Question about InFocus LP860 Multimedia Projector
Curious as to why my InFoucus LP860 has blue in the corner and also runs down the side of the image... its a consitint....connected to a source or not.
    Champion:
  • 269 Answers
This is heat damage to the lcd panels due to the projector not being shut down properly. When the unit has been on for any lengthy period and it is shut off using the on/off switch on the rear of the unit, this shuts the whole thing down, fans and everything. If it is shut off using the on/off buttons on the remote or on top, the fans keep running until the unit is cooled and then powers itself completely off. The damage is only fixable by replacing the light engine and if not under warranty is very expensive.
Posted on Oct 12, 2010
What will cause a wavy blue lines running left to right from the top down
That is knon as a convergence failure. Its real common an a failry easy DIY fix. You can read more about how to fix it here in this video and on the fixya tips page below.
07e70208-1f08-4826-857e-065c46e4dbb8.pngFixya Tip Page
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2013 | Philips Televison & Video
When i install apps, 0xE8008001 pop ups. telling that the app doesnt installed.
  1. Launch Cydia: First double click the Cydia desktop icon which will launch the application as shown below.
  2. Cydia Sources: First click the Manage in the bottom Cydia navigation menu which will open the window below. cydia-manage-tab.thumbnail.gif
    Now click on Sources to open the package source management window as shown below.
  3. Add New Source: Click the Edit button located in the top right of the window shown in the above image which will allow you to add new sources, edit current sources, or delete current sources. After clicking the Edit button a new button titled Add will appear in the top left of the window so click that to add cydia.hackulo.us as shown below. Once you have the new source location filled in click the Add Source button to complete the addition. cydia-add-new-source.thumbnail.gif
    **NOTE** You may be required to reboot your iPhone or iPod Touch after installing the cydia.hackulo.us source as noted by pinkurinal in the comments. Keep this in mind when attempting to install AppSync below.
  4. Search For AppSync: After you have added the new source above it might take a moment for the new packages to sync but once they do go back to the Cydia home screen and then click the Search button located on the right side of the bottom navigation. Type “AppSync” in the search window and click the blue Search button which should provide results similar to the below image. search-cydia-for-appsync.thumbnail.gif
  5. Install AppSync: Now install the correct version of AppSync based on the firmware version on your iPhone or iPod Touch. In my case I have firmware version 3.0 on my Touch so I installed AppSync for OS 3.0 by clicking on the app in the search results. After clicking on the app in the search results click on the Install button in the top right corner of the window as shown below. cydia-appsync-for-os-3-0.thumbnail.gif
    After clicking Install the details of AppSync will display and you will need to click the Confirm button also in the top right corner of the window as shown in the below image.
    The AppSync source will now downloaded and install on your iDevice. Once completed a screen similar to the below will display and allow you to return to Cydia while AppSync will be installed and ready to use.
  6. Sync Apps Via iTunes: Now return to iTunes and drag the unsigned application into iTunes and then click the Sync button to sync the applications with the jailbroken iPhone or Touch that now has AppSync installed. The signature verification is removed from the Springboard with AppSync so the error will no longer appear and you will be able to use the unsigned application you have downloaded or created.
Sep 11, 2010 | Apple iPod touch
How do I install a Sunpro Super tach 3 in a 1987 Mustang 5.0
The Black wire will connect to body ground, and it should be a good solid ground and if this wire is not grounded well then you might receive a primary voltage shock if you touch anything that is metal or grounded inside of the vehicle when the engine is running.
The Red wire should be connected to power when the key is in the "Run" position only, and a good place to find that source is one of the "IGN" connections at the fuse panel using a covered female spade connector. Use a test light and be certain that the connection only has power when the key is in the "Run" position, and has no power when the key is in the "Off" or "Accessory" position.
The White or Yellow wire should connect to the "LPS" connection at the fuse panel next to the LPS fuse using a covered female spade connector.
The Green wire will connect to the "-" negative side of the ignition coil or to the "Tach" or "Test" lead that runs from the negative side of the ignition coil. To locate the lead run down the wire from the negative side of the ignition coil and the lead should break off from that wire and it should have a tag on the wire that will say either "Tach" or "Test" (sometimes it is just an empty black wire connector) and that is if the lead does not come straight off from the wire connector at the ignition coil. If there is no lead you can get a wire tap connector to tap into the wire from the negative side of the ignition coil and then use a covered male spade connector to connect the Green wire from the tachometer to the wire tap connector.
Here is a diagram to help assist you and if you can not download the image right click on the image and then select "save picture as..." or "save image as..." and from your image viewer you should be able to read this diagram or print it out, and let me know if you require any further assistance.
Aug 20, 2010 | Ford Mustang Cars & Trucks
How do I get my hp f4280 to scan to my comp.
Hello Lulu !
To use the scan features, the HP All-in-One and computer must be connected and turned
on. The HP Photosmart Software must also be installed and running on your computer
prior to scanning. To verify that the HP Photosmart Software is running on a indowscan
computer, look for the HP Digital Imaging Monitor icon in the system tray at the lower
right side of the screen, near the time.
To scan to a computer
1.
Load your original print side down on the right front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it. Any
edits that you make apply to the current scan session only.
The HP Photosmart Software has many tools that you can use to edit your scanned
image. You can improve the overall image quality by adjusting the brightness,
sharpness, color tone, or saturation. You can also crop, rotate, or resize the image.
3. Make any edits to the preview image, and then click Accept when you are finished.
Heres a link you will find everything you need to know about the f4280 (scan features starts on page 63) :
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jul 15, 2010 | HP DeskJet F4280 All In One Printer InkJet
All LEDs are in constant switched on state(BLUE)
When you plug in the source device and the output device, all of the LEDs light blue, letting you know that the device is ready to capture. When you are ready to capture, simply press the play button on your source device, the Rec button on the Video Transfer, and the LEDs light red, both on the source side and the output side, letting you know that a recording is in process. To stop recording, press and hold the record button and when the lights turn blue, recording has stopped.
this is the source: http://www.pinnaclesys.com/PublicSite/us/PinnacleLife/Content/Reviews/video+to+ipod.htm
Jul 25, 2009 | Pinnacle Video Transfer
I have a rosen navigation system in my VW Eos 2009. How do I get video to play while driving?
yes i have a solution,it is disabled for legall issues,but you can go into technician menu and turn off brake setting,you have to go into main menu and go to av setting in far left bottom corner,hit the upper right corner there is no item to touch ,bit tap corner and a drop down menu will appear ,enter 7253 and then enter,go to brake selection and sect till shows off and thats it,hope that helps
Jul 23, 2009 | Car Audio & Video
MSI PR400 can't find wireless switch
On my msi u120 the switch trick is as follows:
Hold down the funcion (Blue FN button on the left bottom of the keyboard) and at the same time press F11. The blue icon, looks like a little saturn, on the front of the keyboads will light up and you will be able to connect
Mar 24, 2009 | MSI : MP54G Wiress 802.11g Mini PCI Card...
InFoucus LP500 Projector
Hi there
That is 100% faulty cable ! Try another VGA / RGB cable and I can guarantee you that you'll be trouble free.
Dec 05, 2007 | Office Equipment & Supplies
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Jun 15, 2007 | Panasonic PT-47WX49 47" Rear Projection...
InFocus LP860 Multimedia Projector Logo
166 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
