Question about Pitney Bowes AddressRight DA300 Printer
How do i cancel a print job? - Pitney Bowes AddressRight DA300 Printer
    Sergeant:
  • 157 Answers
Method A: Press the cancel button or use the cancel menu
command on the printer
loadTOCNode(2, 'resolution');
The most obvious way to cancel a print job is to find a cancel button or a
cancel menu command on the printer and to press it. So, if you have not already
done this, try this method first.
If this method worked for you, you are
finished with this article. However, you may want to read the "Prevention tips"
section to avoid this problem in the future.
If your printer does not
have these items or if this method did not work for you, try Method B.
Method B: Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this
cancels the print job.
If this method worked for you, you are finished
with this article. However, you may want to read the "Prevention tips" section
If this method did not work for you,
turn your printer off, and then try Method C.
Method C: Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel
printing.
But what exactly are you trying to do? Are you trying to cancel
printing only a single document, or are there other print jobs that you want to
cancel? And are all the print job yours, or are there print jobs that other
people have sent to the printer? If you have to cancel documents that other
people have sent to the printer, you must have Computer Administrator status or
you must have permission to cancel the print jobs. If you are using your own
printer, you most likely have Computer Administrator status. If you are printing
to a shared printer, you might have to ask the system administrator to cancel
the print job for you.
To cancel one or more print jobs, follow these
steps.
  1. Click Start, and then click Run.
  2. In the Open box, type control printers, and then click OK.
  3. Right-click the icon for your printer, and then click Open.
    • To cancel individual print jobs, right-click the print job that you want to
      cancel, and then click Cancel.
    • To cancel all print jobs, click Cancel All
      Documents on the Printer menu.
Note If you cancel a print job that you did want to
print, make sure that you send the print job to the printer again.
If
this method worked for you, you are finished with this article. However, you may
want to read the "Prevention tips" section to avoid this problem in the
future.
If this method did not work for you, make sure that your printer
is turned off, and then try Method D.
Method D: Stop the print spooler and delete all spooled
files
If you tried Methods A through C and you were not successful, Method D should
work for you. If you came to Method D immediately only to delete a print job,
some of what we say here might not apply to you, so please bear with
us.
Method D is somewhat more complex and will require a bit more work
than the other methods, but don't worry. Method D looks much more difficult than
it really is.
First, in case that you don't know how printing works, here
is a short explanation. Print jobs are sent to the printer as spooled files.
This means that the files are put in a temporary location so that the printer
can access a print queue and print jobs at its own speed. If you stop the
spooler and its files, most of the time, you both cancel printing and delete the
print job.
Note To use this method, you must have Computer
Administrator status. If you are using your own printer, you most likely have
Computer Administrator status. If you are printing to a shared printer, you
might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
loadTOCNode(3, 'resolution');
To stop the print spooler and its files, we will have you create and run a
script file that will automatically stop the service. This sounds difficult, but
it really isn't. Just follow these steps carefully.
  2. In the Open box, type notepad, and then click OK.
    Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
  1. Carefully select (highlight) all the following text:
    net stop spooler
    del
    %systemroot%\system32\spool\printers\*.shd
    del
    %systemroot%\system32\spool\printers\*.spl
    net start spooler
  2. Right-click the text that you selected, and then click Copy.
  3. In Notepad, right-click in the blank document, and then click Paste.
  4. Carefully select (highlight) all the following text:
    C:\DeletePrintJobs.cmd
  5. Right-click the text that you selected, and then click Copy.
  6. In Notepad, click Save As on the
    File menu.
  7. In the File Name box, right-click, and
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it,
you will copy and paste the name of the command script file in the Run box.
  3. Click Start, and then click Run.
  4. In the Open box, right-click, and then
    click Paste.
  5. Click OK.
  6. Notice that the Command Prompt window opens to run the command script
    file that you created. Notice also that this window closes automatically when
    the command script file has finished running. If you do not see the Command
    Prompt window open, check that you saved the command script file by using the
    correct name and that you entered the correct command script file name in the
    Run box.
Note If this method does
not work the first time, or if you cannot print anything after you use this
method, restart your computer, and then try again.
Posted on Oct 08, 2010
    Genius:
  • 1,354 Answers
Hi
  • Click the "Start" button, then click "Control Panel."
  • 2 Double-click the icon labeled "Printers" or "Printers and Faxes."
  • 3 Find the icon for your active printer and right click on it. Click "Open."
  • 4 You should be looking at the print jobs list. All of the current and pending print jobs should be listed. If you just want to cancel one or more specific jobs, right click each job you want to cancel and click "Cancel" on the menu that pops up. If you want to cancel all of the current and pending jobs, click the "Printer" menu at the top of the window and click "Cancel All Documents."
  • Posted on Oct 08, 2010
    Delete a print queue
      • To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
      • To cancel all print jobs, click Cancel All Documents on the Printer menu.
    Jan 11, 2015 | Office Equipment & Supplies
    HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
    First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
    • Windows 98 - click Start, Settings, Printers
    • Windows XP - click Start, Printers and Faxes
      or click Start, Control Panel, Printers and Faxes
    • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
    Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
    To cancel one or more print jobs, follow these steps.
    If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
    Alternatively You can check the below steps.
    Delete Pending Jobs
    How To Restart Spooler restart In Windows Vista
    Click the Start button.
    Click Control Panel.
    Click System and Maintenance.
    NOTE: This step is not required when using Classic view in Windows Vista.
    Click Administrative Tools.
    Double-click Services.
    On the User Account Control window, click Continue.
    Click Print Spooler.
    Click Stop to stop the Print Spooler.
    Click Start to restart the Print Spooler. Then click Restart
    Click OK
    Hope this helps!
    Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
    Jul 01, 2014 | HP LaserJet 4200 Printer
    I entered a print job that I want to cancel. How do I cancel printing?
    Click on the printer icon at the lower right hand corner of your screen.
    This will bring up the print spooler dialog. Make sure the print job you want to cancel is selected.
    You will find the Cancel command in the menu.
    Hope this helps.
    Jul 21, 2011 | HP DeskJet 970cxi InkJet Printer
    I would like to cancel a print job without losing all of my memory card picture selections. Seems rather silly to lose all your selections if something goes awry with your printer output.
    If you are using Windows, you can cancel a print job by opening your Start menu (usually the bottom left corner of your screen) then open Devices and Printers or Printers and Faxes depending on your version of Windows.
    Double left-click the name of your printer
    Right-click the name of the print job you want to cancel and select cancel print job or right-click a blank part of the printer box and select cancel all print jobs.
    Apr 12, 2011 | HP Photosmart 3310 Printer
    Unable to delete pending jobs
    1. Go to Control panel - Printers .
    2. Right-click the icon for your printer, and then click
    Open.
    3. To cancel individual print jobs, right-click the print job
    4. To cancel all print jobs, click Cancel All Documents on
    the Printer menu.
    Alternatively if this doesnt work you have to restart the spooler service
    1.Go to Control Panel - Click Administrative Tools.
    2.Double-click Services.
    3. Stop the service called Print Spooler.
    4. Click Start to restart the Print Spooler. Then click OK.
    Hope this helps.
    Mar 12, 2010 | HP LaserJet P4015N Printer
    How to cancel a print job that has multiple copies selected for the print job
    Click Start
    Click Control Panel
    Click Classic View
    Click Printers
    Double-click the active printer to open the "job-queue" window
    Select the file to be cancelled
    Right-mouse click on the selected file, and choose cancel.
    Nov 17, 2009 | Microsoft Windows XP Professional for PC
    Canon pixmaip4000
    Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
    1. On the Windows taskbar, double-click the printer icon located to the left of the time.
    2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
    3. From the 'Document' menu, select 'Cancel'.
    4. Repeat steps two and three to cancel another print job.
    5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
      1. Close the Printer window.
      2. Shut down the computer.
      3. Disconnect the printer cable (USB or parallel cable).
      4. Restart the computer.
      5. If a message window appears asking to cancel printing, select 'Yes'.
      6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
      7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
    6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
    May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
    Unable to cancel print queue
    You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
    You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
    (You may want to remove any paper from the paper tray first.)
    Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
    Apr 14, 2009 | Office Equipment & Supplies
    Can't cancel documents in the queue
    Hi grt2b1915
    go to printer not document selct cancel all while the printer power off.
    thanks
    Hamedo
    Nov 22, 2008 | Office Equipment & Supplies
    I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
    To cancel a print job in Windows you can use one of the following two methods:
    CANCELLING A PRINT JOB WITH THE PROGRESS METER:
    When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
    1. Highlight the print job in the PROGRESS METER box.
    2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
    3. Confirm cancelling the print job.
    CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
    If no PROGRESS METER appears, you can access the document queue in this fashion:
    1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
    2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
    3. Confirm cancelling all documents.
    Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
    If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
    Jul 16, 2008 | Epson Printer
    Pitney Bowes AddressRight DA300 Printer Logo
    254 people viewed this question
    Top Pitney Bowes Office Equipment & Supplies Experts
    Adorjani Laszlo
    Victorman
    Victorman
    Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
