Question about Hisense Televison & Video
How do you set tv for rabbit ears? hisense 24" lcd
  • 55 Answers
Hook up ears and run digital channel set up in menu
Posted on Oct 08, 2010
Can I use rabbit tv on my Hisense led plasma tv
Yes. You can place your rabbit TV; over your plasma TV.
May 11, 2017 | Hisense Televison & Video
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
How to hook up T V ears on 32 " element tv ( elucfw329 )
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Jan 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
Add channel to TV that I deleted (using rabbit ears w/ newish digital TV)
Confirm with another set if signal for that channel is still there or not--also if not too large a set take it to someone who gets the channel and add that channel back into the memory with the remote.
Oct 30, 2012 | Samsung LN19A330J LCD TV
Rabbit ear hook up how do you program the tv to work with broacast tv signals?
use your tv remote and click menu, then click setting, or "TV" if tv is an option. choose "channels" or something of that nature, then run a channel scan. if you're using bunny ears, set the option under channel search to "air". hope it works out for ya! :)
Jan 22, 2011 | Sylvania 6615LE LCD HDTV
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
No HD
Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
Mar 15, 2008 | Protron PLTV-4250 42 in. LCD Television
Televison & Video Logo
127 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
