Question about LG Computers & Internet
When I turn the system on it goes black after 5 seconds .to again see the picture I have to restart the monitor but still the same problem.
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 08, 2010
Garfunkel01
  • 56 Answers
SOURCE: HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Posted on Aug 15, 2007
  • 1684 Answers
SOURCE: Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Posted on Jul 24, 2009
  • 23 Answers
SOURCE: Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Posted on Aug 14, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
  • 979 Answers
SOURCE: When I turn on my
Hello sir, does your PC boots normally? The symptoms you describe also applies to a bad CPU. If you see the monitor brand or logo flash on screen, the monitor is good. check your CPU memory, try cleaning the memory modules, this requires you to remove the memory clean the terminals and replace it back again. If this does not work, I need more info. describe the behavior of your PC. beeps sounds lights, keyboard lights. etc.
Posted on Oct 27, 2010
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
No screen after 5 minutes
The picture board on your monitor is bad, since it goes off after few minutes and the power led or button is on, it means the picture board of your monitor has developed fault.
I would advice you replace the picture board on the monitor, this should cost you between $65 - $85.
Take care.
Jul 06, 2010 | Soyo DYLM2286 Monitor
I have a Philips 170S4. On startup it displays the memory check fine. Then everything goes black, the green light indicating the monitor is still on is still lit up. I can only JUST see some pictures on...
did you adjust the brightness, also in windows settings?
pls check with another monitor ,also you can check monitor with another pc or laptop
try with reset the monitor settings
also change the resolution and display frequency
Oct 03, 2017 | Gateway FPD2275W LCD Monitor
I have a VP201m. display flashes at startup and goes black
That's not monitor problem, it's your CPU, probably the Operating System crash!!!( Windows,etc).
Try reinstall it to solve the problem...
Oct 18, 2009 | Computers & Internet
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
Computers & Internet Logo
64 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
