Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Chainsaw starts runs for a couple of minutes and then dies
5 Suggested Answers
  • 4088 Answers
SOURCE: Why does my poulan chainsaw cuts off
Check the spark plug for condition. It should have a light brown appearance. Check the gap, should be about 0.020". If it looks black and wet, check the air cleaner condition. Check the carburetor mounting and end plate screws for tightness. Check the condition of the fuel lines from inside the tank (tank-end filter too) out to the carburetor for condition. Replace anything that looks cracked or kinked. Check the lines to and from the primer button if the saw has one--no cracks in the primer button itself. Make sure the fuel in the tank is the proper oil mix and is fresh. Always pre-mix oil and fuel before filling the tank. Hope this helps.
Posted on Aug 14, 2009
  • 246 Answers
SOURCE: chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Posted on Jul 26, 2009
dontbother10
  • 2220 Answers
SOURCE: chainsaw will run for 10 minutes then dies,will
Does it go from full speed to dead stop (like ignition turned off - coil or associated)? Or does it act like it is running out of gas (fuel vent)? If coil or change the plug and try it. Plug <$5, coil >$50. Answer back with serial number and i will provide an IPL that is most helpful with both problems.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 21, 2010
  • 4088 Answers
When it dies, try removing the fuel cap for a moment, then try restart. If successful, the tank vent is likely plugged (look under the left case cover). It should be a bronze plug set into the tank surface. If no help, remove the spark plug, and test for blue,snappy spark. If nothing happens, try a new plug first. If still nothing, remove the stop switch grounding wire at the ignition module and retest. If still nothing, the module is dying with heat--replace it using a thin business card for a gap gauge. Turn the flywheel magnets under the module poles and allow the new module to stick to the magnets, then tighten the screws. Rotate the flywheel to release the card, then turn the flywheel one complete revolution to make sure the module gap doesn't close up. Hope this helps!
Posted on May 14, 2010
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
Chainsaw cranks and runs but after minute or two it dies. will start again but dies when trying to throttle up
Check the fuel tank vent. Does the saw leak fuel when laying on its side.? Faulty vent can cause the saw to bog down when running
Nov 20, 2012 | Husqvarna Garden
Starts and runs fine, about five minutes then sputters and dies. will not restart until cooled
do cold comp. test if below90psi remove muffler and inspect piston cyl. wall for scroing
Oct 20, 2012 | Poulan 14" Chainsaw
Why does my chainsaw cut out
To rule out the tank breather, slacken off the filler cap enough to allow air in, if it picks up again then it is a tank breather issue.
Apr 21, 2012 | Poulan Garden
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Echo 750 saw runs for two minutes then dies icheck the plug it has gas on it and plug still sparrks put back in starts runs for two minutes or less and dies again?
Could be a fuel tank breather issue, when it starts to die slacken off the fuel cap, to see if it picks up again, if it does you need to replace the breather.
Feb 16, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have a McCulloch 3516 chainsaw and need advice on how to adjust the carburator. It starts but runs for a short time and dies.
You say runs a short time, seconds or minutes ? Seconds could be carb setting, minutes could be fuel mix ratio. let me know.
Oct 17, 2009 | McCulloch Garden
Chainsaw starts and runs fine for a few minutes
Jul 26, 2009 | Garden
Dies when pressing the accelerator
If your chain brake is not engaged, which i am sure you have checked, look at the air breather filter or the exhaust muffler which could be blocked with carbon.
Jun 08, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Saw runs for 3-4 minutes then dies
check the spark plug
change the seals with new ones
check compression
regards Mihai71
Nov 26, 2008 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
602 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
