Question about Neoware Systems e140 Thin Client - Thin Client - VIA - 512MB RAM - 512MB Flash - Windows XP Embedde... Network Terminal
E 140 i want boot with an (so ddr2 1024mb 667) Dimm .is at anable or must flash bios?
What is 3-3-2 beep tone meaning
System doeIf there is one DIMM in the system the memory row/bank may be disabled when there is a memory failure. The system will not boot because it has no memory to use. If the DIMM is replaced with one of the exact same type and size, then the system will continue not to boot. BIOS cannot tell when a DIMM has been replaced with one of the exact type and size, therefore BIOS believes it is still the bad DIMM and will not use it.
Here are two possible workarounds:
1. After replacing the defective DIMM, continue to reboot the system until you hear the "no memory" post beep sequence (3-3-3) during POST (no video display). After three (3) incomplete boots, a "062 three consecutive boot failure. Using default CMOS configuration caches are off" error will occur. At this point BIOS will go back to the default settings and begin to use the new DIMM. However, if you have disabled the 3 boot fail count (this setting may not be available in all servers) in Setup, then BIOS will not turn the DIMM row/bank back on.
-=OR=
2. Remove the DIMM. Power on the system until the "no memory" post beep sequence (3-3-3) is heard. The memory row/bank will now be marked as being empty. Power off the system and put a good DIMM back into the system. The memory DIMM row/bank is re-enabled and the system boots normally.
NOTE: If more than one DIMM (or more than one DIMM set) is installed in the server and one memory (or one memory set) row/bank is disabled due to a memory failure then, the user must go into setup and re-enable the row/bank after replacing the bad DIMM.
Additional information
s not boot after replacing memory DIMM Servers
Jun 11, 2014 | IBM Netfinity 5600 8664 Server
How to anable onboard video Intel ?
In is in BIOS. Press the F key noted during initial boot to enter BIOS.
Dec 20, 2012 | Intel D865GBF Motherboard
Asrock g31 m motherboard will only post if only one ram slot occupied , will not post if both slots are used , identical matched pair of ram ddr 667 800 mhz crucial ballistix both tested in another ri
I did some research. You didn't say what density the RAM was, but everything I can find on the Ballistix 800 MHZ DDR2 states that it runs at 2.2V. The standard for DDR2 RAM is 1.8V. You motherboard has both and AUTO and manual setting capability for memory (DRAM) voltage. It is possible that the AUTOP feature is not detecting the need for 2.2V, and that with only one DIMM installled, the memory marginally functions, but with the extra loading of the second it will not. Boot the system with the single DIMM, go to the BIOS, and set the DRAM voltage manually to the 2.01V setting (Verify by the part number of the RAM with the CRUCIAL website that is uses 2.2V before doing this). Once you have changed the voltage in BIOS, shut down and add the second DIMM and see if things improve.
Jan 16, 2012 | Asrock G31M-S Motherboard
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Im trying to stall 4 module by kingston khx6400d2ll/1g but the computer only pickup 2-248 g
Follow all the instruction bellow.When you install the ram follow the bus speed because memory speed can not excite the limit from 800mhz.
Elitegroup Computer Systems is known for their array of products from desktop computers to graphics cards and motherboards. At hand today we have their NF650iSLIT-A motherboard, which is powered by NVIDIA's nForce 650i Chipset and caters toward the computer enthusiast crowd, but can it really deliver?
Processor
· LGA-775 Socket for Intel Core 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium 4, Pentium D processors
· FSB 1333 (OC), 800, 667, 533MHz
· Supports Hyper-Threading Technology
Chipset
· NVIDIA nForce 650i SLI
· NVIDIA C55 + NVIDIA MCP51
Memory
· Dual-channel DDR2 memory
· 4 x 240-pin DDR2 DIMM
· Supports DDR2-800/667/533MHz
Audio
· Realtek ALC883
LAN
· Marvell 88E1116 Gigabit
System BIOS
· Award BIOS with 4Mb Flash ROM
Hope it will help you.
Jan 07, 2011 | EliteGroup NF650iSLIT-A (V1.0) Motherboard
I just bought a 2gb kingston memory pc2 5300 667 , my motherboard is Giga-Byte GA-VM900Mv.2 , it is written that , it should be compatible but when i put the ram inside , it just make blips that's all, do...
*********** supports,DDR2 667/533 up to 4GB Memory
Available with 2 DIMM slots supporting up to 4GB of DDR2 667 memory, GA-VM900M (Rev 2.0) provides the highest performance platform with the high-bandwidth (4.2GB/s) DDR2 memory solution.
You also check bellow the link for details.
http://www.gigabyte.com/products/product-page.aspx?pid=2407#ov
Regard's
Shibuda
Jan 03, 2011 | Gigabyte GA-VM900M Motherboard
I put 1gb memory stick first slot no boot up
the bios may not support the bus speed of the ram or they maybe some dirt on the brass contacts, clean these with a standard eraser, make sure its pushed into the dimm slot properly ( you'll hear 1 or 2 clip sounds ) check your motherboard manual to see if it supports the bus speed, if it does put your old ram back in boot windows and flash the bios ( download bios update from motherboard manufacurer's support website ), if you have no ram you have get some and flash through windows, you can also flash the bios via floppy ( THE "FLOPPY" METHOD IS NOT RECOMENDED ) if it goes wrong you'll kill the motherboard
good luck
Nov 14, 2008 | Siemens D1675 Motherboard
Neoware Systems e140 Thin Client - Thin Client - VIA - 512MB RAM - 512MB Flash - Windows XP Embedde... Network Terminal Logo
37 people viewed this question
Top Neoware Computers & Internet Experts
David Payne
David Payne
Are you a Neoware Computer and Internet Expert? Answer questions, earn points and help others
