Question about Garmin StreetPilot C330 GPS Receiver
Voice prompts After about 18 months the voice prompts went silent. Seems to be a volume control problem, as If I hold the unit in my hand and apply thumb pressure to the back of the volume control wheel the sound comes back, until I release the pressure again. Can I get the volume control replaced for less than the cost of a new navigator?!
  • 1,689 Answers
Most likely there is a cold solder connection at the contacts of the volume control, or there is a break on the circuit board and you are pushing pressure to join the break, or there are other types of cold solder connections, or the volume control itself is defective.
Jerry G.
Posted on Jun 03, 2008
Clarion vx 401 voice prompt on Nabi was working,
You may have to re-select voice prompts.
Dec 15, 2017 | GPS
Sound does not work on Garmin Street Pilot GPS
is sound enabled in the settings? I will get you instructions if you provide me with your model.
also you could try reseting the device, there is a reset hole or button. Model would help.
Oct 23, 2008 | Garmin GPS
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
on Jul 09, 2010 | Samsung SCH-U450 Cell Phone
Nuvi stopped talking. where is the mute button located on the unit?
If you are no longer getting the voice guidance from your gps, then you need to check if the volume is on the highest or lowest. There is no mute button on the gps, it is when the volume is at the lowest it seems muted. Ensure the volume is turned up by adjusting the scroll whell that is by the right hand side of the unit.
If that does not help, then you check the language settings in the unit. Verify that the voice is enabled, by following these steps:
  1. from the 'where to? view map' screen, touch 'tools',
  2. Touch 'language',
  3. Next to 'voice language' you will see 'jill' listed in the blue box on the right (if so the unit should be ready to use)
  4. If you do not see a 'voice' listed in the blue box, touch on the blue box,
  5. Select 'voice',
  6. Touch 'ok' at the bottom,
That should do the work for you.
Dec 23, 2010 | Garmin nuvi 205W GPS Receiver
I do not have any voice but do have picture. Volume is turned up.
If you are not receiving any sound on your nuvi 200 or 205 series device the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the 'Where To?', 'View Map' screen
  3. Ensure the Mute box is not 'checked'
If the mute button is not 'ticked', you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Sep 23, 2010 | Garmin nuvi 200W GPS Receiver
No voice prompts on my new nuvi 750- volume level not muted.
I had the same problem after I had my Nuvi 750 for a few months.  The voice just stopped.  I called Garmin and they replaced it under warranty.
Feb 11, 2009 | Garmin nuvi 750 GPS Receiver
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Dec 14, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
My Nuvi 360 volume for the voice prompts is too low, even on the highest setting. I also have a Nuvi 200, and the volume is fine on that unit. But if I get a phone call on my 360, the volume is OK. Is...
It is possible to turn up the voice level...but you have to be willing to hack the voice file a wee bit with a hex editor.
Just Open the .vpm file you want to modify in the hex editor, and search for "<voice_volume>96</voice_volume>" without the quotation marks...and change the numerical value - I have Australian Karen cranked up to 96. This makes the sound level of the voice prompts comparable to the MP3 level when I hook my Nuvi350 into my vehicle's sound system via the added line input that takes the place of the non-existent CD changer. Before I did this, when I played MP3s at a comfotable listening level, the voice prompts were too quiet. Now, they're comparable.
May 21, 2008 | GPS
I can't seem to enable to voice prompts
Taken from the Garmin website:
"This error is most likely caused because the voice files need to be reloaded onto the iQue. Insert the iQue setup disk and select 'Install Software'. Then select 'Change voice'. Then select the voice to be installed on the device. When the voice files are finished installing, perform a Hotsync. The voice guidance files will then be restored to the unit and the voice prompts should work correctly."
Feb 26, 2008 | Garmin iQue 3600 GPS Receiver
If you lost "all" sound - click the speaker icon (bottom of screen) and make sure all volume is turned up. If you lost just the voice prompt for turns etc. This happens when you have an extended period of low battery. You need to reinstall the setup CD for the iQue 3600 go through the motions and HotSync the unit - This will reload your voice files.. Jerry ...
Aug 15, 2007 | Garmin iQue 3600 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
134 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
