Question about Microwave Ovens
When I set a cup of water on the center of the turn table and close the door, I enter the time (30 seconds) and press "START". The table starts to turn and the countdown runs. When I hear the beeping sound, I open the oven and take out the cup: The liquid is still cold.
  • 2,272 Answers
Make sure the controls are set properly: that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven.
1. Test the oven elements.
2. Test the oven thermostat.
3. Test the oven selector switch.
Testing oven elements:-
The oven heating elements are large resistor wires with enough resistance to generate significant heat. There are two heating elements in each oven: a bake element and a broil element. The bake element is found on the bottom of the oven, while the broil element is found on the roof of the oven. On some models, the bake and broil elements will work simultaneously to preheat the oven cavity.
click here for instructions :-- Testing the Bake Element
click here for instructions:-- Testing the Broiling Element
Then click here for instructions to Test the oven thermostat.
Then click here for instructions to Test the oven selector switch.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 08, 2010
How do I enter a time of less than 1 minute? Bought a brand new Oster Microwave model OGZJ1104. I cannot figure out how to heat up a cup of coffee for example - for 30 seconds. The user manual has
Usually a quick start button along with dial to scroll down from one minute.check if any buttons are push click to see if they extend away from fascia once pressed or try select one minute then use main dial anti clockwise to reduce time.hope this helps.
Feb 01, 2015 | Oster Microwave Ovens
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
Just purchased our Cuisinart Stainless Microwave, plugged it in, read the operational instructions and set the clock. As a test, we tried to heat water....does not work. Any suggestions?
Yes! Take it right back to the store for exchange, cause could be a bad magnetron "that heats food" and a couple parts that work together with the magnetron,or there may be issues with the keypad, none of these will be cheap to fix.
Jan 30, 2011 | Cuisinart CMW-100 Microwave Oven
I inherited a 1986 J.C. Penney Microwave and can't figure out how to program most of the features. I need an operating manual or a gnome.
The clock must be set before you can use the microwave. When you plug it in, it should read all zeros. Enter the time, and press "Clock Set." Time is in 12-hour format. There is no daylight saving time.
For basic microwave use:
1. Press "Power."
2. Press the keypad corresponding to the desired amount of power, e.g., "High," or "Defrost." (The numbers on the keypad have little words on them, like "Warm," "Med," and "High".)
3. Press "Time."
4. Enter the desired cooking time, e.g., "1-0-0" will be 1 minute; you could also do "6-0" for 60 seconds. You can do as little as 1 second, up to 99 hours 59 minutes. "1-0-0-0" would be 10 minutes. "2-0-1-2" would be 20 minutes 12 seconds.
5. Press "Start."
NEVER operate the microwave when it is empty. Put at least a glass of water in it. Never put a glass in it empty; make sure the glass has something in it, like water. Be careful when taking out a glass of water that's been heated; the water has been known, in rare instances, to "explode" and severely scald people.
It is okay to use the approved metal rack (it's coated with ceramic to prevent arcing) when using the microwave in microwave mode. Of course, the metal rack is also fine for use in the convection/combination mode.
"Defrost" cycles between microwave and nothing, microwave and nothing, microwave and nothing. You can hear the cycles. If defrost takes too long, try "Low." Try to avoid using "High," as it kills most nutrients in the food. Opt for "Medium" for slightly longer time; it'll be more evenly heated and healthier. Some things, like popcorn, require "high" power.
To stop the microwave in the middle of cooking, simply open the door. (There's no such thing as microwaves escaping the oven and bouncing around the kitchen and zapping you. I have a microwave tester, and the moment you open the door, all microwaves dissipate; the reading at the door is "Zero" once it's opened.) Or, press "Cancel." If you open the door, you may test the food, and if it needs further cooking, you may close the door and press "Start," and it will resume where it left off. If you're all done, just press "Cancel."
There is no way to disable the 5 beeps at the end of the cycle. If the baby is sleeping and you don't want to hear the beeps, simply open the door right before the beeps when the countdown is at zero. Pressing "Cancel" will give you one beep.
If you have the Combination feature, that cycles between microwave and convection heat, giving the best of both worlds (cooking inside with microwaves and outside with convection), for things such as a whole meats.
To use Combination:
1. Press "Combination."
2. Consult the chart on the microwave (below the keypad) and choose a number from 1 to 4, depending on what type of food you're preparing (i.e., lamb, pork, etc.).
3. Press "Time."
4. Enter the desired time, using the method described above.
5. Press "Start."
The Convection feature simply blows hot air across the food, at the temperature and duration that you set. It's a great way to toast slices of bread for the whole family at once, or bake a pizza.
To use the Convection feature:
1. Press "Convection."
2. Choose the temperature (the degrees are printed on the keypad, such as "350 degrees."
3. Press "Time."
4. Enter the length of cook time, using the method described above.
5. Press "Start."
Be sure to cover foods (with a paper towel or suitable plastic cover) that are prone to splattering. Don't let foods explode and get up into the motor. Clean the inside regularly with a soft sponge and mild detergent, NOT harsh or abrasive chemicals like Comet. Then rinse the soap off with a clean sponge.
Be sure to close the door firmly before cooking, but don't slam it. Slamming it will wear out the latching part, but being too gentle in closing the door may cause the safety switch to not engage, and the microwave won't work (it'll count down and the light will turn on but the motor won't run).
Note: the Convection feature uses more wattage than the microwave counterpart. The volts and amps are listed in the door jamb; multiply them together and you get total watts (although the actual amount will vary depending on your "power" settings).
Aug 07, 2010 | Microwave Ovens
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
May 30, 2008 | Sanyo EM-S8000 Microwave Oven
Ge microwave
try to hold the door closed when you first start it set the timer for 1 min with a cup of water inside press start and then hold the door in if it reuns your door is out of aligment or the interlock switch is popping open
Jan 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
