Question about Toshiba DVD Recorder
I have a Toshiba D-R17DT dvd recorder. With the HDMI out it wont let me record from it saying about copy protection !! Why is this ?
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: Recording from DVR.
There is a firmware update posted on the Sony support web site. It takes care of the copy protect error. However, i have encountered an error where the recorder doesn't identify the input signal. It posts the message "waiting for input signal." I have no solution for this one yet.
Posted on Jan 27, 2008
marked
  • 6487 Answers
SOURCE: A BTPASS CODE FOR COPY PROTECTION FOR A LG RH2T160 DVD RECORDER
Try this one:
Press Home on remote.
Go to setup
Scroll down list to highlight lock icon
Press 0 seven times
You will get a message saying "Congratulations Region Change Free [Yes]"
Press enter on remote.
Hope that helps........
Posted on Aug 26, 2008
ohms
  • 1879 Answers
SOURCE: Copy by-pass protection LG RH2T160 DVD Recorder
I already tried googling that and nothing shows up. if there's such code, LG knows it.
Posted on Sep 09, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
I have an Magnavox vcr/dvd recorder combo,that used to let me record the higher channels.it won' t do it now sense,I just updated my old box tv to a flat screen,and now I can't record.It say error 26
This message most often occurs when the TV signal has copy-protection on it. Please add a comment with the details of your TV signal (set-top box and provider or OTA antenna).
If you are now using an HDMI cable between a set-top box and the new TV, then you may need to unplug the HDMI cable to avoid the copy-protection information blocking the DVD/VCR recording functions.
I hope this helps.
Jan 09, 2018 | Magnavox Televison & Video
Removing regional code toshiba d-kr10
will it copy from another sorce? if the programing from your cable box is copy protected it will not let you record.
Feb 06, 2013 | Toshiba D-kr10 Dvd Recorder With 1080p...
Dvd says cannot record copy protected movie how to fix ?
Depends what you are trying to record? Some TV stations have protection built in so you cannot record. If you are trying to copy a video from VHS to DVD and it's a commercial movie etc then it won't.
You can get a "box" that will get rid of copy protection signals, but only from outside the unit sources. Internal dub to dub protected sources cannot be copied.
Feb 04, 2013 | Samsung DVD-VR357 Tunerless DVD Recorder...
Can't get my DVD recorder to record shows from my ATT U-Verse DVR.
There may be copy guard protection to prevent transfer of information.
Mar 29, 2012 | Toshiba DR-430 DVD Recorder
Won't allow recording ESPN and other cable channels.
It sounds like the programs are copy protected. I've had the problem with an E 27 error, but I've had success with recording other programming.
Jun 14, 2010 | Toshiba DR420 DVD Recorder
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
Mar 11, 2009 | Toshiba D-VR4 DVD Recorder/VCR
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Copy Protection Signal
"Copy Protected Signal." Means that the data you are trying to Ahem... "Copy" probably has copy protection inbuilt into the disk & data. This is done to stop copying of pirate DVD's etc. Part of the DRM put out by the TV/Music/Film industry. There are programs that can strip protection and enable one to copy said DVD's.. AnyDVD is one that springs to mind, as does Dameon Tools, and many others simply Google for them.
Jul 11, 2007 | Panasonic DMRES15 DVD Recorder
Toshiba DVD Recorder Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
