Question about Acer Aspire 3810 Notebook
My battery on ACER Aspire 3810T doesn't look to be charging or working at all. How to rectify the problem?
5 Suggested Answers
legna
  • 53 Answers
SOURCE: acer aspire 3000 doesn't charge
Harvester3 makes a point here most likely the battery is gone, don't worry it happens quite often batteries have a life time and they need to be replaced. Good luck!
Posted on Aug 30, 2007
  • 7 Answers
SOURCE: Acer Aspire won't power on with fully charged 9 cell battery!
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
  • 253 Answers
SOURCE: Acer Aspire 1 only runs on mains - although battery is charged
batteries should be conditioned before normal use by ensuring they are charged and then fully discharged for the first 3 to 4 charge cycles.
and for our technician help contact us at 18884276640
Posted on Jun 23, 2009
SOURCE: Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Posted on Nov 23, 2009
My battery will not charge. Have tried different batteries and chargers. Works fine on mains power. Any ideas please? Roger
sounds like to me you have a bad connection in the battery terminals. try cleaning the contacts with a Emery stick.
Nov 08, 2014 | Acer Aspire 3810T 4810T 5810T
I bought a new acer aspire 5630 laptp battery but it is not working when fits into, whereas when I put it on the old battery it works on the power as the old battery is fully exhausted. Someone told me to...
What I believe they were mentioning is Flash the BIOS to the most current version, which should on the Acer support site (Support.acer.com or such)
If the old battery wasn't charging and the new one doesn't either then there also may be a hardware issue with the charging circuit if the BIOS flash doesn't resolve, at which time you discuss that issue with Acer if under warranty.
Jun 23, 2011 | Acer Aspire 5630 Notebook
BATTERY DOESN'T CHARGE ON MY ACER ASPIRE ONE MOD#KAV60
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
May 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a newly bought Acer Aspire 3810T. When I opened it last night I saw a green vertical line, and until now this green line still appears. Can you please help me?
"....a newly bought Acer Aspire 3810T...." It's NEW.. why mess around with it.
Read the manual that came with it. If the green line means somthing, it will be in the manual or Quick Sart guide. If not, it's defective and should be returned for exchange or repair.. under warranty.
Save any personal info to a cd first.
Jan 15, 2011 | Computers & Internet
My ACER Aspire 3810-TG battrey is not charging (the message on Windows 7 Energy settings screen - 85% available (battery plugged, no charging)
A BIOS update can resolve this issue and allow the battery to charge up to 100% in Windows. The BIOS update can be performed either before or after the symptom appears
You can Get the latest BIOS from
http://gd.panam.acer.com/
Dec 04, 2010 | Acer Computers & Internet
Bluetooth not working on acer aspire 5738
Hi tallyman,
you lost bet ...when it has a bluetooth switch it will have a hardware installed.
Best solution is got is a simple call to acer service support,the problem very very simple in 5738 machines they installed foxcom bluetooth device a very much updated version.But the drives in your cd will be broadcom drivers install aspire 3810T model bluetooth drivers.
regards
Ar.Praveen(Architect)
ardesarchitects@yahoo.co.in
Oct 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Aspire 3810 Notebook Logo
374 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
