Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Hp pavillion Hey, Out of the blue my games will not run in full screen and sometimes my screen turns to black and white stripes. Do you think it's a software or hardware problem?
  • 3 more comments
  • jax1 May 30, 2008
    I have tried to intsall drivers but I get an error message every time I try.
  • jax1 May 30, 2008
    The error message says "access denied."
  • Chris Hall May 11, 2010
    is it onboard video?
    whats the error?
    have you installed drivers lately?
  • 458 Answers
Most Definately a Hardware problem...your laptop is not capable of running the refresh rates that the game requires, Because your Display Panel is Going bad..This is the screen that attaches to the Backlight.. it is connected to a Long Circuit Board.. The Board is the part that is going bad..
I would first check the Display Cable.. it connects to the circuit board i just described.. see if has come loose.. push into place & secure..
Posted on Jun 04, 2008
Pioneer deh 15ub wire diagram
Yellow - Constant 12 Volt (battery)
Red - Accesory 12 volt (switched) only 12 volts when car in accesory or on position
Black - Ground (chasis)
White/white with black stripe - Front left speaker (black stripe is negative polarity)
Gray/Gray with black stripe - Front right speaker (stripe negative)
Green/green w/ black - rear left
purple/purple w/ black - rear right
solid blue - power anteanna (not all have this wire)
blue w white stripe - remote turn on (used to turn amplifier on or power anteanna)
yellow w/ black stripe - mute (for cellphone handsfree kit)
Jan 21, 2014 | Car Audio & Video
Pioneer premier gm-x434 wiring diagram
Yellow - Constant (battery 12V)
Red - Accesory (switched) only 12 volts when car in accesory or on position
White/white with black stripe- Front left speaker (black stripe is negative polarity)
yellow w/ black stripe - mute (for cellphone handsfree kit)2_17_2012_9_02_19_am.jpg
Feb 17, 2012 | Pioneer Car Audio & Video
I just want to no what colour does what job on my sony cdx-l480x player just ripped it out my old car and cant find the wireing diagram
Yellow: battery constant 12v Red: Ignition 12v Black: GND ground White and White with Black stripe: Left front speaker. White is positive (+) Grey and Grey with Black stripe: Right front speaker. Grey is positive. (+) Green and Green with Black stripe: Left rear speaker. Green is positive. (+) Purple and Purple with Black stripe: Right rear speaker. Purple is positive. (+) Blue: Antena remote turn on. Blue with Wite stripe: Amplifier remote turn on. I think thats all of them. Make sure to connect your positives and negative correctly or you will have phasing problems. dreamsystems
Feb 08, 2011 | Sony CDX-L480X CD Player
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Hp pavillion wont boot, i just get a black screen
hello
I have read your problem and I think its a sure case of gone RAM.
Replace the RAM with a new one and your system will work fine.
Thank You
Jul 11, 2009 | HP Pavilion dv9000z Notebook
Blue stripes on Ipod screen
hey dude go to google and type in firmware reflasher for ipod(and what ever one you have and it's version) and then reflash it. or you can do it in itunes but it never works that way for me
May 21, 2009 | Apple iPod touch
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
