has happened the oil ring on the piston broke. When you break a ring chances are that you can put a new ring on and the tiller will be good as new. The ring is what produces compression. With no compression the engine will not run. The white smoke is from burning oil. It don't cost very much to have a new ring put in. Or you can go to Lowe's or Home Depot and get the parts and a manual to rebuild it yourself.
Posted on Oct 09, 2010
  • 712 Answers
How old is it?
Posted on Oct 08, 2010
My brand new Honda 25cc 4-cycle Mini Tiller, belches out lots of white smoke. Is this normal
If it is a four cycle and no oil mixture required..sometimes new ones will smoke at startup due to oil residue during manufacturing but only a short while..and maybe a little longer fir the rings to break in..but normally not very long..One thing could cause this is too much oil in the crank case..it will build up internal pressure due to the limited block space..and cause the excess oil passed the Pistons and into the firing chamber..check your oil..also pull the plug and see what it looks like.. Burning oil and gas mixture will give a black wet look on the plug ends..if so you definatly are burning oil.if the oil is ok ..give it a couple more tries if it continues..it is back to the dealer and warenty..Hope this helped good luck.
Sep 25, 2014 | Garden
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
What caused 19 horse Kohler to belch white smoke
white smoke fuel blue black white smoke oil over fill oil will cause it getting to much fuel will cause it check carberator check oil
Sep 02, 2014 | Cub Cadet Garden
My pulsar 150,2008 model is not giving good milage. its only 30km/l. what to do ?
Smoke means the gas does not burn excellently because of 1) piston and piston ring worn out or 2) there is a damage oil seal inside the crank case thus the leaking motor oil mix with the gasoline and produces smoke when you roll the bike. Clutch plate, timing chain do not have to do with smoke belching bike for sure because these are mechanical parts not combustion.
Jan 30, 2014 | Bajaj Motorcycles
White smoke belching out but will not start
white smoke is usually water, grey=oil dark grey=other fluids. with the belching and other symptoms i would be inclined to believe you have a blown head gasket.
Nov 15, 2011 | Cars & Trucks
Excessive exhaust smoke
i suspect you are leaking coolant into the combustion chamber, it may be a head gasket, get it checked
Jul 17, 2010 | 2004 Toyota Camry
My Toyota Corolla XL 1996 model is belching heavy white smoke. I have just changed the oil and also the spark plug. What do you think is the problem?
white smoke usually indicates the engine is burning oil or its burning coolant. when the engine is cold remove the radiator cap and start the vehicle, if it immediately begins to blow air and or coolant from the radiator you most likely have a blown head gasket, if not then remove the oil cap and feel for air coming out. if it blows kinda like a hair dryer then you most likely have a piston ring issue and you are burning oil. either way you may be looking at major surgery to repair.
Dec 10, 2009 | 1996 Toyota Corolla
Smoke and sparks from my exhaust
Well 1st you need to check and make sure you have enough oil in the engine
suspect valve cover gasket leaking oil
check for oil leak
Nov 10, 2008 | 2000 Ford Focus
Garden Logo
168 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
