Question about ASUS VK246H 24 inch LCD Monitor
I have this ASUS VK246H 24 inch LCD Monitor, but while pressing the input mode button (shifting between vga, dvi, hdmi) suddenly the button was stuck. :-( It was like a spring was missing inside the monitor because it did not say click anymore. Thereafter i was only able to get respons from the power button to switch on and off the monitor. The other buttons no longer reacted. Is there a way to fix that easily by disassemble the monitor? Thank you so much!
2 Suggested Answers
FoxSysTech
  • 23 Answers
SOURCE: input select button to switch between hdmi/dvi/vga
Unless there is simply some dirt or dust caught in it, I would imagine that the button has lost its 'spring' or bounce-back ability which means that either you can take the big risk of attempting to fix it or come up with some other clever way to give it bounce.
Posted on Jul 03, 2009
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
Third monitor not showing
right click on desktop click screen resolution and press Detect button. Also try updating your video driver. also try swapping out the cables with each other and try using a hdmi cable for the TV connection.
Jan 18, 2013 | ASUS EAH5450 SILENTDI512MD3 RADEON HD 5450...
Asus ve205n lcd does not come on
It's might not be communicating with PC video card. It should pick up the input port automatically, but make sure on monitor is set to correct input like VGA. You can try re-seating video card on PC. Also test with VGA if you are using HD like DVI or HDMI.
Aug 31, 2012 | ASUS Ve205n 20" Widescreen Lcd Monitor Vga...
Can't get my Iiyama Prolite E2407HDS out of test mode
from iiyama tech support (UK):
  1. Switch off the monitor.
  2. Connect all 3 input types with live connections (VGA + DVI + HDMI)
  3. Turn the monitor on.
It will select an input and display as normal.
I have tested this and it does work!
Good luck
May 25, 2012 | iiyama E2407HDS-1 24 inch LCD Monitor
I have a Samsung 940bw monitor. After pressing the auto button, it does not work anymore. Is there a problem about monitor or is it broken? I am waiting for your help. Thanks.
Hello
damnor01 here to the rescue!
Welcome to Fixya.
Since you pushed the Auto button it is possible that the monitor has changed the input type to a type other than that you are currently using.
For instance it may have chosen to accept VGA input however you have the DVI or HDMI connected.
To fix this you will have to push the auto button again, and possibly again to get it to find your current input channel.
You may need to turn your computer off and then back on again.
You may need to connect your monitor using a different connector, example via VGA, DVI or HDMI. It all depends on the connection you have at present.
Blue Connector is VGA.
White connector is DVI.
HDMI is very narrow conector usually black.
Please be sure to rate this session!
Thanking you
damnor01
Mar 18, 2011 | Samsung Syncmaster 940BW LCD Monitor
I cannot seem to connect my new Asus VE247H 23.6 Inch Monitor with my New HP Pavilion Elite 460a Computer
Click here to see your screen specifications.
Your screen Supports DVI, HDMI 1.3 and VGA inputs.
Your Computer should have at least one of these connectors. The cables should have come with the screen.
Match them up, I would use either HDMI or DVI as these are digital signals.
VGA is analog, but if you can only use this one then go for it.
I do not see a reason to purchase an adapter.
Simply plug in at the wall and into the Graphics card of your computer.
You might have a card or onboard Graphics.
Thumbs up!
Let me know how it goes!
damnor01
Jan 20, 2011 | ASUS LCD Monitor
Where is the video on a samsung 23 inch syncmaster
I assume you mean video input. It should have both a DVI and VGA input on the back. looking up from underneath it is easily visible. I do not think it has HDMI, so if you're looking for HDMI input, you won't find it, get an adapter.
Oct 28, 2009 | Samsung 23 inch widecsreen 16:9 DVI 2ms...
Emachine 17" lcd monitor from Best Buy
1: Check the cable connections for the VGA or DVI cable at both ends for a secure connection.
2: There may be a button on the bezel of the monitor for input source to switch between VGA, DVI, or HDMI. While the monitor is on, press that one or more times waiting 2 or 3 seconds between presses to see of it finds the signal.
Apr 10, 2017 | E-Machines e15t 15" Flat Panel LCD Monitor
ASUS VK246H 24 inch LCD Monitor Logo
313 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
