Question about BenQ FP737S-D 17" LCD Monitor
How to troubleshoot my my benq t52wa that shows no signal detected
  • 11,361 Answers
Since you did not indicate what you have done so far, I would suggest the following:
First thing to do is to find out it ias not PC vdieo card problem, try this monitor with other PC and this PC with another monitor to narrow down the problem. Please post back what you found.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 08, 2010
    President:
  • 2,992 Answers
If the monitor is showing you a "no signal" message, it's almost certainly working fine. There's no video coming in from the computer, and that's likely where the problem is. Try another monitor first. It's possible yours isn't recognizing the input signal, but it's unlikely. I've only seen that happen twice I can remember. Chances are that another monitor will say "no signal" as well. Either the computer isn't starting up, or the video isn't working.
If you hear all the sounds of a normal startup (usually a single beep when the motherboard finishes power-on tests, hard drive activity shown by the front panel indicator, and finally the Windows startup sound through your speakers), then the video circuitry is bad. If the video is integrated onto the motherboard, you can install a replacement video card in an open expansion slot. If you already have a separate video card you can replace it.
If the computer isn't starting, you need to suspect memory, the motherboard, power supply or processor. You might also have a bad hard drive, optical drive or other device connected which is preventing startup. Begin by unplugging everything except the main parts: memory, processor and fan, power supply and (if used) video card. If the system starts up, you can identify the bad part by reconnecting them one at a time until the problem comes back. If the system still doesn't start with the minimum hardware, part substitution is how you'll figure out which is responsible.
It can be frustrating, but you'll get the thing going. Good luck, and thanks for using Fixya!
My monitor keeps opening monitor menu and keeps auto adjusting
As you have already used a cleaner spray, this is a sign that the monitor is on its' way out. I had one that went the same way.
Apr 13, 2013 | Computers & Internet
Pls help me to make a 1024x768 for my BENQ T52WA lcd monitor. can provide a driver for this.
Need more information. What graphics card are you using and what operating system? Is the monitor connected via DVI or VGA?
If 1024x768 is not showing up as an option when settings the resolution, try updating your graphics card driver.
Mar 04, 2011 | Computers & Internet
Benq T52WA LCD MONITOR SMPS OUTPUT VOLTAGES?
Hi
My Benq t52wa wide screen monitor works fine for some time and then its goes off for a few seconds and then comes back in regular intervels. This keeps on happening. Also im unable to get the auto adjusting thing that comes on the screen to go off. IT keeps adjusting.
I checked for the drivers and it says all drivers are up to date. Any suggestions please?
Feb 13, 2011 | BenQ FP553 (White) 15" LCD Monitor
I'm trying to set up BenQ FP71G+ as a second monitor connecting to Nvidia GeForce 8800 GT. I cannot get the BenQ to display even if it is the only monitor connected. However, I can see the BenQ in...
I have had problems occasionally with connecting a second monitor, too. Hook up both monitors. In the Windows control panel, look up display (or right click on your desktop and select display). Is the second monitor shown? If not, click "detect" and see if it shows up. I have had a couple times where I clicked on the monitor icon in "display" and then clicked "enable this monitor" and it started working. If not, then try switching the cords so your working monitor is the second one. try again and see if it show up. If not, the problem is probably with the video card or video card driver. Try and update the driver for your card.https://www.geforce.com/hardware/desktop-gpus/geforce-8800-gt
If this does not work, the issue is probably the card.
Feb 09, 2018 | BenQ FP71G 17" LCD Monitor
Benq 19' LCD Screen 3 yrs old- no signal detected on brand new PC
Have a look at the back of your computer.
See if there is more than 1 video port.
If there are 2 ports try plugging the monitor into the other port....
Sometimes motherboards have internal video cards, in this case the video port is in among the USB ports, sound and mike sockets etc.
Look for a video port away from all those other things.
Apr 26, 2009 | BenQ FP71E 17" LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
284 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
