Question about ASUS P4V8X-X Motherboard
Motherboard with mistake in the initialization
It shows that!!!
CMOS SETTINGS WRONG
CMOS DATE/TIME NOT SET
OVERCLOCKING FAILED! PLEASE ENTER SETUP TO RE-CONFIGURES YOUR SYSTEM
and I changed the battery these days
configuration
Plate of video NVIDIA GeForce FX 5200
1Memoria RAM 256Mb 333Mhz
1Memoria RAM 256Mb 400Mhz
Processor Intel Pentium 4 2.8Ghz
I already did of everything and I don't know the cause I await answer
Respectfully JARBAS BRASIL
  • Anonymous Feb 17, 2009
    some problem happened on my PC.
    the error message shown up when on the PC:
    overclock failed
    press F1...
    sometimes my HDD not dtected and said that my HDD was not on properly.
    please anyone can solve this?
    Scholar:
  • 139 Answers
After changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
Posted on May 29, 2008
How to set boot priority in award modular bios v6.0
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
hope this helps
Jun 25, 2012 | ASUS A7V333 Motherboard
CMOS Checksum Erro
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Mar 15, 2012 | Gigabyte GA-8I865GME-775 Motherboard
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
System failed due to cpu overclocking. Not setup for overclocking in the bios.
Reboot, and enter BIOS SETUP mode.
Choose "Load Default Settings".
This will "undo" any overclocking of your motherboard and of your CPU.
Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
Cmos setting wrong.overlocking failed! please enter setup.usb device over current status detected.system will shutdown after 15 second
remove the cmos battery wait about 5-10 seconds, replace battery. warning: this should reset all your setting such as time and date including your windows password
Jul 21, 2010 | ASUS P5GZ-MX Motherboard
I INSTALLED A NEW CMOS BATTERY BUT STILL NO EFFECT AFTER THE SHUTDOWN WHEN I RESTART IT THERE IS AN ERROR ..LIKE THIS CMOS SETTINGS WRONG ...CMOS SYSTEM TIME/DATE NO T SET...PRESS F1 TO RUN SETUP...PRESS...
Just replacing the battery will not set anything. You have to do the setting of the values. If you can run setup by pressing F1, then do that and set all the settings and then save before exiting. Make sure you save the settings by choosing the correct exit and re-boot option.
If the settings cannot be set nor saved, then make sure the poser is off or pull the plug from the wall outlet, then short the bios with the jumper to short the bios. This will reset the bios to the default settings. Turn on the system and then go to the bios settings and set the settings. Then use the reboot option to save the settings.
Nov 06, 2009 | ASUS P5PE-VM Motherboard
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Mar 18, 2009 | ASUS P5V800-MX Motherboard
Cmos problem
first load bios default settings then save.
then set your date and time.
detect your hard drive if your harddrive has win xp u not need to reinstall u just detect your hardisk then restart your sys will be boot with hdd.
Mar 26, 2008 | ASUS P4S800D-X Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
ASUS P4V8X-X Motherboard Logo
373 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
