Question about Xerox XA7-17i 17" LCD Monitor
No response although light is on showing PSU is working
  • 11,361 Answers
You can still ahev the backlight power supply problem because the 5vdc powwer supply for the logic board may be working but not the 12vdc section, or problem in the inverter circuits, lamps, etc.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 08, 2010
Power supply not powering on
mine 2 psu running doesn't. false where knowing won't am i?
Aug 08, 2012 | HP Compaq 6000 Pro Microtower PC (NV504UT)...
RVS10 only show blue light. not starting
the blue light on means the light is getting power
test your PSU power supply unit if the psu units fan is not working the psu is faulty
check the leads from motherboard to hard drive EIDE/SATA make sure connections are secure and dust free
if its a flat 40 pin ribbon type this will be the first to fail
also make sure your cd/dvd drives are working even something as small as a faulty electrical fan lead can cause this problem
make sure your ram modules and cmos battery are securely seated with nod dust in the sockets although on some motherboards th cmos battery is soldered in
a computer needs power and data to travel through every working device and to have an end point to work
hope this helps you
Sep 21, 2011 | Computers & Internet
My pc was working properly when I turned it off. Upon returning I powered up my pc (HP 805n) but it will not turn on. The green light in the back of the pc is steady, but no response. I've own the pc...
to trouble shoot,
open case and disconnect all cables except power supply.
if the computer starts up okay, then shut down and connect the cd-rom then startup. if that's okay then connect any other cables . if any one of the parts are defective you will find the stinker.
if the computer still won't go, try another power supply/
if that's okay, then the board might be bad
Aug 03, 2017 | HP Pavilion a805n (PS519AA) PC Desktop
If pluged into light not powering at all
Firstly insert the battery. When you plug the PSU into the machine does a charging light turn on? If not then check the fuse in the mains plug as it may have blown. If the fuse is OK then you may have a defective PSU, although the motherboard could also be defective. Try a new PSU to determine if which component is faulty. <br /> Now remove the battery and insert the PSU. Will the machine turn on or do any power lights illuminate? If power lights illuminate and the machine will not turn on then I would suggest the motherboard is at fault. If the machine turns on briefly the turns off before displaying the splash screen then I would suggest the RAM, CPU or motherboard is at fault.<br /> If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit on the motherboard is fried.<br /> Hope this helps,<br /> www.PuterCare.com<br />
Aug 30, 2010 | Dell Latitude D600 Notebook
Power supply unit gets power as light on the back shows but pc wont turn on. Have tried differnt PSU and pc turned on but have had unit checked and they said the PSU is working fine. Cant fit standard PSU...
Try this to get it at-least back on with your PSU that fits in the case. open up your computer case, locate your power supply. With the AC cord still plugged in , unplugged the connectors to your motherboard from the PSU and wait about 10secs. Then replugged them in. This should power on your PC.
Also, You wanna check around where the PSU connects to the motherboard and make sure there is no damage. No burning,Discoloration anything that could be potential damage.
Hope this works atleast to get the PC booting up.
Jul 28, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Why when i switch my hp 6720s on does the battery light flash amber then goes white nd the laptop switches off? all in 5 seconds
It sounds as if the battery is too low to power the unit on.
If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit n the motherboard is fried.
Hope this helps,
www.PuterCare.com
Jul 04, 2010 | HP Compaq 6720s Notebook
My Acer Aspire One model D250 cannot power on even if i already put the power adapter.Is it the battery pack problem or the motherboard?
Hope this helps,
www.PuterCare.com
Jul 03, 2010 | Computers & Internet
Fujitsu Siemens Scaleo 600. No power to processor.
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Oct 06, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Display problems at Boot Up (Windows PC)
my problem hp 530 notebook lcd light problem ..inverter flex no problem systemboard problem yes
Dec 18, 2008 | Gateway 7330GZ Notebook
Upgrading power supply
The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
Get an OEM PSU from Compaq(HP).
Dec 02, 2007 | Compaq (253219-002) Motherboard
Xerox XA7-17i 17" LCD Monitor Logo
77 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
