Question about E-Machines Computers & Internet
I have a E-machine t2240. The video output has stopped working. I have connected a known good monitor ands still there is no image. Help! wwood37@hotmail.com
  • Sameer Kashyap May 11, 2010
    any beeps or sound signal that you can hear ?
    Problem Solver:
  • 19 Answers
If you are positive that your monitor is good, the cable is connected properly and everything is powered up and in working order, you may only have a blown onboard video card. If you have a free PCI slot available (I think it normally has only two free PCI slots) I would try to find borrow a used PCI video card to see if that will work before wasting any good mony on a new one. You would have to disable the built in video from the BIOS, but it would be worth a try if you can find someone with an old PCI video card willing to let you try it out. Given the age of the system, don't waste too much money taking it to a repair shop though as you can spend half the cost of just buying a newer and more capable new computer very quickly.
Good Luck
Posted on May 30, 2008
MONITOR IS BLACK, POWER LITE IS ON, I CAN HEAR COMPUTER SOUNDS
By computer sounds do you mean the sound of fans and hard drives spinning? If there are no loud distinct beeps indicating a startup error (See Post Beep Codes), then I would check the following.
I'm assuming you mean the power light on the monitor is on. If that is the case then it is one of two things.
  1. The monitor is not set to the correct input source.
    • Make sure you go through the monitors menu and select the input. Example
  2. The video cable to the monitor has a bad connection.
    • Make sure the cable is connected properly
    • If repositioning the cable differently restores the image than the cable is most likely failing. Try replacing the cable with known good one.
    • If the cable is good it could be a problem in the jack on the monitor or the computer.
      To repair this would require disassembling the monitor or computer and replacing the jack.
      However, most computers and monitor have more than one type video input/output. Try the other input/output jacks. Example
Nov 16, 2013 | Impression Products Impression 9LSP 19"...
No screen image
Test with known good monitor. Consult a nerd at this point. They can diagnose things quickly. Its usually more obvious then you think.
If still no image, replace video card. You can buy a replacement online. Most likely you have something else going on. For example, You usually hear beeps from a PC if it is doesn't pass post testing during startup. This could also cause no video output. You would need to check PC memory and power supply as those two can cause many performance problems.
Oct 10, 2013 | Westinghouse Electric L1916HW 19" Monitor
Hi, I have a sony vaio vpcej3t1e laptop. Suddenly the screen went dark. The images on the screen could be hardly seen. I opened the screen, removed the connector and replaced it again. The screen now...
Connect a known working monitor to the the video output terminal of laptop. If that works then your screen is bogus. If it does not work then the laptop video circuits have an issue.
Apr 09, 2017 | Computers & Internet
I have a hp 2009m monitor and it keeps telling me to check video cable.
Possible causes:
1. Bad cable. Use another video cable that you know is good and test with it.
2. Input source on monitor incorrect. Check to make sure you've got it set to the correct input (VGA or HDMI)
3. Unplug/replug the video cable connections at both the monitor and computer...it could be just corrosion or dust.
4. Hook up the monitor to another computer that you know is working. If your monitor then works, then you know that the video output on your computer has failed. You can also test this situation by connecting a known good monitor w/known good cable to your computer to see if you get video.
Hope that's helpful.
Jan 12, 2011 | HP 2009M Monitor
The computer was in use when the display cut out. The monitor is fine and the computer turns on but has no display on the monitor
I presume that you tried the monitor on another system to verify function. Try restart after 2 min power down and disconnect and try again, then take another "known good" monitor and try that. If both monitors give no image, video output is suspect. Many motherboards have the video output as part of the board itself, cost prohibitive to replace motherboard.
Sometimes you can plug in a PCI video card and bypass system video.
Oct 01, 2010 | Gateway GT5622 PC Desktop
Monitor switches on. shows screen for about 5
Make sure your computer is working properly. Hook up another known working monitor up to the computer and turn it on. If you get video on the known good monitor then that means the original monitor is bad. If you don't get video on the know good working monitor then that means the computer has no video output and the computer would need to be troubleshooted.
Nov 30, 2009 | HP Compaq FP5315 15" LCD Monitor
I'm getting no video
Try a "known-good" monitor with your computer.
If no output, then your computer's video-card is suspect.
Try your monitor connected to another desktop/laptop.
If no output, then your monitor is the problem.
Sep 14, 2009 | PC Chips P53G v1.0 Motherboard
Computer monitor turns on but no image appears.
1. When you boot the computer keep pressed 'F' & 'J'. the display should appear if there is no hard to your hardwares.
2. If you still not get the images on monitor try to unplug and plug back in the monitor's data cord.
3. If you still do not get success then you must need to open the computer tower and see if the RAM is not loose from the slot and processor is not loose from its slot.
Once these settings are perfect nothing can stop you getting from the proper display until and unless you monitor is damaged.
Best of luck!
Sep 14, 2009 | Compaq fs740 17" CRT Monitor
Monitor power save on, says to activate with pc, key board knot w
try to check Video cable connected tightly or not ..if connected right then the video card on the motherboard having the problem ... try to contact the motherboard service center for replacement..
thank you ..
Apr 26, 2009 | E-Machines T2240 CELERON 2.2 GHz 128 MB 80...
Monitor is acting up been using for about 3 years
The problem is most likely caused by one of two things. Either your monitor has a defect or the video output of your computer is defective. The problem can be isolated by connecting your monitor to another computer that you know is working properly. If the problem occurs on the known good computer then you know the monitor is the problem. Just to be sure connect a known good monitor to your computer If the problem occurs when you have a good known monitor connected to your computer then you know the problem is with your computer and not the monitor.
Please let us know if this answers your question.
Harleyknut
Apr 06, 2009 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
