Question about Acer Computers & Internet
Step by step instructions to put memory into laptop
    Sergeant:
  • 458 Answers
FIRST UNPLUG THE LAPTOP AND TAKE OUT THE BATTERY.
Hold onto the laptop while you work with it to discharge any static electricity.
Take the cover off of the back that houses the memory. Remove the old memory and replace it with the new memory. You might have two slots for memory. If you do you can put two in at a time. There also might be a stick of memory under the keyboard. That is harder to do and I would advise you to leave it alone unliss you know exactly what you are doing. There are a lot of screws and tiny parts that can be lost and/or broken. Download the manual for the laptop and it should have the directions in it also.
Rate me if you like my answer.
Posted on May 29, 2008
How to install memory syick [ram]
Hello, its really easy, just follow the steps:You can also checkout this site for step-by-step instructions:
How to install laptop memory
Have fun.
Jul 05, 2011 | Kingston 2GB PC2-5300 DDR2 Laptop Memory
How to put in new memory on my acer 1691 notebook
Laptops are notoriously difficult to upgrade with one exception. Luckily, that exception is one of the quickest and best ways to improve the performance of your Acer laptop. Adding more RAM will speed up your laptop and boost its performance. Be aware, though, that Acer is also notorious for its "hidden memory compartment" under the keyboard.
Adding RAM to Your Acer Laptop
  • Step 1 Unplug your laptop from the AC power source and remove the battery.
  • Step 2 Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
  • Step 3 Locate the memory access door for the main memory module. It should be on the back of your computer.
  • Step 4 Unscrew the memory access door and remove it.
  • Step 5 Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
  • Step 6 Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
  • Step 7 Align the new RAM module with the tab in the connector slot.
  • Step 8 Slide it firmly into place and gently rotate it downward until it clicks into place.
  • Step 9 Replace the memory access door.
  • Step 10 Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use.
  • May 20, 2010 | Acer Aspire 1691WLMi PC Notebook
    Where is memory located in compaq n610c laptop
    It is located in the lower panel underneath a panel the has a icon of two rectangular boxes put together you need to open the screw and you would find the RAM or the memory located there.
    Feb 18, 2010 | HP Compaq nc6000 Notebook
    Is the ram of dv2000 expandable?
    Yes up to 2GB
    Standard memory
    1024 MB
    Memory type
    DDR2 533 MHz
    Memory layout
    (2 x 512 MB)
    Maximum memory
    Supports up to 2 GB DDR2 memory
    any further help let me know
    Nov 06, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
    Just need to know how to insert a new memory stick I bought for my dinosaur 3000. Fry's salesman said I could find a step-by-step instruction. THX!
    Dinosaur, as in a old acer aspire 3000 or what?
    Most likely two screws on the bottom of the laptop that hold the memory cover closed, inside you will find 1-2 memory modules, you may have to remove one of the old ones and then install the new one, or if one is free install the new one there.
    Sep 11, 2009 | Acer Aspire 3000 Notebook
    Compaq armada e500 memory
    memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
    Nov 13, 2007 | Compaq Armada E500 Notebook
    Acer Aspire Notebook 3694 wlmi
    First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
    1. Turn off the computer and remove all power cords from the computer system.
    2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
    3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
    4. Remove the panel from the laptop and set aside.
    5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
    6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
    7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
    8. Replace the memory access panel onto the laptop computer.
    9. Replace any screws or fasteners that hold the panel in place.
    10. Replace the power cord and power up your computer system.
    Step 1:
    Step 2:
    Step 3:
    Step 4:
    Step 4_1:
    Step 5:
    Step 6:
    Step 7:
    Oct 26, 2007 | Computers & Internet
    Computers & Internet Logo
    35 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
