Question about Kohler 17 kW Emergency Power System - 17RES-L
I need to charge the battery on my 17RES to about 16V to get it to start. 14.5 V will not cause it to fire. The control board briefly flashes SCF0, and the readout shows about 10V when running and I know the battery is much higher. The connector on the control board shows the high voltage at the same time the display is showing the lower voltage. New battery, starter contact has the full voltage. Almost seems as if something is preventing the firing from the control board.
2 Suggested Answers
  • 142 Answers
SOURCE: Engine does not turn over fast enough to start
May be the problem is the hard turning of the motor. It may be caused by segments broken, bearings defective, oil problem etc.
Posted on Jul 02, 2010
Wheelchair runs fine after charging but only after 1 day 6hrs use it stops with a jerk and then controller lights start blinking.
Abdus,
Thank you for all the information, number one, charge with the joystick on for 12-14 hrs. there is a circuit in the joystick that can cause problems, in order to reset it you will need to charge it like this. The batteries will last longer if the batteries are charged every night that it is used during the day, also, instills good charging habits.
The blinking is a flash code, count the flashes, and refer to the owners manual for meaning. The joystick maybe failing or the controller or both. Motors may need to be cleaned out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 12, 2016 | Health & Beauty
Camera will not switch on in operate mode.
Can you test the voltage of the charged batteries, often they will not hold full charge for several reasons, age, factory imperfection, over use, haven't been allowed to discharge fully before recharge, dirty battery contacts, if you can, try new non rechargeable batteries, often cameras get temperamental about batteries after some time, use a metal tarnish cleaner with a cue tip, on the contacts, or pure alcohol, if bad, use plastic scourer, cold batteries don't work well, warm them in your hands if cold.
Nov 28, 2014 | Samsung WB150F SMART Long Zoom WiFi 14...
My ford explorer 2005 lost all control panel activity tonight. The lights are still all on, however none of the gages are working. The radio and windows would not work as well. The car starts and stops...
I would say your battery is gone,if original
Next ,once you have a good battery,I would
test the charging system
eg: alternator for 14 + volts eng running
Dec 21, 2010 | Ford Explorer Cars & Trucks
4210 Starts for a second and then stops
This will be one of, or both of, the following.
Bad battery will not take a charge and cause this condition.
NOW... Why will it not take a charge. either the battery is bad, and CAN'T take the charge the machine is giving. OR the charging circuit is fired on the main board. Sometimes a bad charging circuit will also cook your battery causing both to be screwed.
But it is a common problem with the board going bad. Some people purchase an external charger for the battery and then swap it into the roomba when charged. But this kinda defeats the automated controls. The fried charging circuit also will drain the battery when it isn't turned on. I have repaired a number of charging circuits on these units
Jul 05, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Manual
use this site and put 220 in the search box - your explorer 220 is found and you can download the user guide http://www.plantronics.com/north_america/en_US/support/manuals.jsp;jsessionid=83D442E12D37E83038D66C83670075A9.delta#results
see page 14 for details of the lights
  • Powering on Blue flashes
  • Powering off Red appears and goes off.
  • Charging battery Red solid light.
  • Low battery Red flashes.
  • Pairing mode Blue/red flashes.
  • Missed call Purple flashes. Single press the call control button to cancel.
  • Ringing Purple flashes. Briefly press call control button to answer the call.
  • Press call control button for 2 seconds to reject the call.
Apr 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My wife plugged a wrong charge (16V instead of 12V) to the Panasonic LS82. It wasn't turned on. The charging light was flashing, now it's dead. Is the battery pack dead or the whole DVD player? Anyway to...
Ur wife overload,the power board,and also kill the litium battery.This DVD player exspensive?Not,not worth repairing,must take to shop,probally must order the power board for replacement,to repair for u.
Apr 06, 2010 | Panasonic DVD-LS82
Not charging {I think }
I assume that you have a meter of some sort as you stated the voltage as 16v.
test the battery voltage with the engine off, should be 12.4 volts or there abouts.
then test it again with the engine running, 14 to 16 volts should show a charge. Turn it all off and leave for 30 mins to an hour and retest the battery with the engine off, if the reading is lower than 12 volt then the battery is faulty.
May 02, 2009 | 1983 Honda XL 125 R
Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Dec 28, 2007 | HP Photosmart R607 Digital Camera
Veiwsonic 924x
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Dec 27, 2007 | ViewSonic VX924 19" LCD Monitor
Kohler 17 kW Emergency Power System - 17RES-L Logo
64 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
