Question about Philips 170S5FB 17" LCD Monitor
Philips 170s LCD Backlight turns on only 1 sec and than the backlight off. The indicator lamps still green.... anyone can help me? thanks
After replacing 4 capacitors (all 25 V, 470uf) my Philips 170s turned on, but had the 1-2 second back light problem. I de-soldered and re-soldered all three (2 inverter and main power) transformer-back light works perfect now! I'm glad that did it-nothing like fixing one problem (no power) to find another!
Posted on Apr 07, 2011
  • Matt Apr 07, 2011
    Forgot to mention-this model, Philips 170S uses AT LEAST 3 different power supplies, maybe 4. I buy these all the time to fix and repair and have personally seen 3 different power supplies.
    From early 2004-October (ish) it uses a power supply that has 9 (yes nine) 25v 470uf capacitors-usually only 4-6 will be bad, but to be safe replace all 9.
    Late 2004 (November/December) to about mid 2005 (model mentioned in my solution is from February of 2005) have 4 25v 470uf capacitors-usually 3 of 4 are bad, but to be safe replace all 4. These I usually avoid buying, because the back light issue. This is the first time I tried to resolder the transformers-and it worked (unlike BenQ boards where you have to replace 4 transistors.
    The last power supply I seen is from mid 2005 to 2006 (never seen one newer than 2006). These are usually (if I remember right) 5 capacitors-25v 470uf
    I see more models with first and second generation power supplies. I only had back light problems with the 2nd generation power supplies. This model is also somewhat known for dying (pink tint) back lights...
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 08, 2010
My Monitor lost the image suddenly (black screen). When I turn it on, the LED indicate a green light the image appear for 1 sec and disappear. The ON OFF button still green though.... I can conclude...
First place to check will be the DC filter caps in the power supply, it can have circuits failure in the backlight inverter, or bad lamp assemblies (worst case).
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 19, 2010 | Acer AL2216W LCD Monitor
Philips LCD 170S Backlight problem.. only turns on 1 second and than the backlight goes off..... which component at the power supply board i can replace it?? thanks
It can be DC filters caps with leaking/bulging tops, or they have high ESR, bad transistors or IC or transformers in the backlight inverter circuits, bad lamps assemblies. Please read below and look at the pictures of bad caps, failed monitors, and troubleshooting guides.
Oct 08, 2010 | Philips 170S6FS 17" LCD Monitor
20" lg LCD backlight turns off after about 5 seconds of use.
First, check the power supply for the backlight. It's usually a 24 volt supply. Look for swollen caps. If that is ok, go to the inverter board and inspect for damage, ohm out the inverter transformers. Last is to test out the lamps seperately with an external inverter. If a lamp goes out this way, it is bad and causing the whole backlight to go out.
Apr 14, 2010 | LG 20LS7DC 20 in. LCD TV
My phillips 170 s monitor turns on for just 2 secs then the screen goes blank but the green light is still on like the monitor had not gone into sleep mode but is not displaying any picture can u help me...
More likely to have capacitors failure in the power supply, that will be the first thing to kook for inside, it can also be failure in the backlight inverter circuits, lamps. see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | Philips 170S4FG 17" LCD Monitor
My philips lcd monitor in side dim please healps model philips 170s
It sounds like the backlight has gone out. Replace the monitor.
Feb 06, 2010 | Philips 170S4FB 17" LCD Monitor
Screen goes black but still can see the desktop??
Yes this is a back-light problem. The fault could be the inverter board which supplies high voltage to the CCFL lamp or it could be a faulty CCFL lamp, this lamp is a mini fluro tube.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 12, 2009 | HP w2207 Monitor
Screen does not work
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 04, 2009 | Toshiba Tecra 8100 Notebook
Lcd screen d600 backlight turns off after 1 second
Check out
www.lcdparts.net
Jul 03, 2009 | Dell Computers & Internet
Screen goes off after every 2 secs. Pls help
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 12, 2009 | Sony VAIO VGN-N130G/W Notebook
Black screen when I turn on my computer
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Apr 02, 2009 | Toshiba Satellite A135-S2276 Notebook
Philips 170S5FB 17" LCD Monitor Logo
1,819 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
