Question about Logitech 967437-0403 Keyboard
My mouse works but my keyboard does not. I have installed new batteries and still no response from my wireless keyboard. Any suggestions?
    Novelist:
  • 117 Answers
Have you synchronised the keyboard with the wireless receiver unit after changing the batteries? It's normally a case of pressing the connect button down on the receiver and then holding down the connect button on the back of the keyboard until the receiver picks up the signal.
Posted on Oct 08, 2010
Microsoft mobile mouse 3000 device unknown on usb driver . Code 43 .was working lastnight . Now want work . Works on other computer
I suggest that you run the Windows 7 Hardware Troubleshooter on the computer and check to make sure that the mouse is ok.
1. Click Start.
2. Type in Troubleshooting in the Start Search.
3. Click on Hardware and Sound.
4. Click on Hardware Devices.
Now check if that fixes the issue or not.
If the issue still persists, then I suggest that you install the latest drivers manually from the link and install the same and check.
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Refer the link for more information: Troubleshoot a wireless mouse that does not function correctly: http://support.microsoft.com/kb/321122
Troubleshoot failure to find new mouse connected to your USB port: http://support.microsoft.com/kb/223256
I also suggest that you check if the batteries are full of charge.
Hope this response helps you out.
Best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time
to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Microsoft Wireless Mobile Mouse 3000
Wireless mouse worked fine until I put in a new battery; not now
check the transceiver which is usually attached to one of your usb ports.
you can try installing it to another port.
May 31, 2010 | Logitech 9311570403 Mouse
Logitech wireless mouse not working. Tried changing batteries. No go. Tried different mouse inserted into USB (this worked) Anything else to do short of buying new one?
I was unable to find this product on the Logitech website to check for support information. I would suggest that you make sure that you install the proper software for these devices and also that you press the sync button (located under the wireless receiver) and also on the keyboard and mouse (doing one at a time).
Good Luck,
Jesse
Jan 12, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Wireless Mouse on a laptop with built inTouchpad on the keyboard
No need to disable the touchpad they should both work at the same time. Have you tried both the mice on another PC?. The first mouse should have the correct software already installed but you will most probably need to install software for the microsoft mouse. I hope you have tried resetting by hitting the button on the receiver then while its flashing the button on bottom of the mouse? If all this fails do have any other USB devices you can test on laptop?......good luck
PS I hope its not the batteries
Oct 31, 2009 | Microsoft Wireless Notebook Optical Mouse...
My keyboard is n't typing? I have a laptop.
reinstall the driver ..and check the plugs for proper insert ...if there was a problem and you started the pc ..and do not sow the device ...( problem like unpluging ..or out of batteries..) it is the chance that you need to go to the device manager ..and update the driver ...( from the disc ) or automatically cause the driver is still installed into the pc ...
May 29, 2009 | Logitech Wireless Access Duo Optical...
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Microsoft Wireless Optical Mouse 2000 stops responding
i would agree that a new one may be needed. i have a desktop set that, the mouse had failed. i got a better microsoft mouse, and i was able to use it with the desktop set.and have all of the functions of the new mouse through the original receiver. hope this helps! good luck.
Jan 21, 2009 | Microsoft Wireless Optical Mouse
Mouse works, but not keybord. Had to elace batteries on keyboard now it doesn't work..I am using 'On-Sceen Keyoard'.Please help.
Presumably you have a wireless keyboard? I would suggest buying the cheapest USB keyboard for now and then try to get the other keyboard working.
Are batteries OK, any lights from keyboard, is wireless receiver in computer working (presuambly yes if same one as the mouse - if so then suggests the problem is with the keyboard).
Try removing and replacing all batteries - try new batteries.
Aug 03, 2008 | Computers & Internet
Keyboard does not work
i would suggest starting over.. uninstall the drivers for the keyboard mouse and go download the new ones from the manufactures website and fallow the instructions. typically they want you to install the drivers first before plugging in the wireless receiver. i hope this helps.. good luck.
side note- if your having the same problem with 2 diffrent wireless keyboards. you might have some interference from another wireless device. i.e. cordless phone, cell phone. so you might troubleshoot that if the drivers dont work.
Jan 22, 2008 | Computers & Internet
Logitech 967437-0403 Keyboard Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
