Question about Bass Pro Boating
Steering cable is broken and needs to be replace. having a problem removing the cable. a detailed schematic would be helpful.
    Top Expert:
  • Bass Pro Master
  • 52,175 Answers
There is no such thing the cable unbolts from the steering head and the motor then ust pull the entire thing out . best to pull a rope thru with it tho to help get the new one in
Posted on Oct 23, 2010
My horn honks when I turn the steering wheel
You have to remove the steering wheel.The part your looking for is a spring loaded button that is held in place by a plastic clip. The clip has broken. Your best bet is to find one at a salvage yard. Good luck.
May 14, 2015 | Cars & Trucks
Cable seems to have broken and/or come off track. Rear driverside door. Where can I find a schematic?
You probably won't find a schematic, I would replace the regulator because when the cable comes off usually the teeth have broken off inside the mechanism and you can't replace that particular piece, that's the way it's made.
Dec 02, 2011 | 2000 Buick LeSabre
I have a problem. I have a 94 lincoln. It wont go into gear. The automatic gear shift drops all the way down with no shifting
Most likely, either the shift tube is damaged/broken or the screws have backed out of the lever at the end of the shift tube that the shift cable connects to. If the shift lever feels really "floppy", then you probably have a broken shift tube. You will probably have to pull the steering column down to get a good look at the shift tube to see if it is broken and to see how much play is in the shift tube bushings. Also look to see if the lever at the end of the shift tube is loose (shift cable lever).
A little word of caution: If you take the steering column down, be sure to disconnect the shift indicator cable first so it does not get broken. There is a tiny screw in the plastic braket that must be removed then the cable loop will simply slip off of the nipple on the shift tube arm.
Anyway, you will need a T-30 torx bit to work on the shift tube, the shift tube bushings and the lever at the end of the shift tube.
I made you a graphic below to help you understand what I am saying. Please note that it is NOT necessary to remove the steering wheel to do this, but you will need to remove the upper steering column shrouds if the shift tube bushings are loose.
Sep 23, 2011 | 1994 Lincoln Town Car
My 1997 grand marquic will not go into park, im mechanic enclined, is there something I can do w the linkage
Most likely, either the shift tube is damaged/broken or the screws have backed out of the lever at the end of the shift tube that the shift cable connects to. If the shift lever feels really "floppy", then you probably have a broken shift tube. You will probably have to pull the steering column down to get a good look at the shift tube and see how much play is in the shift tube bushings, check the shift tube to see if it is broken and see if the lever at the end of the shift tube is loose (shift cable lever).
Sep 20, 2011 | 1997 Mercury Grand Marquis
Broken shifter cable, how do i repair it
Put park brake on or block wheels, and shift into neutral (if possible), If not go to tranny and pop the cable off the tranny lever (pry off with screwdriver). Turn tranny shift lever, until it clicks twice, leave here for later adjustment. Follow the cable to the adjuster, pull out the flat steel retainer clip, pinch the sides to remove cable from bracket. Remove upper covers below the steering wheel. Remove kick panel below steering colomn. Remove cable from steering wheel shifter assembly (pry off and remove clip same as at tranny). Remove the side kick panel and follow cable along floor. You may find it easier to remove the driver seat (4 nuts on floor and wiring). Pull cable thru floor and replace. Reverse procedure to install. Lock the cable and clip at steering colomn, but leave the clip off at tranny. The tranny should still be in neutral. Now turn key to run and shift the shifter into neutral. At the tranny side cable there is a white square button, press in and lock cable to lever. install retainer clip. move shifter thru ranges and ensure it locks in park. Readjust if needed by pressing button and moving shifter lever on tranny.
Jan 27, 2011 | 1995 Chevrolet Silverado 2500
NEED HOW TO DIAGRAM OR SCHEMATICS FOR INSTALLING NEW SWITCH ASSEMBLY TURN SIGNAL WIPER 1995 FORD F150.
Removal
  1. Disconnect battery ground cable
  1. Remove the steering column shroud
  1. Remove two self-tapping screws that attach the multi-function switch to the steering column tube casting. Disengage multi-function switch from casting.
  1. Disconnect the two electrical connectors, using caution not to damage the locking tabs. Do not damage PRNDL cable.
Steering Column 2
Screw 3
Multi-Function Switch 4
Wiring to Multi-Function Switch A
Tighten to 2-3 Nm
(18-27 Lb-In)
Installation
  1. Install the two switch electrical connectors to full engagement. The wiring for the switch is to be routed under the PRNDL cable.
  1. Align the mounting holes on multi-function switch with the holes in the steering column tube casting. Install two self-tapping screws making sure to start the screws in the previously tapped holes. Tighten to 2-3 Nm (18-27 lb-in).
  1. For automatic transmission (7003), verify that the PRNDL adjustment is correct.
  1. Install the steering column shroud.
  1. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more for powertrain control module to relearn the strategy.
  2. Connect the battery ground cable.
  3. Check the steering column tube for proper operation.
I hope this helps, if you have any questions just ask
Jan 01, 2011 | 1995 Ford F150 Styleside Regular Cab
Airbag light on, cruise does not work
Hello. Welcome to FIxYa. My name is Toyota Ed, and I would like to assist you.
What you have is a broken 'spiral cable" (more commonly known as the 'clockspring'. This device transfers all of the steering wheel electrical functions to the steering column wiring harness.
To replace the spiral cable, you will need to remove the horn pad/air bag, and pull the steering wheel from the steering column. Note: You will be removing the air bag from the steering wheel. This requires some familiarity with the air-bag system and specific precautions, to remove it safely.
If you do not have the correct experience and tools to perform this task, I would suggest that you take it to a professional.
Aug 16, 2010 | 1996 Toyota Avalon
Broken manual clutch cable
You can go to www.Searspartsdirect.com and put you units model number in and order the cable yourself. They can ship it right to your house and you can swap the cable yourself with just simple hand tools.
You can see the details on the idler attachment in the parts schematic when you are ordering your new cable.
Good luck and be careful!
Jul 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do you remove or drop down the tilt steering column on a 1989 F250 4x4 7.3 diesel? I'm trying to replace the clutch and brake peddle support pivot bracket that is broken. I've gotten the bracket...
this is for 1996, don't have 89.
these may be steps you need
  1. Remove pinch bolt from steering shaft flex coupling.
  1. Disconnect shift cable from selector lever pivot.
  1. Remove shift cable from steering column lower mounting bracket by pushing tab on cable in and sliding cable off bracket.
  1. Disconnect ignition switch (11572) by loosening bolt and removing connector. The bolt is part of connector and can not be removed.
  1. While supporting steering column, remove four retaining nuts.
  1. Disconnect collapsible intermediate shaft from U-joint at lower end of steering column.
  1. Remove steering column from vehicle.
Oct 29, 2009 | 1989 Ford F 250
Broken plastic on minn kota steering cable
Hi!
Here's a schematic:
Edge 40
My guess is you need key# 80 (part# 2232360 cable drum pulley)
Good luck in your repair!
Mike
Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Boating Logo
87 people viewed this question
Top Bass Pro Boating Experts
ray gallant
obsteiner
Gordon Richard...
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
