Question about Technics SH-GE90 Home Equalizer
Hallo, all function works,but no signal and levels dont work.... I try cd,tape,tuner...but not is hapening. Please help
  • 1 more comment
  • bozilovic_de Oct 08, 2010
    help,hekp,help...........
  • Attila Jmbor
    Attila Jmbor Mar 17, 2014
    Detto :( HELP ANYBODY???
  • Attila Jmbor
    all function work, but no level, no signal, no picture,demo ok!
Detto :(
Posted on Mar 17, 2014
SOURCE: PROTECT Mode issue
Well let us start here ok one of my speakers blew the woofer blew out on my infinity speaker on the right side. Your amp will protect itself from being overloaded on one side of the power amp. This is what happened to me. So you should check your connections also this may also pose a problem. Make sure your speakers got 4 ohm or 8 ohm speakers switch dialed correctly on the rear of your power amp. check your ohm rating on your speakers also with a volt meter on your ohm setting which is very important which can damage your power amp if it is set wrong. You all have a great holliday season hope this helps.
Posted on Dec 15, 2007
OnlyOneN
  • 86 Answers
SOURCE: Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Posted on Apr 20, 2009
SOURCE: only the tuner will work, other functions will not
placed item in an electronic repair shop
Posted on Feb 05, 2010
dunnbiker
  • 8546 Answers
SOURCE: Dear Friends, I have this Audio system (tuner,twin
Get the manual for free at retrevo.com
Posted on Jun 10, 2010
dunnbiker
  • 8546 Answers
SOURCE: All systems function correctly but
Have you looked at the manual?
The product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
Google search: "(product) manual"
Posted on Apr 27, 2011
Turntable with built-in preamp won't play on phono channel on technics sadx950, but fine on CD channel. Is phono channel dead?
A turntable with a built-in preamp should not be connected to the phono input, because the preamp of the receiver or ampifier will be overdriven. The task of a preamp is to amplify the very low level of magnetic cartriges to the high level needed to work a line input and does some equalizing work to the signal. You can check if your turntable has a switch to disable the built in preamp (mostly they are low-end quality), otherwise connect the turntable to a high level input like "Tape", "AUX", "TUNER", "MONITOR", or "CD".
Nov 13, 2015 | Technics Audio Players & Recorders
How do I fix the FM tuner to pick up FM signals?
I think you might have fault in the FM tuner section. Most of these are done by a single IC, replacing that will cure the fault I suspect.
Jun 10, 2017 | Audio Players & Recorders
Hello i need help please..... I have a Technics SU-Z550 and SH-8055 Graphic Equalizer My amp has lost power... lots.! its working one channel louder than the other but the one which is louder still has...
If the same channel is dead on the EQ as is dead on the amp there may be a correlation.
Let's break this into its two parts.
1) SU-Z550: You don't say WHAT source(s) you tried to use on the CD/AUX, TUner and PHONO inputs. The external device itself could be the source of the low volume. Try swapping the Left and Right cables to see if it follows the source channel or stays with the amplifier channel.
Check the controls on the amp to make sure you understand each one's effect on the sound.
"PHONO" is literal and exclusively FOR A TURNTABLE - NOTHING ELSE - EVER.
2) SH-8055: Equalizers don't 'boost' sound, they modify its levels at various frequencies. To do that they should be connected into a Tape loop on your amp. OUTs go to IN's. Then you select the Tape Loop on the amp and that inserts the EQ into the signal path of whatever source you're listening to. It's actions are BEFORE any other amplifier controls such as volume, tone and balance. The EQ itself also has a Tape Loop to replace the one it occupies. Make sure it is not enabled unless you have a Tape Deck on it to use. Choose "SOURCE". The blue LED display is to show you frequencies are present in the program material.
Set all of its lighted band controls at midpoint prior to declaring it defective. EQ is like any spice - a little is good, a lot ruins the recipe.
Mar 21, 2011 | Technics Audio Players & Recorders
I have a A5 KENWOOD MUSIC PLAYER at ON position "Tuner" appears and tuner works .However input select don't work. Tape & CD are not selected. Could you please help me!..
Hi,This solution will be helpful to you;
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear humming on the radio channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
If you can't do this yourself, you can seek the assistance of a local radio repairer in your area.
Thanks and take care
Apr 01, 2010 | Audio Players & Recorders
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
How do i fix my radio in 1995 mercedes c280
hello,good day,try to check your power supply in your cd,pos. and neg. and or wake-up signal,to check this you need a multi tester,if you have a d2b connection try to check if their is a light when you operate your cd,ty
May 27, 2009 | 1995 Mercedes-Benz C-Class
How to play an ipod using the (Audio in) system
On the remote click 'Function' and itll scroll through the settings.
Tape, CD, Tuner, Audio In.
Choose Audio In.
I know this may seem annoying but itll work.
Apr 12, 2009 | Sony CMT-NEZ3 Shelf System
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Conrac Plasma Display 4042
Found cold soldering point on tuner board.
Sep 11, 2008 | Fujitsu Plasmavision PDS-4203 42 in....
Technics SH-GE90 Home Equalizer Logo
237 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
