Question about Maytag Dishwashers
We have a Maytag Quiet Series 300 dishwasher (#MDBTT 60AWB) that is in a house we recently bought. A few days ago it worked, but now it won't turn on. We checked the plug that goes into the outlet and it is plugged in. Yesterday we did have a plumber come out and unjam the garbage disposal. I don't know if that could be the source. Is there a reset button on the dishwasher? Basically there is no power going to the dishwasher. Any suggestions?
  • marka19
    marka19 Oct 08, 2010
    Is the outlet a GFCI? They have a small reset button in the center of the outlet.
SOURCE: Maytag dishwasher legacy 300 quiet series
FYI... I followed Miss Midget's steps... and there it was... a piece of plastic... actually one of the end caps from the rack. Poor design if you ask me. So for all you "grinders" out there, it's an easy fix... just need the appropriate star screwdriver. It went back together easier than it did taking it apart. Thanks.
Posted on Nov 28, 2007
jsrock516
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
  • 18 Answers
SOURCE: whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Posted on Jan 13, 2009
SOURCE: Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Posted on Apr 06, 2009
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601AWS)
in such cases it is always the control panel(touch panel) that needs to be replaced.it is very simple 2 chg and u could save lot of money.to chge cntrl panel ,open the door and remove all the screws around the white plastic part of door.then pull apart the inner part from outside part.the cntrol panel is held to outer panel with 4 screws.b4 that remove 2 screws holding the control board to panel.do not forget 2 unplug the unit from power b4 doing anything.
Aug 21, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag Quiet Series 300 owners manual
my dishwasher does not want to work anymore it has a big L flashing
Jun 14, 2009 | Dishwashers
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Apr 05, 2009 | Dishwashers
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
