3.0L DOHC Engine
Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines
3.0L OHV Engine
Fig. Exploded view of the water hose connection and the thermostat assembly-3.0L OHV engines
Fig. Remove the upper radiator hose from the water outlet
Fig. Remove the water outlet retaining bolts and . . .
Fig. . . . remove the outlet from the engine
Fig. Remove the thermostat from the water outlet
Fig. Inspect the water outlet connection for cracks or damage
Fig. Thoroughly clean the mating surfaces of the water outlet and . . .
Fig. . . . the engine before installing a new gasket
Fig. The jiggle valve must be in the up (12 o-clock) position after installation into the water outlet
Fig. 1: Remove the coolant recovery tank hose from the water outlet
Fig. 2: Remove the upper radiator hose from the water outlet
Fig. 3: Remove the three retaining bolts for the water outlet
Fig. 4: Carefully separate the water outlet from the thermostat housing
Fig. 5: Remove the thermostat from the housing
Fig. 6: Make sure you replace the O-ring when installing a new thermostat
