Question about LG Dryers
LG dle2516w lg dryer wont turn on - already checked the breaker, and unplugged it and plugged it back in.... any other suggestions?
SOURCE: LG WFT1081TP Top load washer
I WANT KATALOGE WASHING MACHIN MODEL ; WF-T1081TP BECOUSE MY KATALOGE MISSE
Posted on Jul 13, 2008
  • 52 Answers
SOURCE: NEED TO REPLACE HEATER ELEMENT
You should be able to take off the back panel and see it. The heating element is USUALLY an easy fix. Let me know if you need any further help.
Posted on May 04, 2009
  • 84 Answers
SOURCE: When I turn on my dryer on it gives a rattling/vibrating noise.
There maybe a lot of lont build up in the blower wheel housing. Take off bottom panel and take apart the blower wheel house and check for any lint build up....if it check ok, your drum rollers maybe worn....try checkin the blower wheel housing...hope this helps
Posted on Aug 04, 2009
  • 108 Answers
SOURCE: lg dryer dle2516w doesn't heat up. everthing works
the heating coils may be burned out.
Posted on Dec 22, 2009
omaharox
  • 166 Answers
SOURCE: LG Dryer DLE2516W contiuously trips breaker but
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Posted on Jan 20, 2010
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
The dryer won't turn on. I have tried the circuit breakers, unplugged and plugged back in the dryer. The dryer was bought in March of 2008.
Check the power cable connection inside the dryer. If that is OK then the defect lies with the power cord. Check it is not twisted or cut in the body of dryer.
Jan 23, 2010 | LG DLE2516 Electric Dryer
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Jan 04, 2010 | LG DLE2516 Electric Dryer
LG DL2610 model does not dry, it turns on properly
Check your vent. Make sure there is a strong flow of air out the outside vent cap. If not, your dryer is not able to get rid of the moisture. Check for lint build up inside vent piping and for crushed flex vent pipe behind dryer which would obstruct air flow.
Sep 16, 2009 | Dryers
Aug 04, 2009 | LG DLE2516 Electric Dryer
May 04, 2009 | LG DLE2516 Electric Dryer
LG DRYER DLE2516W
The timer is not advancing itself to the OFF or open cam, which opens points and stops the timer motor.
You will have to replace the timer to correct the issue.
Dave E. (Illeagle)
May 30, 2008 | Dryers
Dryers Logo
201 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
