Question about Panasonic NV-GS15 Mini DV Digital Camcorder
No display on screen when fully opened. Display appears when screen is partially open (25 degrees)
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Acer tablet troubleshooting
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
DELL VOSTRO Display goes blank after it is more(than halfway open
You should be able to remove the LCD hingecover and reeseat the video cable. But hte issue may be a damaged cable going thru the hinge assembly which would require a replacement LCD.http://support.dell.com/support/edocs/systems/vos1500/en/sm/display.htm#wp1179838
Jun 04, 2009 | Dell Vostro 1500 Notebook
When I open the lid of my laptop fully, the screen goes black.
Sounds like the ribbon cable connected to the display is loose, I would send in for repair, shoun't cost much.
Dec 22, 2008 | Toshiba Satellite A100-S8111TD Notebook
Screen does not display
I had the same problem. more than likely your connector cable between the camera and the display has become brittle over time and is beginning to break. as you open the screen the small wires inside the cable are separating. mine went from 30 deg view to 90 deg no display as yours is now, then 30 deg fuzzy display (cant make out the picture like a VHS when it needs heads cleaned) then the cable gave in and snapped. all the way through. Simply not a lasting camera. I got quotes and it was about $200 to fix. for that price these days u will pick up a better camera anyway. Good luck
Nov 19, 2008 | Panasonic NV-DS60 Mini DV Digital...
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
112 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
