Question about Fujitsu Siemens AMILO D-7830 Notebook
HDD REMOVAL Covers removed, can see the HDD in its carrier, but it's not obvious as to what has to be done to remove the HDD assembly (or perhaps I am being particularly dense today). Anybody help plse.
  • supac Jun 20, 2008
    Thanks for the info. Further to your instructions, you remove the one screw retaining the HDD caddy. Then with the help of the plastic tab fitted to the caddy, you push the caddy/HDD to the right to disengage the pins, then lift the left hand side upwards to remove the assembly.
    Scholar:
  • 139 Answers
To remove the hard drive yu will have to lose any screw holding it then u now act as if yu want to push it towards right or left direction. u need to apply a little force but not too hard man.
now raise it up it should come out.
hope this helps
thanks
Posted on May 29, 2008
How do I replace heater core?
Removal Procedure
  1. Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement .
  2. Remove the heater core case cover.
  3. Remove the heater core bracket and screw.
  4. Remove the heater core.
Removal Procedure
Recover the refrigerant. Refer to Refrigerant Recovery and Recharging .
  1. Drain the engine coolant. Refer to Cooling System Draining and Filling in Engine Cooling.
  2. Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Remove the evaporator hose from the evaporator. Refer to Air Conditioning Evaporator Hose Assembly Replacement .
  4. Lower the vehicle.
  5. Remove the heater hoses from the heater core. Refer to Heater Hoses Replacement .
  6. Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  7. Remove the drain tube elbow from the evaporator block heater case plate.
Remove the nuts holding the heater case plate for the heater pipes. Remove the heater case plate and the seals for the heater pipes. Remove the nuts holding the heater case plate for the evaporator block. Remove the heater case plate and seal for the evaporator block. Remove the nut for the HVAC module assembly bracket. Lower the vehicle. Remove the instrument panel (IP) carrier. Refer to Instrument Panel Carrier Replacement in Instrument Panel, Gauges, and Console. Remove the cross vehicle beam (tie bar). Remove the floor air duct from the HVAC module. Refer to Floor Air Outlet Replacement . Remove the air distribution duct. Refer to Air Distributor Duct Replacement .
Remove the daytime running lights (DRL) sensor wiring harness clip (1) from the HVAC module assembly. Disconnect the IP lamp dimmer switch electrical connector (2). Remove the wiring harness clips (3) from the HVAC module assembly bracket. Disconnect the vacuum source hose (4) from the vacuum tank.
If you have never done this before I suggest you take it to a ASE certified repair shop or the dealer .
Dec 27, 2015 | 2001 Chevrolet Malibu
How to install a blower moter and fan
Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support.
BLOWER ASSEMBLY
Removal and Installation
1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly
2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure.
INSTRUMENT PANEL
Removal
1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl.
2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector.
3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel.
Installation
1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
Feb 28, 2011 | 1995 Isuzu Rodeo
Electric window feel down broken mechanism
Glass & Regulator
Fig. View of inner door frame and window regulator assembly
  1. Lower the window glass and remove the door panel.
  2. Carefully peel off the door screen so that it can be reused.
  3. Raise the window enough to reach the regulator bolts, hold the glass underneath and unbolt the glass from the regulator.
  4. To remove the glass, raise the glass by hand and tilt it as necessary to remove it from the track.
  5. To remove the regulator, lower the glass carefully to the bottom of the door and remove the bolts to remove the regulator.
  6. Installation is the reverse of removal. Tighten all bolts to 61 inch. lbs. (7 Nm).
Fig. Installing the door glass regulator
Motor
  1. Remove the door panel.
  3. Unbolt the window from the regulator and carefully lower it to the bottom of the door.
  4. Disconnect the wiring and remove the motor mounting bolts.
  5. Remove the 3 guide rail bolts and lower the motor and guide rail assembly out the bottom of the door.
NOTE The upper cable must be below the guide rail mounting bracket.
Showing window regulator motor, or assembly carrier with window regulator, removal/installation
Fig.
NOTE The illustration shows the removal and installation of the window regulator motor/assembly carrier with the window regulator on the rear doors. The procedure for removing and installing on the front doors is the same.
Fig. Slide a hammer shaft between the window guide and the assembly carrier until the end of the hammer shaft presses against the assembly carrier. Remove the screws and take off the window regulator motor
  1. Slide a hammer shaft between the window guide and the assembly carrier until the end of the hammer shaft presses against the assembly carrier.
  2. Remove the screws and take off the window regulator motor.
To install:
  1. The gearing will move when the window regulator motor is removed; it is then no longer centered. The gearing must be aligned when the window regulator motor is installed until the window regulator motor is centered again.
  2. Installation is the reverse of the removal (see illustration).
Motor & Regulator
NOTE The illustrations in the procedure show the replacement of the window regulator motor/carrier assembly with window regulator for rear doors. The procedure for front doors is the same.
  1. Remove the front or rear carrier assembly.
  2. Slide a hammer handle between the window guide and carrier assembly until the hammer handle end presses on the gears of the carrier assembly.
  3. Unfasten the bolts (1) and remove window regulator.
    Fig. Unfasten the bolts (1) and remove window regulator
To install:
NOTE By removing window regulator motor, gearing shifts, it is not centered.
Fig. By removing window regulator motor, gearing shifts, it is not centered
  1. When installing window regulator motor, the gears must be aligned until the window regulator motor is centered again.
  2. Attach and tighten the bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
  3. Carrier assembly with window regulator, installing:
    1. For replacement part carrier assemblies, the gearing is secured in place with a cable tie.
      Fig. For replacement part carrier assemblies, the gearing is secured in place with a cable tie (1)
    2. Slide a hammer handle between window guide and SF so far until hammer handle end presses on gears of SF.
  4. Remove the cable tie .
  5. By removing window regulator motor, gearing shifts, it is not centered.
  6. When installing window regulator motor, gears must be aligned until window regulator motor is centered again.
  7. Attach and tighten bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
Hope this helps to solve it.
Dec 14, 2010 | 2002 Volkswagen Jetta TDI
How do you replace the ignition key switch for a '96 chevy diesel 1 ton 4wd pickup truck?
Ignition Switch Removal & Installation To Remove:
  1. Remove the steering column trim covers.
  2. Remove the wire harness from the retainers as needed.
  3. Slide the 2 connectors of the multifunction switch assembly out from the bulk head connector.
  4. Detach the key alarm connector from the lock assembly.
  5. Remove the ignition switch mounting screws and the ignition switch from the steering column.
Ignition switch removal/installation gm-08-00-1141.gif
To Install:
  1. Install the ignition switch on the lock module.
    • Tighten the screws to 42 lb in (4.7 Nm).
  2. Install the key alarm connector on the lock module.
  3. Slide the turn signal and multifunction switch connectors into the bulkhead connector.
  4. Install the harness in the original retainers.
  5. Install the steering column trim covers.
Ignition Lock Cylinder Removal & Installation To Remove:
  1. Disconnect the negative cable from the battery.
  2. Disable the supplemental inflatable restraint (SIR) system.
  3. Remove the steering column trim covers.
  4. Turn the ignition lock cylinder to the run position.
  5. Using an awl with a bent tip, insert the tip into the access hole of the ignition lock cylinder.
  6. Turn the lock cylinder to start and push down and hold the lock cylinder retaining pin.
  7. Release the lock cylinder to the run position and withdraw the cylinder from the steering column.
To Install:
  1. Align the slot in the steering column to the tab on the lock cylinder and install the lock cylinder until it locks in place.
  2. Install the steering column trim covers
  3. Connect the negative cable to the battery
  4. Check for correct operation
Oct 08, 2010 | Chevrolet 3500 Cars & Trucks
No air deflected to floor. All others (vents, defrosters) ok
There's a possible problem with the following part: Vacuum Control Assembly Removal & Installation To Remove:
  2. Disconnect the electrical connector from the vacuum control assembly.
  3. Disconnect the vacuum harness connector from the vacuum control assembly.
  4. Remove retaining screws and vacuum control assembly from vehicle.
To Install:
  1. Install the vacuum control assembly and retaining screws to the vehicle.
  2. Connect the vacuum harness connector to the vacuum control assembly.
  3. Connect the electrical connector to the vacuum control assembly.
  4. Install the instrument panel carrier.
Sep 24, 2010 | 2003 Chevrolet Blazer
Replace a brake light, how do you remove the lens?
Well you can please follow the below link -
1. Open the rear hatch of the Murano.
2. Remove the screws holding the rear trim covers in place.
3. Pull off the rear trim covers to expose the rear taillight housing assembly.
4. Remove the power connector running to the brake light ballast.
5. Turn the brake light counterclockwise with your hand, and remove the light from the housing assembly.
6. Install the new brake light. Installation is in reverse of removal. Post comments for more help or information......
Good Luck!!
Mar 28, 2010 | 2003 Nissan Murano
2006 hhr to take out ignition switch out
1. Disable the SIR system.
Remove the Instrument Panel (I/P) center trim panel by releasing the retaining fasteners
  1. Remove the Instrument Panel (I/P) center trim panel (1) by pulling out on the trim panel in order to release the retaining fasteners (2).
  2. Disconnect the electrical connectors on the Instrument Panel (I/P) center trim panel (1).
Remove the steering column opening filler assembly, with clip, & bumper
3. Remove the steering column opening filler assembly (1) by pulling away the clips (2).
4. Disconnect the electrical connector for the trunk release.
Remove the Instrument Panel (I/P) left side trim panel
  1. Remove the Instrument Panel (I/P) left side trim panel (1).
  2. Tilt the steering wheel up.
  3. Disconnect the I/P dimmer switch and, if equipped, the fog lamp switch.
Remove the 4 bezel screws (2) & the Instrument Panel (I/P) cluster bezel assembly (1)
  1. Tilt the steering wheel down.
  2. Remove the 4 instrument panel cluster bezel screws.
  3. Remove the instrument panel cluster bezel.
Remove the steering column trim covers: steering column upper cover assembly, steering column left cover assembly, & steering column right cover assembly
  • Remove the 3 cover screws (4).
  • Remove the steering column upper cover assembly (1).
  • Remove the steering column left cover assembly (2).
  • Remove the steering column right cover assembly (3).
Removal of the ignition switch
    1. Disconnect the ignition switch harness connector.
    1. WARNING
    The ignition switch must be in the run position during removal in order to avoid damage to the ignition switch.
    1. Turn the ignition switch to the run position.
    2. Remove the ignition switch screws.
    3. Remove the ignition switch from the steering column.
    To install:
    1. Install the ignition switch and screws on to the steering column. Tighten the screws to 17 inch lbs. (2 Nm).
    2. Connect the ignition switch harness connector.
    3. Installation is the reverse of removal procedure.
    4. Tighten the trim cover screws to 17 inch lbs. (2 Nm)
    5. Tighten the 4 instrument panel cluster bezel screws to 19 inch lbs. (2 Nm)
    6. Enable the SIR system. Refer to Air Bag (Supplemental Restraint System), arming the system.
      NOTE If the ignition switch is replaced and a learn procedure is not performed, the engine will crank but not start or will start and stall immediately.
    7. Perform the vehicle theft deterrent system learn procedure.
    Mar 12, 2010 | 2006 Chevrolet HHR
    Diagram on to change turn signal arm on 1994 chevy cavalier , do u have to pull the sterring wheel
    1991-94 Cavalier
    See Figure 5
    This procedure covers removal and installation of the headlamp, headlamp dimmer switch, turn signal and hazard switches, as well as the cruise control switch.
    1. If equipped, disable the SIR system. For details, please refer to the procedure located in of this repair guide.
    0900c1528003bf08.jpg enlarge_icon.gif enlarge_tooltip.gif Fig. Fig. 5: View of the steering column showing the turn signal switch location
    1. If not already done, disconnect the negative battery cable.
    2. Unfasten the horn pad, then remove the steering wheel. For details, please refer to the procedure earlier in this section.
    If necessary, using locking pliers with a piece of rubber (such as a spark plug boot) between the jaws to help prevent damage to the tilt lever during removal.
    1. If equipped, remove the tilt lever from the steering column by grasping the lever firmly and twisting counterclockwise, while pulling it from the column.
    2. Remove the upper and lower steering column covers.
    3. Remove the dampener assembly, then unfasten and remove the switch assembly from the vehicle.
    To install:
    1. Position and secure the switch assembly.
    2. Install the dampener and the upper and lower steering column covers.
    3. If equipped, attach the tilt lever to the column.
    4. Install the steering wheel, then fasten the horn pad.
    5. If equipped, enable the SIR system, as outlined in of this repair guide.
    6. Connect the negative battery cable.
    Nov 15, 2009 | 1994 Chevrolet Cavalier
    IS it difficult to remove the ink carrier on the DX4850 Epson.My magenta must be blocked below the carrier.I have done numerous cleans but ink still won't flow through to the page.I think I am capable of a...
    The removal is not difficult it's just a couple of screws however, great care must be taken with the ribbon cable as it is very fragile. I wouldn't recommend trying, leave it to a service centre
    Aug 21, 2009 | Epson Office Equipment & Supplies
    E2 error
    Something might've been broken in the forced tape removal. VCR tape carriage (the cassette unit) assemblies are rather delicate, easily broken, in contrast to the units in early VCRs (from the '80s or early '90s). Use of force in tape removal... can break stuff, or perhaps get the gear timing fouled up. Take the top cover off, look for broken pieces of this assembly. If this assembly has gears on the right side, this obviously means it is gear driven. Timing is set by lining up marks on the gears, in most cases. Setting this might be tricky- service literature will tell you how to set this, and in what mode the marks line up.
    Apr 15, 2007 | Mitsubishi HS-U778 VHS VCR
    Fujitsu Siemens AMILO D-7830 Notebook Logo
    219 people viewed this question
    Top Fujitsu Siemens Computers & Internet Experts
    Alun Cox
    Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
