Question about Bosch 24 in. SHU43 Built-in Dishwasher
Shu3302uc/u12 will not pump out - Bosch 24 in. SHU43 Built-in Dishwasher
    President:
  • 1,140 Answers
It's most likely a seized pump impeller/motor bearings or a burnt-out pump motor. There are some simple tests for the pump that anyone can do:
A. If your washer is full of water:
1. Select a wash program and press start. You should hear a low humming noise. If you can't hear anything, you probably need a new pump, but try the next step before you start buying parts or call an engineer.
2. Open the door and pull the lower basket forward or lift it out completely. Find and lift the float (the plastic dome/mushroom in the bottom of the washer) all the way up. Keep the float lifted and the dishwasher should pump out. Stop if/when you hear a gurgling noise as this means it's empty and pumping mostly air.
B. If your washer is empty of water:
C: If you can hear the low humming noise but the pump doesn't start when you lift the float:
1. lift the float again for about 1-2 seconds then let it drop again for 1-2 seconds. Repeat this 10-20 times and see if the pump starts. The repeated stop/start signals to the pump motor can sometimes free a seized impeller.
If the pump does start, keep lifting and dropping the float switch (1-2 seconds each time) to see if the pump starts every time. If it does, you should be OK to use the washer, but further action is needed to stop the problem returning.
When you've done all this, post the results here and I'll advise you what to do to fix the problem or prevent it from returning.
Posted on Oct 12, 2010
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Water doesn not drain out
The problem is most likely that there is still water residue at the bottom of your machine.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again. Also check that the drain pipe is not kinked or caught somewhere.
Feb 17, 2011 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Shu3302uc water comes out bottom of door when running
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
I have a Bosh SHU3302UC dishwasher that seems to be pumping all of the water out of the basin and will not advance to the next cycle. I know it is normal for the washer to pump to the drain at the...
Make sure you go to the Bosch website and follow the recall notice on this model...they have a recall repair notice that replaces the faulty controller on this model...the faulty controller may cause a fire so be sure to stop using the unit until you setup the recall repair appointment...I hope this helped! (We just found out about the recall...they never contacted us even thoughwe registered our unit when we bought it! Figures!)
Mar 07, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch dishwasher won't drain model SHU3302uc/17
probably something stuckin drain pump. remove plastic part in bottom of unit with a torc screw driver spin the propeller and your problemis solved. let me know if it works.:]
Dec 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Where do you put the jet dry?
ALONG SIDE THE POWDER DISPENSER- LIFT THE DOOR-
Jul 10, 2009 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch Dishwasher SHU3302UC manual
I have one it seems forever ,about 45 mins
Apr 22, 2009 | Dishwashers
Old plustek opticpro u12 scanner software, new Vista engine.
i have old plustek opticpro U12 Scanner software,
rigister s/n:52D11F002984
Dec 02, 2008 | Plustek OpticPro U12 Flatbed Scanner
Spare Part
you can build your own using any old 12v 1250ma+ psu
guid on this site
kpm
Apr 18, 2008 | HP Scanjet 5470c Flatbed Scanner
Bosch 24 in. SHU43 Built-in Dishwasher Logo
350 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
