Question about Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250
I have an older stihl 028. The saw starts and idles nice. As soon as you throttle up or put it under load, it bogs out, It also seems a little smokier, Can ya help? I cleaned the carb and jets and exhaust screen.???
    Problem Solver:
  • 6 Answers
First check your fuel filter. Its on the end of the pick up tube in the fuel tank. Could be clogged. this is a relatively easy and inexpensive place to start. Make sure the fuel supply isnt pinched anywhere along the way.
Could be a scored cylinder. A scored cylinder is common problem with all makes of chainsaws. If you dont take special care to keep the air filter clean and in perfect working condition, the wood chips and dust will enter the combustion chamber and score the cylinder walls, ruining the rings causing a loss of compression.
The piston could also have been damaged from running to lean of fuel to air mixture causing heat damage to the piston and cylinder.
Hope this was helpful. If so, gimme a thumbs up vote!
Thank You
Posted on Feb 01, 2011
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Carbsettings
Both the high an low speed circuits should be at about 1.5 turns out from seated. Gently screw them in until they seat, then turn them back out 1.5 times. This should be close to the factory setting, but will likely need to be refined a bit from there. Start the saw and let it run for a few minutes. Adjust the low speed circuit at idle until it runs smoothly, then rev the motor to full throttle and slowly turn the screw out until it starts to run a little rough, then turn it back in until it clears up, usually about an eighth of a turn. If it still doesn't run right, it may need a carb cleaning and rebuild, or other work. Good luck.
Jul 01, 2014 | Stihl Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
I have a stihl 044, older saw and its not running properly. When I try to start it with the full chock, I get fuel ranning out of the muffler every time I try to start it. I take off the air filter and...
I would say it is flooding, you realy need to pressure test the carb to check the seating of the inlet needle, a simple bulb tester is all you need, connect it to the fuel inlet on the carb ( where the fuel hose is connected ), pump approx 2/3 psi into the carb, it should hold this steady with no leak, any leaks then you will have to fit a new inlet needle, let us know how the test goes.
Apr 05, 2011 | Stihl Chain Saw Handle Models 044 046...
Engine bogs when throttling
Jamie it sounds as though you have a fuel delivery problem. What little fuel system there is can be found here: (click "Go")
On the "Handle, Chassis and Bar Assembly" drawing.
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-1/75.2375LE-Gas-Saw-Type-1.1.59.1.html
This can be caused by a dirty or loose carburetor, cracked fuel lines, dirty air filter, plugged fuel filter, old fuel mix, and a few more things that aren't coming to mind.
If you attempt a repair take extensive notes and some digital pictures as things progress.
You can get it tuned up for about $40 at a good saw shop (Stihl, Husky, Etc), They do an inspection, change the plug, and adjust the carburetor. Explain your symptoms, ask for an estimate to repair & perform a tune up. If you do this (recommended) ask what oil/fuel ratio they used. Use the same ratio until the next time you have it tuned again. HTH
Lou
Sep 30, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250 Logo
642 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
