Question about Luminox Navy Seal Dive 3001 Wrist Watch
I just changed battery and the watch is still not keeping time correctly.?? Ju
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
I just replaced the battery on a fossil watch and it won't work. How to you reset it? or what else needs to be done? Please help me. thanks.
mcdevito75 here, Your Fossil watch should work with the battery change, of course it will need to be re-set. You"ll have to double check the battery install, make sure the battery contacts are clean, use a piece of paper towel and carefully clean the battery contacts. Hopefully your new battery is not dead. Another thing to check for, is that the buttons contacts are lined up with the quartz movement. While you double check your battery install, carefully press 1 button at a time, and make sure each button is making contact with the quartz mechanism, many times during a battery change to quartz movement may move just slightly but enough to keep the buttons from contacting the movement, this will keep the watch from working. Hopefully 1 or all of these is the answer for your Fossil watch.
Aug 22, 2010 | Watches
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
I changed the battery in my Fossil ladies watch and it still will not keep time. The hands are going around but it is not keeeping up with the time
mcdevito75 here, Just had the battery changed, if the watch was running fine before the last battery died, and now with this battery change the watch can"t keep time, try another battery as any Battery can be weak just from storage.
Jun 14, 2010 | Fossil JR8096 Wrist Watch
Second hand skips
This is warning: it's time to change the battery. Your watch is fitted with EOL (end of life) feature and this is how the low battery power is displayed. However, the watch will keep running correctly for about two weeks.
Rate me, please.
Jul 30, 2009 | Tag Heuer Watches
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Luminox Navy Seal Dive 3001 Wrist Watch Logo
97 people viewed this question
Top Luminox Watches Experts
Dennis Fitzsimmons
Level 1 Expert
ibewjm
Are you a Luminox Watch Expert? Answer questions, earn points and help others
