Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Console removal How to remove the console on model number LSQ9549LW2?
  • WeyBug May 30, 2008
    Thanks. Most postings talk about screws on the front or removing the endcaps to find the screws. I see the screws you are talking about.
THER ARE SEVERAL DIFFERENT WAY TO GET INTO ANY WP OR KENMORE TOP LOAD WM ON THIS MODEL LOOK AT THE BACK OF THE CONSOLE YOU WILL SEE A PHILIP SCREW ENBEDDED AT A 45 DEGREE ANGLE ON THE FAR RIGHT AND LEFT HAND SIDE USE A SCREW DRIVER NOT A DRILLBIT TO REMOVE THOSE 2 SCREWS THEN LEFT UP AND FORWARD ON THE FRONT OF THE CONSOLE
Posted on May 29, 2008
How do you remove the lower center console on a 2000 Olds Intrique
Item Part Number Description 1 060024 Floor console armrest 2 06010 Floor console storage bin 3 04338D Floor console finish panel (front) 4 044D90 Floor console finish panel (center) 5 - Floor console cup holder screws (2 required) 6 13562 Floor console cup holder 7 - Floor console front screws (2 required) 8 - Floor console rear screws (3 required) 9 - Floor console nut 10 045A36 Floor console Removal and Installation
  1. Position the seats as needed to remove the console.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console storage bin.
    1. Remove the 3 screws and the armrest.
    1. Remove the floor console storage bin screw.
    1. Remove the pin-type retainer.
    • Disonnect the electrical connectors.
  1. Remove the floor console front finish panel.
    • Pull upward from the front of the trim panel to release the retainers.
    • Disconnect the electrical connectors.
  1. Remove the floor console center finish panel.
  1. If necessary, remove the 2 screws and the floor console cup holder.
  1. Remove the 2 floor console front screws.
  1. Remove the 3 floor console rear screws.
    • To install, tighten to 4 Nm (35 lb-in).
  1. NOTE: Lift the console from the rear and slide it rearward to release the rear seat heater ducts from the instrument panel. Remove the nut and the floor console.
    • Disconnect the electrical connector.
    • To install, tighten to 8 Nm (71 lb-in ).
  1. To install, reverse the removal procedure.
Jun 10, 2015 | 2000 Oldsmobile Intrigue
Removing heater core
This is for a 2.3L
Hope this helps, it it does please leave feedback Thank You and Good Luck
REMOVAL
  1. Disconnect battery ground cable.
  2. Drain cooling system.
  3. Raise and support vehicle.
  4. Disconnect heater hoses from heater core assembly.
  5. Remove drain tube.
  6. Lower vehicle.
  7. If equipped, remove console as follows:
    1. Apply parking brake and block drive wheels.
    2. Position transaxle shift lever in Neutral.
    3. On models with automatic transaxle, remove clip retaining shift lever handle to lever, then remove shift lever handle.
    4. On models with manual transaxle, turn shift lever handle counterclockwise to remove from lever.
    5. On all models, carefully pry upward on outer edges of console trim plate.
    6. Disconnect electrical connectors and ashtray lamp from console trim plate, then remove trim plate from console.
    7. Remove console to mounting bracket attaching screws, then remove console.
  1. Right and left sound insulators.
  2. Steering column opening filler.
Floor Air Duct Outlet 58917672
  1. Floor air outlet duct.
  2. Heater core cover.
  3. Heater core mounting clamps and remove heater core.
INSTALLATION
  1. Heater core and heater core mounting clamps.
  3. Floor air outlet duct.
  4. Right and left sound insulators.
  5. Console.
  6. Steering column opening filler.
  7. Raise vehicle.
  8. Heater hoses to heater core.
  9. Drain tube to heater case.
  10. Lower vehicle.
  11. Negative battery cable.
  12. Fill cooling system and check for leaks.
Jan 01, 2011 | 1994 Pontiac Grand Am
Kenmore 20712 goes trough the first cycle OK but when it comes to draining and spin cycle it stops.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts. (20712 is a stock number for a number of products, you'll need the full model number that starts with 110. )
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Oct 12, 2010 | Kenmore 20172 Top Load Washer
How can I replace a lid switch
Then see the following for how to release the console and remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=f49470e9067a2e9069fb3de3c0833ad6
Some models don't have removable end caps on the console. These usually have spring clips under the ends of the console that will release if you slip a thin putty knife between the console and cabinet.
With the cabinet off, you should be able to locate the lid switch and replace it.
Jul 17, 2010 | Kenmore Washing Machines
How do I remove the top piece to replace the timer. They are made of plastic and I can't get them off feels like they snap into place.
If the model number you have this listed under is correct, I believe there is a screw on the back side of the console on each side that you need to remove. With the screws removed, the console will pull towards you (as you are standing in front of the washer) then lift up to access the inside.
If there are no screws in the back, then the console will have a retaining clip under each side. To release, you need to insert a putty knife under the console along the front corner of each side and push straight in while lifting up to release.
If you have questions, or if the model number is different, please post back with the correct information so that I may provide you with better assistance. I hope this helps you.
Sep 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i remove back
Without the model number of your washer I will not be able to provide specific instructions. It's likely the back panel is not designed to come off.The washer cabinet will most likely have to be removed. Since I do not have the model number I added the instructions how to remove the cabinet. However, there are two different methods of attaching the console to the top. One way will have a screw located at the bottom of console end cap to remove, the other way has hidden screws and you will have to remove the end cap trim like shown in image 2 and 3. After removing the screws follow the instructions in image one. If this is not you type of washer; resubmit your question with the model number.
Resubmit your question with the model number and details of the symptom for model specific instructions and trouble shooting tips.
    Aug 05, 2009 | Zanussi Washing Machines
    I need disassembly instructions for a Kenmore Automatic Washer model number 110.24942300. I am trying to help a neighbor correct an internal water leak and I don't want to destroy any fasteners if...
    HI. thanks for the question. the cabinet comes off. to remove. 2 screws on each corner, of the console. remove. lift console. 2 brass clips . remove them. disconnect lid switch harness. remove the cabinet. look for the leak. thanks the appliance doc. please rate my answer.
    Oct 07, 2008 | Electrolux Washing Machines
    Remove console
    The console can be removed in a few different ways depending on your model number:
    1. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
    2. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
    3. Some consoles have screws in the back that require removing before the entire panel will slide forward, then lift back.
    Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
    You should post back with your COMPLETE model number (located on a nameplate under along the wash tub opening under the lid) if you ruin into any difficulties. I hope this helps you.
    PS Is there a reason why you are removing the console?
    Aug 07, 2008 | Kenmore 24032\24036 Top Load Washer
    Older Style Top Loader Washing Machines
    if the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
    Aug 06, 2008 | Kenmore 24032\24036 Top Load Washer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    105 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
