Question about GE Wireless Optical Mouse
TheGE wireless Mouse seems to have batteries charged and functioning. The small USB connector seems to bethe problem. I think it used to light u7p when inserted into the usb slot but no longer. I have tried it on another computer but it still does not work. What is wrong?
  • 2,229 Answers
If it used to light up and now doesn't, it's probably gone bad. You did the correct thing in testing it on another computer.
If it has a little "connect" button on it, push that button.
Also push the "connect" buttons on the mouse and keyboard.
See if that helps.
Posted on Oct 08, 2010
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
I'm currently using a 2.4 GHz wireless optical mouse product number WR564A. Recently the mouse has stopped working in an odd fashion. The button in the mouse wheel flashes as if the batteries are low,...
its got a battery, replace it?
that small pieces is USB , and uses USB power to work
the mouse has a battery.
page to in your hp manuals states
single AA battery lasts 6months.
http://h10032.www1.hp.com/ctg/Manual/c02542571
Mar 12, 2017 | HP Wireless Optical Mouse
Keyboard & Mouse not inputting..Dell OptiPlex GX280.. OS, XP. Microsoft Wireless Desktop 3000 (keyboard/mouse) new.. Dell boots up and desktop appears, the cursor (arrow head) remains in middle of...
Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
I hope this helps
Andrew.A
Apr 09, 2011 | Dell OptiPlex GX280 PC Desktop
How do I replace the battery on my cordless mouse
Step 1 change-wireless-mouse-battery-1.1-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.1-800X800.jpg'); }); Exposed batteries of a wireless mouse Flip your mouse over and remove the battery cover. Gently pull it up and set it down in a safe place.
Step 2
  1. change-wireless-mouse-battery-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.2-800X800.jpg'); }); Carefully remove each battery.
  1. Step 3 Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.
Step 4 Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.
Good luck.
May 09, 2010 | Logitech Cordless Mouse
How do I change the battery?
  1. change-wireless-mouse-battery-1.1-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.1-800X800.jpg'); });
  2. Step 2 change-wireless-mouse-battery-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.2-800X800.jpg'); }); Carefully remove each battery.
  3. Step 3 Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.
  4. Step 4 Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.
Mar 14, 2010 | Logitech Cordless Mouse
How do i charge it?
You do have re-chargeable batteries in it? You could try a new set of batteries and there's usually a "Connect button you can press to reconnect it after installing new batteries.
Jan 02, 2010 | Dynex Wireless Optical Mouse
Wireless keyboard not functioning
I unplugged the usb connector and took out the batteries for both the keyboard and mouse for 30 seconds. Then I plugged everything back in.
Jan 09, 2009 | Kensington Computers & Internet
Wireless mouse
Dear friend,
I think that you are right, please check the manufacturing date of the mouse if one year has been passed that means it is ture.please also try to check your mouse after changing all the batteries of your wireless mouse.
thanks.
Jul 30, 2008 | Microsoft Wireless Optical Mouse
Toshiba Wireless Mouse
Your mouse might have had an internal receptor problem, meaing it can not read the signal from the adapter. This sometimes happens with wireless products. Contact Toshiba and they should give you a new one free of charge since it seems it was a faulty product. Rate me if this helps!
Dec 27, 2007 | Toshiba Wireless Mouse PA3205U-1ETC
GE Wireless Optical Mouse Logo
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
brian soufane
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
