Question about Cobra GPS
I can hear people talk but they can't hear me I have a cobra29 nwst what should by settings be at
  • Cobra Master
  • 3,287 Answers
Set the switches to: 1) S/RF, 2) OFF, 3) CB, 4) HI and 5) NOR. You may change any of these to any desired position except for the CB / PA switch. This switch must remain in the CB position to transmit "over the air" - whereas the PA selection simply sends the audio to the PA jack on the rear of the radio to an external, Public Address speaker and the WX position is to select Weather Band radio reception. It is not possible to transmit on the Weather Band channels.
Choose a channel and set the squelch to MIN and Volume to a comfortable level (you can increase the Squelch slowly just until the speak shuts off if you don't want to hear static sounds). Dynamike and RF Gain both should be set to MAX. Delta tune should normally be left at the mid point. The Dimmer and SWR/CAL knobs should be set to any position you like.
Make sure you have a properly tuned 27 Mhz CB antenna connected to the back of the radio. You should review the Calibrate for SWR procedure in the manual - SWR of 1.5:1 or less are ideal, and those greater than 2:1 are bad. SWR of 2.5:1 and up may damage the radio if left unfixed. Check this list of articles of how to tune a CB antenna if you have more questions about this very important subject.
You should download & review the manual . I hope this helps
Posted on Oct 08, 2010
How to set dk on cobra29 ltd classic
reverse the procedure in the way you turn it up. You need a watt meterand a small non metallic screw driver.hook the meter between the radio and the antenna and turn it on.Now find l14 , it will be near the final. Watch your meter and turn the screw slow and it will either go up or down ,which ever way you need it to go. Have a great day.
Apr 17, 2014 | Cobra Radio Communications
I can talk but cant hear
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
Can a Motorola talk about 250 talk to a cobra CXT 195. They can hear me from the Motorola I just cant hear them
Your code (PL code, interference eliminator, quiet call) is not programmed the same on both radios. The Cobra appears to be set to open squelch (no code). Set your Motorola code setting to zero (off). This should solve the problem.
Feb 18, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
How can i hear what they are saying without that awful loud sound when they arent saying anything. cause when i turn the volume down i cant hear what they are saying
Turn up your SQUELCH button when no one is talking until the static noise just goes away.
Now your set will remain quiet until someone talks.
If you set the squelch too high it will also cut out the people talking, so always try to have it set just slightly above the background static level.
Good luck.
Apr 15, 2011 | Uniden BC350C Base Scanner
Can hear the other party talk but they can not hear me from my LGVX970, is there a setting that I can change?
Since you can hear the other party when calling but the cannot hear you, this as nothing to do with settings.
The problem with your phone is that the mouthpiece of your phone is bad and will require you to chande it.
Change the mouth piece of your phone, and your caller or who you talking to will hear you.
Take care.
Apr 25, 2010 | LG Dare VX9700 Cell Phone
My friends can hear me when i talk into my turtle beach x1's, but i can't hear them. Why?
If you set the Xbox Dashboard > Live > Voice setting to "Play Through Speakers" can you hear the others talking to you? If the chat talkback works that way, but doesn't work when you have it set to "Play Through Headset" then you probably have a failing chat-controller cable. If you replace that, the problem should be fixed.
Mar 10, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
I have a cobra29 wx nw st. its been peaked and tuned, an echo board installed, and soundtracker override when i key up if my mic gain is over 1/4 the way up it makes an awful racket what do i do?
is there talk back installed? if so its probably too loud. You are getting feed back. The talk back should be low, just enough to hear it to check echo. 470 ohm resistor is perfect.
Jan 04, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I can't hear or talk to anyone on halo 3
I'm not to sure about CoD4, but on halo u might have the settings set up so that you have to hit up on the Dpad to be able to speak.
Sep 03, 2009 | Microsoft Xbox 360 Console
I can hear people i just cant talk to them
A few reasons for not being able to talk through the mic is that if parental settings are set. Parental settings can stop you from talking and, if set right, can stop you from hearing other people, which isn't the problem. It could also be that the mic on the headset is broken. If it is, you will have to buy a new one. Try using someone else's headset. If theirs works, then it confirms that it is only your headset. If it doesn't, it might mean that either your Xbox 360 remote isn't working right for voice, or parental settings are restricting you from that action.
May 01, 2009 | Video Game Consoles & Games
How do I set up my Skullcandy Lowrider head set
if you go on there site you have got to change some settings on x box live. here is the link. http://www.skullcandy.com/manuals-and-drivers.html it is the x box settings for lowriders.
Apr 22, 2009 | Skull Candy Lowrider Headphones
GPS Logo
177 people viewed this question
Top Cobra GPS Experts
Steve
TO Lady
Are you a Cobra GPS Expert? Answer questions, earn points and help others
