Question about HTC Touch Cell Phone (Unlocked) - Soft Black
Actually my touch screen is not working and touch screen is lock y i want to unlock it from the keys given
  • 25 Answers
You have to take it to a servise and sort it out there
Posted on Oct 08, 2010
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
Locked phone
  • You Have to Reset Your Phone,to Reset Please Follow these Instructions,
  • Unlock the touch screen by dragging image_thumb17.png to the right or press the Unlock Key ( image_thumb18.png ) on the right side of your phone and touch the Menu Quick Key image_thumb19.png.
  • Touch Settings image_thumb20.png.
  • Touch Phone Settings.
  • Touch Security.
  • Enter the four-digit lock code.
  • Touch Reset Default.
  • After reading the warning message, touch image_thumb21.png.
  • Touch Revert.
May 13, 2013 | Cell Phones
Motorolla ex119 mobile touch screen working problem
HOW DO MY PHONE UNLOCKED PERMANTLY BECAUSE MY PHONE TOUCH SCREEN IS NOT WORKING
Jun 07, 2012 | Motorola Mobility Ex119 Ex-119 Dual-sim...
How do i un freeze my nokia twist
  1. Make sure that the keys are actually locked. If you attempt to unlock a keypad that is not locked, nothing will happen. Look on the phone's screen for the key icon that indicates the keypad is locked. If you try to press any of the keys and the word "Unlock" appears on the screen, your keypad is definitely locked. If you do not see the indicator but are unable to use the keypad of your Nokia 6085, your battery could be dead, so try recharging it and then see if the keypad works.
  2. Enter the unlock sequence. If the key indicator appears on your screen, you need to enter a simple sequence of keys to get the keypad working again. For the Nokia 6085, select Unlock and then quickly press the * key. If you wait more than 1.5 seconds to press the * key after selecting Unlock, it will not unfreeze the keys so make sure you enter the sequence very quickly.
  3. Turn off the automatic keyguard. If you are tired of having to unfreeze the keys every time you want to make a call, you can program the Nokia 6085 to always remain unlocked. In the menu, go to Settings, then select Phone, then select Automatic Keyguard and choose Off.
Mar 01, 2012 | Nokia Cell Phones
My son dropped my lg ms690 android phone in the toilet I got it out right away and took battery out and let it dry out but now the touch screen is locked and is not sensitive to touch it is non responsive...
Hello and Welcome to FixYa
Ma'am The situations you are telling seems to be the problem of hardware, Actually water damages touch senses very badly, I had same experience with my other customers and i suggested him solution.
Actually the problem is that the hardware of touch screen is very sensitive when water enters inside the Cellphone it disable the touch, As your phone is locked so its not allowed you to unlock it, In airplane mode phone is almost free from the main system because there is not a network integrate that time. So its may be allowing you to response in Airplane mode.
If you are familiar with hardware issues of cellphones then open the cellphone and you need to dry the phone from inside, It will solved problem automatically but if you are not familiar how to open it then my best advise is to consult LG authorized service center. They will solved your problem. I wish i could be there for you to fix it but now you must do it as i advised you. Try this i hope it works
Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 23, 2011 | LG Cell Phones
My arcos no working teh touch screen so bad because for example u press a dive k d q etc
I believe you are trying to say that your touch screen isn't working. Your touch screen is probably locked. Its similar to a button hold lock, when this is activated, you can't press any buttons do anything unless you unlock it. To unlock the touch screen, press the ON/OFF button (don't hold the button for a long period of time. A message will appear on your screen asking for your conformation (approval) to perform the task. If that doesn't work, tap the TOOLS option, then select SETTINGS, and choose SCREEN. Once you've done that, choose the "Touch Screen Calibration" button and follow on-screen instructions given. If the second solution doesn't work, the "Touch Screen Calibration" option can be forced by using a feature called 'System Recovery'. To do a system recovery, Press and hold the Power button, then the Volume + button as soon as possible until you see a white screen, as system recovery is beginning. While this is happening, you will not be able to use the touchscreen to navigate between items. In order to navigate between items, you will have to use the Volume + & Volume - buttons and use the Power button to validate your selected task. The system recovery feature gives you a lot of options. Select the "Touch Screen Calibration" option and follow on-screen instructions given. I hope this activates your touch screen again.
Mar 22, 2011 | Archos 7 Digital Media Player
My thermostat is not working. It might be locked. It's blinking with all of the information it holds flashing on the screen. The part number is: tstatccnhp01-c My heat is no longer working. Can you...
Instructions
  1. 1 Unlock a partially locked screen by pressing any locked key, which will bring up the "Screen Locked" message. Next press an unlocked key, which will likely be the temperature up and down arrow keys. This will unlock the screen.
  2. 2 Press the "System" key from the home screen. Five blank touch keys, flanked by the "Done" and "Cancel" keys, will appear. Hold down the middle key for about five seconds. The Advanced Settings menu should come up.
  3. 3 Change the User Setup Number, found in the bottom left of the screen, by pressing the middle arrow keys up or down. Set the number to "0670," the universal unlock code.
  4. 4 Turn to the arrow keys on the right side of the screen. Press the keys up or down to change your options. Selecting the number "0" will unlock the screen, while choosing "1" will partially lock it. You can fully lock your screen again by selecting.
Read more: How to Unlock the Screen on a Honeywell Thermostat ' eHow.com http://www.ehow.com/how_7667347_unlock-screen-honeywell-thermostat.html#ixzz19ktDWSq8
Jan 01, 2011 | Heating & Cooling
My touch screen isnt workin its says press and hold lock key to unlock what does that mean
It sounds like your screen is just locked..You have to hold down the lock/unlock button in order to unlock the touch screen.
Jul 06, 2010 | Samsung SGH-A877 Impression Cell Phone
Screen locked on my htc mp6900. I don't know how to unlock it because the touch screen is not working. How do I get the touch screen to work?
You probably need to replace the digitizer pad. That's the outer screen. The actual touch screen. I did mine today, works great!! Easy to replace on your own,also. I got it for 11 dollars on dealxtreme.com good luck!!
Apr 20, 2009 | HTC Touch Cellular Phone
Unlocking the screen on 6800 mogul, with cracked screen
Remember that the * key is a 2nd function and you must press the blue or shift key and then the * key. i ahd the same problem for 2 days but persistance did it!
Mar 19, 2009 | HTC PPC-6800 Smartphone
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
47 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
