Question about Brother MFC-8460N All-In-One Printer
What is a PF Kit 1? - Brother MFC-8460N All-In-One Printer
    Genius:
  • 1,354 Answers
Hi
PF Kit 1, is the Paper Feeding Kit, number one.
http://www.retrevo.com/support/Brother-MFC-8460N-Multifunction-Printers-manual/id/260ag208/t/2/
User manual above.Below is your service and repair manual.
www.scribd.com/.../BROTHER-MFC8460n-Series-Service-Manual
Below is what the kit is for another type of printer to give you the idea.
Posted on Oct 08, 2010
4 Suggested Answers
  • 215 Answers
SOURCE: Replace the PF KIT 1 On my MFC 8460 N
that refers to the automatic feed. in other words, your main paper cassette. the MP kit is for the manual bypass tray. if paper is feeding ok and your not having problems, you can reset the message by pressing "menu" " *2864" within 2 secs. now you are in maintenance mode. push "88" should show "parts replacement." using arrow buttons go to reset pf1 kit and press "ok" or "start" to reset. press "stop/clear" to back out to maintenance mode screen. press "99" to exit maint. mode. do not mess with any other settings in that mode as you could render your machine inop. however, you may want to reset the "fuser life" while you are in maintenance mode "88" as both of these messages are supposed to come up at 100,000 pages. chances are unless you've had fuser replaced, that message will be coming up soon also.
good luck,
razors
Posted on Mar 27, 2009
SOURCE: Resetting "Replace PF Kit 1" message
From what I could figure out from experimenting on an MFC-8860DN we are junking the procedure is:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
Not sure if this applies to the 8460. Maintenance menu feels dangerous, so use at your own risk.
Posted on Aug 07, 2008
komguy
  • 2306 Answers
SOURCE: pf kit 1
Brothermall.com has all the Brother accessories.
Posted on Aug 20, 2009
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
OK, we've got a second-hand brother 6050dn for our computer lab of about 35 computers. I've recently replaced the PF KIT For the MP drawer, but had trouble resetting it. Finally figured it out...
Replace the parts! If it is used you have no idea of how old the parts in it are even if they look good. The counters that turn these messages count sheets of paper not time and the parts may have moisture damage from sitting up.
May 02, 2017 | Brother HL-6050DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Where can i get a new PF Kit 1
You can get PF Kit 1 from an authorized service center of Brother. Click the link below to locate the nearest authorized service center in your location.
http://www.brother-usa.com/service/default.aspx
Hope this helps.
Apr 26, 2011 | Brother MFC-8860DN Printer
Have a Brother mfc 8460n reads replace PF kit 1 need to now what that is and how to replace it
Replace PF
Kit1
It is time to replace the paper
feeding kit for Tray 1.
Call Brother Customer Service to replace the
PF Kit 1.
You can read more by clicking here or copy and paste link to your browser address bar:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002000/cv_mfc-8460n_usaeng_user_d.pdf
then go to page 110 (you can type 110 at the top of the page to quickly get to the page)
I hope this helps. Sorry for the small font
Mar 10, 2011 | Brother Office Equipment & Supplies
I am trying to buy a pf kit 1 for my brother MFC 8670 DM. Where can I purchase this?
Just clean the pick up rollers with water + a dash of meths and a drop of detergent, de-fluff the paper separation shoe and rollers on the paper trays. Reset the PF Kit 1 counter (PF = paper feed) and carry on.
Aug 16, 2010 | Brother Office Equipment & Supplies
It says to replace the PF Kit 1 what is that?
solutions.brother.com/Library/pdf/pfkit_hl6050.pdf
Aug 04, 2010 | Brother MFC-8460N Laser Printer
Mfc-9420cn pf-kit2 reset, how to reset the counter after installing new kit
Press Menu/Set, 7, 4. Press down arrow to select PF Kit 2 and press Menu/Set. The confirmation message appears on display PF Kit 2. Press 1 to reset or 2 to cancel. PRESS 1.
Nov 03, 2009 | Office Equipment & Supplies
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
Brother MFC-8460N All-In-One Printer Logo
1,105 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
