Question about IBM Proprinter II Matrix
Column1 column2 column3 column4 Row1 @ * 2 Z Row2 S K ? $ Row3 I P Z + Row4 # 8 F Q Questions r as follows ( not same questions but same type) 1.if column1 , Column 4 r interchanged and row3 , row4 r interchanged and diagonal elements from top left to bottom right r written in reverse order then what is the element in row1 and column 1?
Intel inc og8310 drivers
You can get the drivers from here:
http://www.dell.com/support/drivers/us/en/04/DriversHome/NeedProductSelection
1. Select "Choose from a list of all Dell products" in the "NO"
column
2. Hit "continue" button
3. Select "Desktops"
4. Select "Optiplex"
5. Select "OptiPlex GX280"
6. Now choose the "operating system" you need the drivers for
7. Download the drivers you need.
When Installing:
They need to be installed in a specific order - very Important.
1. Chipset - so download and install this first.
2. Video
3. Network
4. Sound (Audio)
5. Modem (communications) - If you even want a modem
Jun 20, 2012 | Dell Computers & Internet
78 f250 died while driving slow and wont start. getting fuel, coil fireing didnt check rotor or plugs, spin it over try to give it trottle backfires out tailpipe
Three things to try:
1) replace ignition switch located in column
2) replace ignition control module on firewall
3) if those don't work, check the pick up coil in the distributor
hope that helps
Sep 18, 2011 | 1982 Ford F 250
Find the equation of the line that best fits on a ti 89 calculator
I assume you know how to enter data in your calculator.
In Home folder run F6: NewProb to reset the configuration.
Press Apps, and select 6: data/Matrix editor. Select a new data set
Give it a name: here testing.
Press OK/ENTER, The data entry screen opens, enter your values.
When you finish press F2.PlotSetUp.
b142867.jpg.
Press F1:define to configure Plot1. Choose Scatter, then choose a mark for the data point. I select 5:Dot. and press [ENTER
Select the data column X=c1, Y=c2
Press ENTER to save configuration. Press [CTRL] [GRAPH] On my TI92 the CTRL key is the [Diamond] key. On the following graph I changed the mark to a cross to see the data point better. I also played with the window dimension. You can also do that with ZoomStat. Th graph remind me of a parabola (I know I chose the exact values)
Now we have to find the equation that fits these data best.
You press APPS 6:Data/ Matrix editor but you select current to return to your data set. You are taken to the data entry editor (Figure 3 above). In that screen Press F5:Calc to edit the type of statistics you want
On first line select QuadReg quadratic regression, X is from column1, Y is from column 2. Store RegEQ The regression equation in say Y1(x)
Press ENTER to save to get the Regression Equatio. Here it is
As you can see I cheated: a perfect parabola. R^2 =1.
And here the best fit represented on same graph as the satistical data
Usually you have to try different regression models, until you find the one that fits best the experimental data.
As you can see I have gone a long way out of my way to show you all the steps.
I hope it helps you and others who wonder how to do regressions on a TI89. If someone does not understand these explanations, the blame does not rest with me.
Oct 21, 2009 | Texas Instruments TI-89 Calculator
I have been trying to get this formula or function to work all day
You might try looking/posting on forum sites like http://www.mrexcel.com/archive/index.html
That has helped me with different things, especially correct syntax.
MM85
Jul 27, 2008 | Microsoft Computers & Internet
66 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
