Question about SanDisk Sansa e200 MP3 Player
Music Folder!! Help my music folder does not show up for some reason and i can not delete or drag music out of my mp3!! Please & thank u!!
  • 8,596 Answers
Try the Sansa Recovery Tool from Sandisk's website to see if it will download the missing folders/info.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
How do i delete all the songs off my sansa e260?
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselfs then format a couple of times hope this works
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer2.gif first
Dec 20, 2010 | SanDisk Sansa e260 MP3 Player
I downloaded a music cd into a folder under my music. How do I transfer the music from the folder to my mp3 player?
Use the software that the MP3 came with or open with folders and drag the music into the MP3 folder. Please make sure you have read the manual on what type of music file it takes and make sure you have installed any software that has come with the MP3.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | Audio Players & Recorders
The tracks all say bad track and will not play, how do I fix the problem?
These tracks are corrupt Delete all Format
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Try and drag and drop2.gif from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Oct 24, 2009 | SanDisk Sansa e260 MP3 Player
HELP! i keep gettin ALADsong title
format And Try and drag and drop from your music folder to the media folder on the player make sure usb mode is mtp this will show you all the folders Use your windows explorer for the transfer... much easier.....open windows explorer click on folder this will bring All folders up on the left...find the sansA And formAt with A right click....left click on mediA hold and drag to sAnsA mediA folder
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
Can't delete duplicate tracks!
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Apr 17, 2009 | SanDisk Sansa E280 MP3 Player
No music file showying on MP-BT1
Just check they are not located inside a folder on your MP-BT1. If so, drag files out of their folders and then delete the folders and MP-BT1 will then recognise them!
Jan 07, 2009 | Tascam MP-BT1 MP3 Player
Music folder won't show up.
TRY THIS LINK :
http://www.sandisk.com/Retail/DriverDown...
OR TRY THIS :
In your player's menu, go into Settings, choose USB mode, and change it to MSC. This will cause the player to show up in Windows as if it were a flash drive, and you can add and delete music by drag and drop into the player's Music folder. Hope it helps and please rate , thanks AJ
Jun 30, 2008 | SanDisk Sansa e250 MP3 Player
Sansae250
connect to your pc using usb connection. sansa should be recognized as storage media drive. navigate to the drive. Drag and drop files to music/video folder. Enable show hidden files and folders in your windows folder settings. Tools>Folder Options>View. Some of the folders are hidden. You can delete the preloaded music also.Some of them are in the radio folder.
ThePlague...
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Coby Mp3 player
For your music, go in MTPMEDIA\Music folder then, create an another one and drag all your files in. Go in the new folder arranger your files alphabetically and drag them back to the music folder. Delete the new folder you created before and the next time you will look at your songs from your player, they will be in alphabetical order.
Dec 20, 2007 | Coby MP-C7085 MP3 Player
Deleting songs
If you want to delete songs off your Sansa you just need to go to "MY COMPUTER: And find the sansa drive open it then look for the music folder.If you dont see a music folder you will need to go to the top where it says tools>then >folder options>then click on show hidden files> you should now see the music file. Go into it and simply delete any songs you don't want.
Oct 19, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
